SSLClient SSL_ERROR Certificate is expired or not yet valid
I aim to have a MKR1000 board send information via MQTT over TLS. How can I get past this TLS error from the SSLClient library? The serial monitor gives the following error:
12:54:03.187 -> Attempting MQTT connection...(SSLClient)(SSL_WARN)(connect): Arduino client is already connected? Continuing anyway...12:54:03.352 -> (SSLClient)(SSL_WARN)(m_run_until): Terminating because the ssl engine closed12:54:03.352 -> (SSLClient)(SSL_ERROR)(m_start_ssl): Failed to initlalize the SSL layer12:54:03.352 -> (SSLClient)(SSL_ERROR)(m_print_br_error): Certificate is expired or not yet valid.12:54:03.352 -> failed, rc=-2 try again in 10 seconds
And the MQTT broker shows corresponding lines in the log:
1772967253: OpenSSL Error[0]: error:0A000126:SSL routines::unexpected eof while reading1772967253: Client  disconnected: Protocol error.1772967253: New connection from xx.yy.zz.aa:50101 on port 8883.
I’ve refreshed all the certificates, up to and including the self-signed CA, so I know they are up to date. The sketch also uses NTP to pull in the correct date to the MKR1000.
Here is what I’ve cobbled together for a sketch:
#include <SPI.h>
#include <WiFi101.h>
#include "wifi-secrets.h"
const char* ssid = WLAN_SSID;
const char* pass = WLAN_PASS;
const char* host = WLAN_HOST;
const char* mqttServer = BROKER_ADDRESS;
int status = WL_IDLE_STATUS;     /* the Wifi radio's status */
#include <SSLClient.h>
#include <PubSubClient.h>
#include <RTCZero.h>        /* https://www.arduino.cc/en/Reference/RTC */
#include "trust_anchors.h"  /* Certificate Authority */
#include "ssl-client.h"     /* my_cert , my_key */
RTCZero rtc;
/* https://www.industrialshields.com/blog/arduino-industrial-1/building-an-mqtt-over-tls-connection-a-guide-for-esp32-plc-537 */
void callback(char* topic, byte* payload, unsigned int length) {
  Serial.println("msg rcvd");
/* Define MQTT parameters */
WiFiClient netClient;
SSLClientParameters mTLS = SSLClientParameters::fromPEM(my_cert, sizeof my_cert, my_key, sizeof my_key);
SSLClient netClientSSL(netClient, TAs, (size_t)TAs_NUM, A5);
PubSubClient mqtt(mqttServer, 8883, callback, netClientSSL);
void reconnect() {
  // Loop until we're reconnected
  while (!mqtt.connected()) {
    Serial.print("Attempting MQTT connection...");
    // Attempt to connect
    if (mqtt.connect(ID_CLIENT)) {
      Serial.println("connected");
      // Once connected, publish an announcement...
      mqtt.publish("sensors/temperature","1772912070  9 22.0");
      Serial.print("failed, rc=");
      Serial.print(mqtt.state());
      Serial.println(" try again in 10 seconds");
      // Wait 10 seconds before retrying
      delay(10000);
void setup(){
  // Start Serial
  while(!Serial);
  // Enable mutual TLS with SSLClient
  netClientSSL.setMutualAuthParams(mTLS);
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.hostname(host);
  WiFi.begin(ssid, pass);
      Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  IPAddress ip = WiFi.localIP();
  Serial.println("IP address: ");
  Serial.println(ip);
  /* Initialize RTC */
  rtc.begin();
  int epoch = 0;
  while (! epoch or epoch < 1772915611) {
    epoch = WiFi.getTime();
    if (!epoch) {
      Serial.println("Waiting for network time");
  rtc.setEpoch(epoch);
  Serial.print("Epoch: ");
  Serial.println(epoch);
void loop(){
  if (!mqtt.connected()) {
    reconnect();
  mqtt.loop();
The header file, ssl-client.h, has the following structure (abbreviated here):
const char my_cert[] =
"-----BEGIN CERTIFICATE-----\n"
"MIIDFjCCAf6gAwIBAgIUFsIGQdtDoxw0wA8nFwnPo+DF1DIwDQYJKoZIhvcNAQEL\n"
"lISwTgSio2ghdvXdxug5HThyHWCi/AWtKsc=\n"
"-----END CERTIFICATE-----\n"
const char my_key[] =
"-----BEGIN PRIVATE KEY-----\n"
"MIIEvAIBADANBgkqhkiG9w0BAQEFAASCBKYwggSiAgEAAoIBAQCpXiIS3KYfPqC6\n"
"MW4HXhp+hqFnKKoazKjW9w==\n"
"-----END PRIVATE KEY-----\n"
All my Perl and Python scripts can connect to that MQTT broker just fine, albeit with TLS1.3 instead of TLS1.2 like the sketch seems to use. I’ve used openssl to triple check the certificates which I have imported and verified the dates are ok.
I've revisited the matter. It turned out to be a question of including both the CA cert and the broker cert in the trust anchors (as built by pycert_bearssl.py), and redoing the broker cert to identify the broker by name or address in the CN. (Is using CN that way deprecated though?)
Between these two excellent tutorials, I can now connect the Arduino (now a MKR1010 no longer using MKR1000) to the MQTT broker.
The MKR1010 connects now. However, until I got the ACLs sorted properly, I was seeing the below errors in the Mosquitto logs.
1781802319: New connection from xx.yy.zz.aa:64607 on port 8883.
1781802322: New client connected from xx.yy.zz.aa:64607 as mkr1010 (p2, c1, k15, u'username01').
1781802322: Bad socket read/write on client mkr1010: Quota exceeded
1781802337: New connection from xx.yy.zz.aa:64608 on port 8883.
1781802337: New client connected from xx.yy.zz.aa:64608 as mkr1010 (p2, c1, k15, u'username01').
1781802337: Bad socket read/write on client mkr1010: Quota exceeded
Now with the ACLs set correctly, the connection itself proceeds without error.
But, the although the reconnection function seems to pass through mqtt.publish() successfully, nothing shows up in MQTT:
void reconnect() {
    delay(15000);
    if (mqtt.connect(ID_CLIENT, MQTT_USER, MQTT_PASS)) {
      Serial.println("trying to publish");
      if (mqtt.publish("notifications","hello world\n")) {
        Serial.println("published");
        Serial.println("not published");
      Serial.println(" try again in 15 seconds");
      // Wait before retrying
Although it says that it has published to the topic, nothing shows up elsewhere:
20:29:55.061 -> Attempting MQTT connection...connected
20:29:57.853 -> trying to publish
20:29:57.853 -> published
Is there something missing from how mqtt.publish() is used there?
I'm going to call this one more or less solved. The sketch now communicates with the MQTT broker on port 8883 using MQTT over TLS.
EDIT: the official documentation
https://docs.arduino.cc/libraries/pubsubclient/
leads to this link
which, as of last week, says,
Caution
This library is not maintained. ...
