Error while uploading
Hello, Yesterday when i uploaded the sketch to my arduino uno it worked fine but when today i tried to upload the sketch i got this error
avrdude: stk500_getsync(): not in sync: resp=0x00 avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
What does that mean ?
I'm having the same problem.. :relaxed: this is the error I get when i try to upload the sketch...
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x41
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x41 avrdude: stk500_set_extended_parms(): protocol error, expect=0x14, resp=0x45 avrdude: stk500_initialize(): failed
Resolved The problem was that i selected wrong serial COM port
There is no problem with the com port… I’m still unable to upload my sketches… :frowning:
I’m still a novice… any help would be appreciated… :drooling_face:
See i unplugged the arduino cable and again plugged it in and checked which port it uses and then selected that com port no. in the arduino software and it worked.
i tried that several times… no use… :frowning:
Could there be a problem with my arduino board???
I dont know that if the problem is in your arduino or not was there any other device attached to your pc alongwith arduino e.g ipod,etc Because when i got this error i had my ipod attached to the pc and when i removed the ipod and again tried it worked. I really dont know that it was because of that ipod but you can try this.
Problem Solved!!! XD The problem was with my hardware... :( got the atmega8 controller changed... now everything is working fine.. :)
im sry but i didnt get how you solved the problem
