static uint16_t Compteur;
static char OrdreRecu;
Compteur=0;
pinMode(LED_BUILTIN, OUTPUT);
// the loop routine runs over and over again forever:
if (Serial.available()>0)
OrdreRecu=Serial.read();
switch (OrdreRecu)
case 'W':
digitalWrite(LED_BUILTIN, HIGH); // Allume la LED intégrée
byte lowByte = Serial.read();
byte highByte = Serial.read();
// Reconstruction de l'entier 16 bits signé (little endian)
int16_t valeur = (int16_t)((highByte << 8) | lowByte);
Compteur=valeur;
Compteur=512;
Serial.write((uint8_t*)&valeur, 2);
case 'R':
uint16_t C=Compteur;
Serial.write((uint8_t*)&C, 2);
default:
the led does not light up, but if I had this:
switch (OrdreRecu)
Thge led light up, it means that I received a byte, but it's never processed in the switch!!
I don't understand, perhaps it's a stupid error!!
Thanks for your help
If your LED does not light up you do not receive the expected data ('W' or 'R') but something else. It might be an incorrect baud rate, maybe parity or format.
What is the sender/receiver of the data? What is the format of the data? I have some doubts that it is Serial Monitor.
If I compile your code I get plenty of warnings because you declare variables inside cases. I suggest that you set the warning level under file → preferences to All. Not sure if that is the cause of your problem.
@gilshultz, your code does not compile; what are readUnint16LE() and writeUnint16LE()?
Hello,
No I haven't copy any program. I think that all of you don't understand where is the problem. In the code, the serial.available told that there is a byte ready in RS232 buffer, whatever the byte received, one of the switch's three possibilities should be executed, but this is not the case! The led is only use to debug and see where the program runs out. When you have a switch with two possibilities and a 'default', you MUST have one!
Thanks
It is rarely a good idea to declare new variables within cases of a switch; in your code, you do this more than once. Move those declarations outside the switch, and see if that solves it. IDR what the formal description of the error is, but I think that’s your problem.
Alternatively, try this:
Compteur = 0;
if (Serial.available() > 0) {
OrdreRecu = Serial.read();
switch (OrdreRecu) {
case 'W': {
Compteur = valeur;
Compteur = 512;
case 'R': {
uint16_t C = Compteur;
default:
If you go into preferences and enable verbose compiler output, then enable ALL warnings, you’ll see that the compiler is trying to tell you your code has structural problems.
Other than that, you haven’t mentioned WHAT Arduino this is on - it sometimes matters a whole lot, so please tell us!
Hello,
I have made some changes, first all declaratrions of variable are made at the beginning, not in the loop part. And, it's solves the problem, I have add {} after the case declaration (why???). Now I read properly my linear encoder, and I can change the value. The only problem remaining is that the Compteur variable is a 16bits variables and can not be change with an atomic instruction, and I can't use noInterrupts() / interrupts() because if I use them I could miss a step of the encoder.
Michel
const byte A = 2;
const byte B = 3;
static uint16_t ReadCompteur;
static byte LByte;
static byte HByte;
static byte ChangeOK;
static int16_t NewCompteur;
Serial.begin(38400);
pinMode(A, INPUT_PULLUP);
pinMode(B, INPUT_PULLUP);
ChangeOK=false;
Compteur=0;
attachInterrupt(digitalPinToInterrupt(A), onEventA, CHANGE);
attachInterrupt(digitalPinToInterrupt(B), onEventB, CHANGE);
switch (OrdreRecu)
case 'W': {
while (Serial.available()==0);
LByte = Serial.read();
HByte = Serial.read();
NewCompteur = (int16_t)((HByte << 8) | LByte);
ChangeOK = true;
case 'R':{
if (ChangeOK){
ReadCompteur=NewCompteur;
else{
ReadCompteur=Compteur;
Serial.write((uint8_t*)&ReadCompteur, 2);
default:
void onEventA() { // Changement d'état de A
if (ChangeOK){
ChangeOK=false;
if (digitalRead(A)==1) {
if (digitalRead(B)==0) { // A=1 B=0
Compteur--;
else{ // A=1 B=1
Compteur++;
else{
Compteur++; // A=0 B=0
else{
Compteur--; // A=0 B=1
void onEventB() { // Changement d'état de B
if (ChangeOK){
ChangeOK=false;
if (digitalRead(B)==1){
if (digitalRead(A)==1) { // A=1 B=1
Compteur++;
else{ // A=0 B=1
Compteur--;
else{
if (digitalRead(A)==0) { // A=0 B=0
Compteur--;
else{
Compteur++; // A=1 B=0
You misunderstand the purpose and function of these calls. The interrupt does not go away, it will still be there when you re-enable interrupts; the noInterrupts() call simply results in the suppression of the call to the interrupt function until interrupts() re-enables the interrupt. So unless your interrupt frequency is extreme, you won’t miss one, unless your interrupt routine itself is longer than necessary.
If your interrupt frequency is so high that you actually do miss interrupts despite optimizing the interrupt routine, you’d be best to move to a faster processor - although we don’t know that, because you have yet to tell us what Arduino this is running on.
Edit - Thank you for finally revealing your processor.
No more than 1000 interrupts per second, but if an interrupt arrive just after the noInterrupts and before the Interrupts, I will miss an interrupt? In this case I will lose the precision of my linear encoder https://www.posic.com/products/linear-encoders.html
My idea was to write:
noInterrupts;
Compteur =NewCompteur;
Interrupts;
outside of the interrupt code.
The system I am building is to mesure precisely during all the night the position of a focuser on a telescope.
