Error with servoeasing in eezybotarm control by meisben (FIXED)
The readme says to open the sketch and upload to arduino. Everytime i try, i get this error code:
In file included from C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:50:0,
                 from C:\Users\kenan\AppData\Local\Temp\.arduinoIDE-unsaved20241010-19188-14v9tue.wpjk\sketch_nov10a\sketch_nov10a.ino:38:
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.h:58:1: error: expected unqualified-id before '/' token
In file included from C:\Users\kenan\AppData\Local\Arduino15\libraries\Servo\src/Servo.h:63:0,
                 from C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.h:134,
                 from C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:50,
C:\Users\kenan\AppData\Local\Arduino15\libraries\Servo\src/avr/ServoTimers.h:57:41: error: 'timer16_Sequence_t' does not name a type
 typedef enum { _timer1, _Nbr_16timers } timer16_Sequence_t;
In file included from C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.h:134:0,
C:\Users\kenan\AppData\Local\Arduino15\libraries\Servo\src/Servo.h:92:23: error: '_Nbr_16timers' was not declared in this scope
 #define MAX_SERVOS   (_Nbr_16timers  * SERVOS_PER_TIMER)
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.h:172:27: note: in expansion of macro 'MAX_SERVOS'
 #define MAX_EASING_SERVOS MAX_SERVOS // =12 use default value from Servo.h for Uno etc.
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.h:704:42: note: in expansion of macro 'MAX_EASING_SERVOS'
     static ServoEasing *ServoEasingArray[MAX_EASING_SERVOS];
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.h:705:47: note: in expansion of macro 'MAX_EASING_SERVOS'
     static float ServoEasingNextPositionArray[MAX_EASING_SERVOS];
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:156:44: note: in expansion of macro 'MAX_EASING_SERVOS'
 ServoEasing *ServoEasing::ServoEasingArray[MAX_EASING_SERVOS];
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:162:49: note: in expansion of macro 'MAX_EASING_SERVOS'
 float ServoEasing::ServoEasingNextPositionArray[MAX_EASING_SERVOS];
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp: In member function 'uint8_t ServoEasing::reattach()':
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:521:54: note: in expansion of macro 'MAX_EASING_SERVOS'
     for (uint_fast8_t tServoIndex = 0; tServoIndex < MAX_EASING_SERVOS; ++tServoIndex) {
In file included from C:\Users\kenan\AppData\Local\Temp\.arduinoIDE-unsaved20241010-19188-14v9tue.wpjk\sketch_nov10a\sketch_nov10a.ino:38:0:
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:522:13: error: 'ServoEasingArray' was not declared in this scope
         if (ServoEasingArray[tServoIndex] == NULL) {
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:522:13: note: suggested alternative: 'ServoEasing'
             ServoEasing
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp: In member function 'uint8_t ServoEasing::attach(int, int, int, int, int)':
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:611:54: note: in expansion of macro 'MAX_EASING_SERVOS'
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:612:13: error: 'ServoEasingArray' was not declared in this scope
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:612:13: note: suggested alternative: 'ServoEasing'
             ServoEasing
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp: In member function 'void ServoEasing::detach()':
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:700:9: error: 'ServoEasingArray' was not declared in this scope
         ServoEasingArray[mServoIndex] = NULL;
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:700:9: note: suggested alternative: 'ServoEasing'
         ServoEasing
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp: In member function 'void ServoEasing::write(int)':
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:842:5: error: 'ServoEasingNextPositionArray' was not declared in this scope
     ServoEasingNextPositionArray[mServoIndex] = aTargetDegreeOrMicrosecond;
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:842:5: note: suggested alternative: 'sServoNextPositionArray'
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp: In member function 'void ServoEasing::write(float)':
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:861:5: error: 'ServoEasingNextPositionArray' was not declared in this scope
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:861:5: note: suggested alternative: 'sServoNextPositionArray'
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp: In member function 'bool ServoEasing::startEaseToD(int, uint_fast16_t, bool)':
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:1354:9: error: 'ServoEasingNextPositionArray' was not declared in this scope
         ServoEasingNextPositionArray[mServoIndex] = aDegreeOrMicrosecond;
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:1354:9: note: suggested alternative: 'sServoNextPositionArray'
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp: In member function 'bool ServoEasing::startEaseToD(float, uint_fast16_t, bool)':
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:1408:9: error: 'ServoEasingNextPositionArray' was not declared in this scope
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:1408:9: note: suggested alternative: 'sServoNextPositionArray'
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp: In member function 'void ServoEasing::printStatic(Print*)':
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:1932:20: note: in expansion of macro 'MAX_EASING_SERVOS'
     aSerial->print(MAX_EASING_SERVOS);
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp: In function 'void setEasingTypeForMultipleServos(uint_fast8_t, uint_fast8_t)':
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2338:26: error: 'ServoEasingArray' is not a member of 'ServoEasing'
         if (ServoEasing::ServoEasingArray[tServoIndex] != NULL) {
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2339:26: error: 'ServoEasingArray' is not a member of 'ServoEasing'
             ServoEasing::ServoEasingArray[tServoIndex]->mEasingType = aEasingType;
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp: In function 'void printArrayPositions(Print*)':
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2404:37: error: 'ServoEasingNextPositionArray' is not a member of 'ServoEasing'
         aSerial->print(ServoEasing::ServoEasingNextPositionArray[tServoIndex]);
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp: In function 'void writeAllServos(int)':
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2412:26: error: 'ServoEasingArray' is not a member of 'ServoEasing'
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2413:26: error: 'ServoEasingArray' is not a member of 'ServoEasing'
             ServoEasing::ServoEasingArray[tServoIndex]->write(aDegreeOrMicrosecond);
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp: In function 'void setSpeedForAllServos(uint_fast16_t)':
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2420:26: error: 'ServoEasingArray' is not a member of 'ServoEasing'
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2421:26: error: 'ServoEasingArray' is not a member of 'ServoEasing'
             ServoEasing::ServoEasingArray[tServoIndex]->mSpeed = aDegreesPerSecond;
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp: In function 'void setIntegerDegreeForAllServos(uint_fast8_t, void**)':
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2432:22: error: 'ServoEasingNextPositionArray' is not a member of 'ServoEasing'
         ServoEasing::ServoEasingNextPositionArray[tServoIndex] = va_arg(*aDegreeValues, int);
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp: In function 'void setFloatDegreeForAllServos(uint_fast8_t, void**)':
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2440:22: error: 'ServoEasingNextPositionArray' is not a member of 'ServoEasing'
         ServoEasing::ServoEasingNextPositionArray[tServoIndex] = va_arg(*aDegreeValues, double);
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp: In function 'bool setEaseToForAllServos()':
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2481:26: error: 'ServoEasingArray' is not a member of 'ServoEasing'
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2482:46: error: 'ServoEasingArray' is not a member of 'ServoEasing'
             tOneServoIsMoving = ServoEasing::ServoEasingArray[tServoIndex]->setEaseTo(
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2483:34: error: 'ServoEasingNextPositionArray' is not a member of 'ServoEasing'
                     ServoEasing::ServoEasingNextPositionArray[tServoIndex], ServoEasing::ServoEasingArray[tServoIndex]->mSpeed)
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2483:90: error: 'ServoEasingArray' is not a member of 'ServoEasing'
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp: In function 'bool setEaseToForAllServos(uint_fast16_t)':
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2498:26: error: 'ServoEasingArray' is not a member of 'ServoEasing'
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2499:46: error: 'ServoEasingArray' is not a member of 'ServoEasing'
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2500:34: error: 'ServoEasingNextPositionArray' is not a member of 'ServoEasing'
                     ServoEasing::ServoEasingNextPositionArray[tServoIndex], aDegreesPerSecond) || tOneServoIsMoving;
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp: In function 'bool setEaseToDForAllServos(uint_fast16_t)':
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2514:26: error: 'ServoEasingArray' is not a member of 'ServoEasing'
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2515:46: error: 'ServoEasingArray' is not a member of 'ServoEasing'
             tOneServoIsMoving = ServoEasing::ServoEasingArray[tServoIndex]->setEaseToD(
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2516:34: error: 'ServoEasingNextPositionArray' is not a member of 'ServoEasing'
                     ServoEasing::ServoEasingNextPositionArray[tServoIndex], aMillisForMove) || tOneServoIsMoving;
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp: In function 'bool isOneServoMoving()':
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2524:26: error: 'ServoEasingArray' is not a member of 'ServoEasing'
         if (ServoEasing::ServoEasingArray[tServoIndex] != NULL && ServoEasing::ServoEasingArray[tServoIndex]->mServoMoves) {
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2524:80: error: 'ServoEasingArray' is not a member of 'ServoEasing'
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp: In function 'void stopAllServos()':
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2533:26: error: 'ServoEasingArray' is not a member of 'ServoEasing'
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2534:26: error: 'ServoEasingArray' is not a member of 'ServoEasing'
             ServoEasing::ServoEasingArray[tServoIndex]->mServoMoves = false;
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp: In function 'void pauseAllServos()':
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2546:26: error: 'ServoEasingArray' is not a member of 'ServoEasing'
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2547:26: error: 'ServoEasingArray' is not a member of 'ServoEasing'
             ServoEasing::ServoEasingArray[tServoIndex]->mServoIsPaused = true;
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2548:26: error: 'ServoEasingArray' is not a member of 'ServoEasing'
             ServoEasing::ServoEasingArray[tServoIndex]->mMillisAtStopMove = tMillis;
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp: In function 'void resumeWithInterruptsAllServos()':
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2556:26: error: 'ServoEasingArray' is not a member of 'ServoEasing'
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2557:26: error: 'ServoEasingArray' is not a member of 'ServoEasing'
             ServoEasing::ServoEasingArray[tServoIndex]->resumeWithInterrupts();
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp: In function 'void resumeWithoutInterruptsAllServos()':
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2564:26: error: 'ServoEasingArray' is not a member of 'ServoEasing'
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2565:26: error: 'ServoEasingArray' is not a member of 'ServoEasing'
             ServoEasing::ServoEasingArray[tServoIndex]->resumeWithoutInterrupts();
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp: In function 'bool updateAllServos()':
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2576:26: error: 'ServoEasingArray' is not a member of 'ServoEasing'
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2577:46: error: 'ServoEasingArray' is not a member of 'ServoEasing'
             tAllServosStopped = ServoEasing::ServoEasingArray[tServoIndex]->update() && tAllServosStopped;
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp: In function 'void synchronizeAllServosAndStartInterrupt(bool)':
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2638:26: error: 'ServoEasingArray' is not a member of 'ServoEasing'
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2638:80: error: 'ServoEasingArray' is not a member of 'ServoEasing'
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2640:47: error: 'ServoEasingArray' is not a member of 'ServoEasing'
             tMillisAtStartMove = ServoEasing::ServoEasingArray[tServoIndex]->mMillisAtStartMove;
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2641:30: error: 'ServoEasingArray' is not a member of 'ServoEasing'
             if (ServoEasing::ServoEasingArray[tServoIndex]->mMillisForCompleteMove > tMaxMillisForCompleteMove) {
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2642:58: error: 'ServoEasingArray' is not a member of 'ServoEasing'
                 tMaxMillisForCompleteMove = ServoEasing::ServoEasingArray[tServoIndex]->mMillisForCompleteMove;
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2661:26: error: 'ServoEasingArray' is not a member of 'ServoEasing'
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2661:80: error: 'ServoEasingArray' is not a member of 'ServoEasing'
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2662:26: error: 'ServoEasingArray' is not a member of 'ServoEasing'
             ServoEasing::ServoEasingArray[tServoIndex]->mMillisAtStartMove = tMillisAtStartMove;
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:2663:26: error: 'ServoEasingArray' is not a member of 'ServoEasing'
             ServoEasing::ServoEasingArray[tServoIndex]->mMillisForCompleteMove = tMaxMillisForCompleteMove;
C:\Users\kenan\AppData\Local\Temp\.arduinoIDE-unsaved20241010-19188-14v9tue.wpjk\sketch_nov10a\sketch_nov10a.ino: At global scope:
C:\Users\kenan\AppData\Local\Temp\.arduinoIDE-unsaved20241010-19188-14v9tue.wpjk\sketch_nov10a\sketch_nov10a.ino:88:50: error: no matching function for call to 'ServoEasing::ServoEasing(int, TwoWire*)'
 ServoEasing Servo1(PCA9685_DEFAULT_ADDRESS, &Wire);
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:395:1: note: candidate: ServoEasing::ServoEasing()
 ServoEasing::ServoEasing() // @suppress("Class members should be properly initialized")
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.hpp:395:1: note:   candidate expects 0 arguments, 2 provided
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.h:443:7: note: candidate: constexpr ServoEasing::ServoEasing(const ServoEasing&)
 class ServoEasing
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.h:443:7: note:   candidate expects 1 argument, 2 provided
C:\Users\kenan\Documents\Arduino\libraries\ServoEasing\src/ServoEasing.h:443:7: note: candidate: constexpr ServoEasing::ServoEasing(ServoEasing&&)
C:\Users\kenan\AppData\Local\Temp\.arduinoIDE-unsaved20241010-19188-14v9tue.wpjk\sketch_nov10a\sketch_nov10a.ino:89:50: error: no matching function for call to 'ServoEasing::ServoEasing(int, TwoWire*)'
 ServoEasing Servo2(PCA9685_DEFAULT_ADDRESS, &Wire);
 class ServoEasing
C:\Users\kenan\AppData\Local\Temp\.arduinoIDE-unsaved20241010-19188-14v9tue.wpjk\sketch_nov10a\sketch_nov10a.ino:90:50: error: no matching function for call to 'ServoEasing::ServoEasing(int, TwoWire*)'
 ServoEasing Servo3(PCA9685_DEFAULT_ADDRESS, &Wire);
 class ServoEasing
C:\Users\kenan\AppData\Local\Temp\.arduinoIDE-unsaved20241010-19188-14v9tue.wpjk\sketch_nov10a\sketch_nov10a.ino:91:50: error: no matching function for call to 'ServoEasing::ServoEasing(int, TwoWire*)'
 ServoEasing Servo0(PCA9685_DEFAULT_ADDRESS, &Wire);
 class ServoEasing
exit status 1
Compilation error: no matching function for call to 'ServoEasing::ServoEasing(int, TwoWire*)'
Heres the code
   ~~~~~Prerequisites~~~~~
   ServoEasing.h (https://github.com/ArminJo/ServoEasing) -> Just a fantastic library! wow :)
   ~~~~~Details~~~~~~~~~~~~
   Program title: EEZYbotARM control
   Author: Ben Money-Coomes (ben.money@gmail.com)
   Date: 20/11/19
   Purpose: Communicate with Python program for EEZYbotARM, move the arm
   IMPORTANT: This program receives data over the serial monitor. This data must be in the form of:
   "<HelloWorld,10.0,90.7,81.5,80.0,1000,2000,1000,1000>"
   Where this is the equivalent of <string, float, float, float, float, int, int, int, int>
   This is interpreted as <instruction, jointAngleEE (degrees), jointAngle1, jointAngle2, jointAngle3, movementTimeEE (milli seconds), movementTime1, movementTime2, movementTime3>
   ~~~~~Licence~~~~~~~~~~~~
   MIT License
   ~~~~~Read me~~~~~~~~~~~~
   Can be found at https://github.com/meisben/easyEEZYbotARM
   ~~~~~Version Control~~~
   v1.00 - exactly the same implementation as Robin2 code on Arduino forums
   v2.00 - no change, version control added. Works with same version of python program
   v3.00 - Beginning to take structure from 'servo easing' program -> BUT ONLY FOR COMMS
   v3.10 - Now including servo motor and buzzer control elements -> All servos working ! :)
   v3.20 - Changing order of angles so that end effector becomes pin0
  Library Includes.                                                              *
// include these libraries for using the servo add on board. Taken from servo example code
#include <Arduino.h>
// include this library for servo easing functionality
#include "ServoEasing.hpp"
#include <Wire.h>
  Definitions        *
#define VERSION "3.1"
#define BUZZER_PIN 5 // buzzer to featherwing pin 5, 470 ohm resistor
#define ACTION_TIME_PERIOD 1000
const int SERVO1_PIN = 1; // servo pin for joint 1
const int SERVO2_PIN = 2; // servo pin for joint 2
const int SERVO3_PIN = 3; // servo pin for joint 3
const int SERVO0_PIN = 0; // servo pin for end effector
  Variables        *
//-------- Variables for receiving serial data -------------
const byte buffSize = 40;
char inputBuffer[buffSize];
const char startMarker = '<';
const char endMarker = '>';
byte bytesRecvd = 0;
boolean readInProgress = false;
boolean newDataFromPC = false;
char messageFromPC[buffSize] = {0};
// -------- Variables to hold time -------------
unsigned long curMillis; // Variable for current time
// unsigned long general_timer;
// -------- Variables to hold the parsed data -------------
float floatFromPC0 = 90.0; // initial values are mid range for joint angles
float floatFromPC1 = 90.0;
float floatFromPC2 = 90.0;
float floatFromPC3 = 90.0;
int intFromPC0 = 1000; // inital values are acceptable movement times
int intFromPC1 = 1000;
int intFromPC2 = 1000;
int intFromPC3 = 1000;
float last_servoAngle_q1 = floatFromPC1; // initial values are mid range for joint angles
float last_servoAngle_q2 = floatFromPC2;
float last_servoAngle_q3 = intFromPC3;
float last_servoAngle_EE = floatFromPC0;
  Instatiate clasess for libraries                                               *
  START OF PROGRAM (Setup)                                                       *
  // flash LED so we know we are alive
  blinkLED();
  // Setup pins
  pinMode(LED_BUILTIN, OUTPUT); // setup built in LED for flashing
  pinMode(BUZZER_PIN, OUTPUT);  // Set buzzer pin as an output
  // Play tone so we can tell if the board accidently reset
  playTone();
  // Begin serial communications
  // Wait for serial communications to start before continuing
  while (!Serial)
    ; // delay for Leonardo
  // Just to know which program is running on my Arduino
  Serial.println(F("START " __FILE__ "\r\nVersion " VERSION " from " __DATE__));
  // Attach servo to pin
  Servo1.attach(SERVO1_PIN);
  Servo2.attach(SERVO2_PIN);
  Servo3.attach(SERVO3_PIN);
  Servo0.attach(SERVO0_PIN);
  // Set servo to start position.
  Servo1.setEasingType(EASE_CUBIC_IN_OUT);
  Servo2.setEasingType(EASE_CUBIC_IN_OUT);
  Servo3.setEasingType(EASE_CUBIC_IN_OUT);
  Servo0.setEasingType(EASE_CUBIC_IN_OUT); // end effector
  Servo1.write(last_servoAngle_q1);
  Servo2.write(last_servoAngle_q2);
  Servo3.write(last_servoAngle_q3);
  Servo0.write(last_servoAngle_EE); // end effector
  // Just wait for servos to reach position
  delay(500); // delay() is OK in setup as it only happens once
  // tell the PC we are ready
  Serial.println("<Arduino is ready>");
  MAIN PROGRAM (Loop)                                                            *
  // This part of the loop for the serial communication is not inside a timer -> it happens very quickly
  curMillis = millis(); // get current time
  getDataFromPC();      // receive data from PC and save it into inputBuffer
  // need if statement -> flag to say if new data is available
  if (newDataFromPC == true)
    processMessageFromPC();     // Processes text message from PC
    actionInstructionsFromPC(); // Arrange for things to move, beep, light up
    replyToPC();                // Reply to PC
  //  // This part of the loop is inside a timer -> maybe delete
  //  unsigned long elapsed_time_general_timer = millis() - general_timer;
  //  if ( elapsed_time_general_timer > ACTION_TIME_PERIOD ) // set a target for the Romi periodically
  //    // update timestamp
  //    general_timer = millis();
              FUNCTIONS FOR MAKING THINGS MOVE OR LIGHT UP OR BEEP!              *
//~~~~~~~~~~~~~Fuction: Blink LED~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
void blinkLED()
  digitalWrite(LED_BUILTIN, HIGH);
  delay(100);
  digitalWrite(LED_BUILTIN, LOW);
  delay(100);
//~~~~~~~~~~~~~Fuction: Play Buzzer Tone~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
void playTone()
  tone(BUZZER_PIN, 650, 300);
//~~~~~~~~~~~~~Fuction: Action the instructions from the PC~~~~~~~~~~~~~~~~~~~~~~~
void actionInstructionsFromPC()
  // Local variables
  //  -- joint angles
  float servoAngle_q1 = floatFromPC1;
  float servoAngle_q2 = floatFromPC2;
  float servoAngle_q3 = floatFromPC3;
  float servoAngle_EE = floatFromPC0;
  // -- joint speeds
  int servoTime_q1 = intFromPC1;
  int servoTime_q2 = intFromPC2;
  int servoTime_q3 = intFromPC3;
  int servoTime_EE = intFromPC0;
  // Check if the joint angle has changed!
  if (servoAngle_q1 != last_servoAngle_q1)
    Serial.println(F("Servo 1 moving to position using interrupts"));
    Servo1.startEaseToD(servoAngle_q1, servoTime_q1);
    //    while (Servo3.isMovingAndCallYield()) {
    //      ; // no delays here to avoid break between forth and back movement
  if (servoAngle_q2 != last_servoAngle_q2)
    Serial.println(F("Servo 2 moving to position using interrupts"));
    Servo2.startEaseToD(servoAngle_q2, servoTime_q2);
  if (servoAngle_q3 != last_servoAngle_q3)
    Serial.println(F("Servo 3 moving to position using interrupts"));
    Servo3.startEaseToD(servoAngle_q3, servoTime_q3);
  if (servoAngle_EE != last_servoAngle_EE)
    Serial.println(F("Servo EE moving to position using interrupts"));
    Servo0.startEaseToD(servoAngle_EE, servoTime_EE);
  // Store current joint angle
  last_servoAngle_q1 = servoAngle_q1;
  last_servoAngle_q2 = servoAngle_q2;
  last_servoAngle_q3 = servoAngle_q3;
  last_servoAngle_EE = servoAngle_EE;
              FUNCTIONS FOR RECEIVING DATA VIA SERIAL MONITOR                    *
//~~~~~~~~~~~~~Fuction: Receive data with start and end markers~~~~~~~~~~~~~~~~~~
void getDataFromPC()
  // This function receives data from PC and saves it into inputBuffer
  if (Serial.available() > 0 && newDataFromPC == false)
    char x = Serial.read();
    // the order of these IF clauses is significant
    if (x == endMarker)
      newDataFromPC = true;
      inputBuffer[bytesRecvd] = 0;
      parseData();
    if (readInProgress)
      inputBuffer[bytesRecvd] = x;
      bytesRecvd++;
      if (bytesRecvd == buffSize)
        bytesRecvd = buffSize - 1;
    if (x == startMarker)
      bytesRecvd = 0;
      readInProgress = true;
//~~~~~~~~~~~~~Fuction: Split data into known component parts~~~~~~~~~~~~~~~~~~
void parseData()
  // split the data into its parts
  char *strtokIndx; // this is used by strtok() as an index
  strtokIndx = strtok(inputBuffer, ","); // get the first part - the string
  strcpy(messageFromPC, strtokIndx);     // copy it to messageFromPC
  strtokIndx = strtok(NULL, ",");  // this continues where the previous call left off
  floatFromPC0 = atof(strtokIndx); // convert this part to a float -> to convert to an integer we would use atoi
  floatFromPC1 = atof(strtokIndx); // convert this part to a float
  floatFromPC2 = atof(strtokIndx); // convert this part to a float
  floatFromPC3 = atof(strtokIndx); // convert this part to a float
  intFromPC0 = atoi(strtokIndx); // convert this part to a int
  intFromPC1 = atoi(strtokIndx); // convert this part to a int
  intFromPC2 = atoi(strtokIndx); // convert this part to a int
  intFromPC3 = atoi(strtokIndx); // convert this part to a int
//~~~~~~~~~~~~~Fuction: Send message back to PC~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
void replyToPC()
  if (newDataFromPC)
    Serial.print(F("<Msg "));
    Serial.print(messageFromPC);
    Serial.print(F(" floatFromPC0 "));
    Serial.print(floatFromPC0);
    Serial.print(F(" floatFromPC1 "));
    Serial.print(floatFromPC1);
    Serial.print(F(" floatFromPC2 "));
    Serial.print(floatFromPC2);
    Serial.print(F(" floatFromPC3 "));
    Serial.print(floatFromPC3);
    Serial.print(F(" intFromPC0 "));
    Serial.print(intFromPC0);
    Serial.print(F(" intFromPC1 "));
    Serial.print(intFromPC1);
    Serial.print(F(" intFromPC2 "));
    Serial.print(intFromPC2);
    Serial.print(F(" intFromPC3 "));
    Serial.print(intFromPC3);
    Serial.print(F(" Time "));
    Serial.print(curMillis / 1000); // divide by 512 is approx = half-seconds
    Serial.println(F(">"));
//~~~~~~~~~~~~~Fuction: Process the string message from the PC~~~~~~~~~~~~~~~~~~~~
void processMessageFromPC()
  // this illustrates using different inputs to call different functions
  // strcmp compares two strings and returns zero if the strings are equal
  if (strcmp(messageFromPC, "LED") == 0)
    blinkLED();
  if (strcmp(messageFromPC, "BUZZ") == 0)
    playTone();
    playTone();
is the problem fixed or not fixed?
