Error while setting serial port parameters
Error while setting serial port parameters: 9,600 N 8 1
i change to any type of parameters. such as 115200, problem still exist.
Hello All,
i have facing an instant error message as above.
re-installed driver, same problem exist.
looking in google, any step done. problem still exist.
any idea or solution about this matter? thank you
No. I might if you post the code though.
And the FULL error!
i got the message error :
  1. open the arduino ide.
  2. open the serial monitor, error appeared. no code also same problem. (standard open ide ).
i am sorry, suddently it was working well. i put the sketch then uploaded , it was okay.
before i just stuck with this error a few hours, can not do anything. solve by it self.
I know that this has a solution, but next time it will be very useful if we know what board you are using.
