My dabble app on my phone connects to the esp32 but dosent move the servos at all iv check wiring power supplies changed position of servo ect but it dosnt seem to help any bright idea's?
I have deleted your other post on the same subject @jorvikk.
Please use this forum topic for all further discussion on the problem you are encountering with controlling a servo using Dabble.
Someone is already trying to help you here, so why don't you provide the information they requested instead of wasting time creating duplicate topics???
C:\Users\jorvi\AppData\Local\Temp.arduinoIDE-unsaved2026731-10436-1mt84li.4jo7\sketch_aug31a\sketch_aug31a.ino:2:10: fatal error: ESP32Servo.h: No such file or directory
2 | #include <ESP32Servo.h>
compilation terminated.
exit status 1
Compilation error: ESP32Servo.h: No such file or directory
In your IDE, click the LIBRARY icon, enter "esp32servo" in the search bar, select "Kevin Harrington" library... After it is installed, compile the test sketch. Please, verify you are supplying power to the servo (VCC and GND) with an external power supply, and the ground pins are connected from ESP to Servo to Power Supply)
so dabble is using a game control layout. Using diamond, circle,ex,square & select buttons to move servo's. my phone has the dabble control it connects to the esp32 via bluetooth no problems but dosent make the servos move when appropriate buttons are pressed
Im not sure followed the link but my ide dosnt have the bluetooth example his did Im not sure if the app is dodgy or just my code im at a bit of a loss at the moment.
ok finaly ran test but to no avail not sure what do do next wondering if its my code:
#include "BluetoothSerial.h"
#if !defined(CONFIG_BT_ENABLED) || !defined(CONFIG_BLUEDROID_ENABLED)
#error Bluetooth is not enabled! Please run `make menuconfig` to and enable it
#endif
BluetoothSerial SerialBT;
SerialBT.begin("ESP32test"); //Bluetooth device name
Serial.println("The device started, now you can pair it with bluetooth!");
if (Serial.available()) {
SerialBT.write(Serial.read());
if (SerialBT.available()) {
Serial.write(SerialBT.read());
delay(20);
