16aa00
September 22, 2018, 2:33pm
1
I have generated RSA public and private key pair and now I am trying to generate CSR following
* Certificate request generation
* Copyright The Mbed TLS Contributors
* SPDX-License-Identifier: Apache-2.0
* Licensed under the Apache License, Version 2.0 (the "License"); you may
* not use this file except in compliance with the License.
* You may obtain a copy of the License at
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS, WITHOUT
* WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
#include "mbedtls/build_info.h"
This file has been truncated. show original
I am getting an error while trying to load the private key file in pk context using mbedtls_pk_parse_keyfile() as in this
This function is returning an error -15616. I checked the private key file by printing the key value and the path of private keyfile. I set the password as NULL.
Has anyone of you come across this issue or know what this error means? Could anyone of you please help or guide me how to solve this?
Any help is appreciated.
Thank you
What Arduino are you running this on?
"cert_req.c" is not a complete Arduino sketch. Can you provide a complete Arduino sketch that demonstrates the problem?
16aa00
September 23, 2018, 5:16pm
3
I am running on ESP32. Please find the relevant part of the sketch where I am facing problem.
#include "mbedtls/rsa.h"
#include "mbedtls/pk.h"
#include "mbedtls/sha1.h"
#include "mbedtls/platform.h"
#include "mbedtls/config.h"
#include "mbedtls/oid.h"
#include "mbedtls/ctr_drbg.h"
#include "mbedtls/x509.h"
#include "mbedtls/x509_csr.h"
#include "mbedtls/error.h"
#include<string.h>
#include "mbedtls/md.h"
#include "mbedtls/entropy.h"
#include "mbedtls/bignum.h"
#include "SPIFFS.h"
#include "FS.h"
#include <SD.h>
#include <SPI.h>
#define DFL_FILENAME "/spiffs/client.key"
#define DFL_DEBUG_LEVEL 0
#define DFL_OUTPUT_FILENAME "/spiffs/client.csr"
#define DFL_SUBJECT_NAME "CN=Cert,O=mbed TLS,C=UK"
#define DFL_KEY_USAGE 0
#define DFL_NS_CERT_TYPE 0
#define mbedtls_printf printf
struct options
const char *filename; /* filename of the key file */
int debug_level; /* level of debugging */
const char *output_file; /* where to store the constructed key file */
const char *subject_name; /* subject name for certificate request */
unsigned char key_usage; /* key usage flags */
unsigned char ns_cert_type; /* NS cert type */
} opt;
int ret = 1;
mbedtls_entropy_context entropy;
mbedtls_ctr_drbg_context ctr_drbg;
char buf[1024];
mbedtls_ctr_drbg_init( &ctr_drbg );
mbedtls_entropy_init( &entropy );
if( ( ret = mbedtls_ctr_drbg_seed( &ctr_drbg, mbedtls_entropy_func, &entropy,
(const unsigned char *) pers,
strlen( pers ) ) ) != 0 )
mbedtls_printf( " failed\n ! mbedtls_ctr_drbg_seed returned %d", ret );
return;
mbedtls_pk_context key;
mbedtls_x509write_csr req;
mbedtls_x509write_csr_init( &req );
mbedtls_x509write_csr_set_md_alg( &req, MBEDTLS_MD_SHA256 );
mbedtls_pk_init( &key );
memset( buf, 0, sizeof( buf ) );
opt.filename = DFL_FILENAME;
opt.debug_level = DFL_DEBUG_LEVEL;
opt.output_file = DFL_OUTPUT_FILENAME;
opt.subject_name = DFL_SUBJECT_NAME;
opt.key_usage = DFL_KEY_USAGE;
opt.ns_cert_type = DFL_NS_CERT_TYPE;
if( opt.key_usage )
mbedtls_x509write_csr_set_key_usage( &req, opt.key_usage );
if( opt.ns_cert_type )
mbedtls_x509write_csr_set_ns_cert_type( &req, opt.ns_cert_type );
mbedtls_printf( " . Seeding the random number generator..." );
return;
mbedtls_printf( " ok\n" );
* 1.0. Check the subject name for validity
mbedtls_printf( " . Checking subject name..." );
if( ( ret = mbedtls_x509write_csr_set_subject_name( &req, opt.subject_name ) ) != 0 )
mbedtls_printf( " failed\n ! mbedtls_x509write_csr_set_subject_name returned %d", ret );
return;
* 1.1. Load the key
mbedtls_printf( " . Loading the private key ..." );
SPIFFS.begin();
ret = mbedtls_pk_parse_keyfile( &key, opt.filename, NULL );
Serial.println(ret);
if( ret != 0 )
mbedtls_printf( " failed\n ! mbedtls_pk_parse_keyfile returned %d", ret );
return;
mbedtls_x509write_csr_set_key( &req, &key );
* 1.2. Writing the request
mbedtls_printf( " . Writing the certificate request ..." );
if( ( ret = write_certificate_request( &req, opt.output_file,
mbedtls_ctr_drbg_random, &ctr_drbg ) ) != 0 )
mbedtls_printf( " failed\n ! write_certifcate_request %d", ret );
return;
mbedtls_mpi_free( &N ); mbedtls_mpi_free( &P ); mbedtls_mpi_free( &Q );
mbedtls_mpi_free( &D ); mbedtls_mpi_free( &E ); mbedtls_mpi_free( &DP );
mbedtls_mpi_free( &DQ ); mbedtls_mpi_free( &QP );
mbedtls_rsa_free( &rsa );
mbedtls_ctr_drbg_free( &ctr_drbg );
mbedtls_entropy_free( &entropy );
Path of already generated RSA private key is "/spiffs/client.key"
