Error with the definition of macro
Hello Everyone, I am trying to define a macro but I have this error in "#define ERROR_TIMEOUT 1":
exit status 1
return-statement with a value, in function returning 'void' [-fpermissive]
Someone can tell me how to fix this error!
Here is my code:
unsigned long timeout_start;
unsigned long timeout_ms;
String AtCommandCREG = "AT+CREG";
String bufferStringRX;
#define TIMEOUT_2000MS 2000
#define TIMEOUT_START { timeout_start = millis(); }
#define TIMEOUT_CHECK { if (millis() - timeout_start > timeout_ms) return ERROR_TIMEOUT; }
  timeout_ms = TIMEOUT_2000MS;
  TIMEOUT_START
  Serial.println(AtCommandCREG);
  while (!Serial.available()) {
    TIMEOUT_CHECK
    delay(1);
  if (! ERROR_TIMEOUT){
    bufferStringRX = Serial.readStringUntil('\n');
With the macros expanded your setup() function looks like this
  TIMEOUT_START
      if (millis() - timeout_start > timeout_ms) return 1;
    delay(1);
setup() is declared void but you are trying to return a value. Even if setup() were not declared void, so what do you imagine the calling function would do with the returned value ?
I have updated my code at the beginning, if ERROR_TIMEOUT 1 this tells me that it has timed out and I should no longer read the serial port
...and it still returns a value from a void function.
If you change code, repost it.
Do not modify earlier code.
That is a bad thing to do as subsequent comments about the original code are now nonsense. Please never do that again
Your amended code still tries to return a value from the void setup() function
  timeout_ms = 2000;
    delay(1);
  if (! 1)
I ask again where you thing the value is being returned to ?
I already understood my mistake, thanks for your assistance here is my new corrected code:
boolean flagErrorRX = false;
#define TIMEOUT_CHECK { if (millis() - timeout_start > timeout_ms) flagErrorRX = true; }
  TIMEOUT_START
  while (!Serial.available() && !flagErrorRX ) {
    TIMEOUT_CHECK
  if ( !flagErrorRX ) {
    Serial.println(bufferStringRX);
  else {
    Serial.println("Elapced Timeout");
  Serial.println("Timeout test finished");
Why are you using macros in the first place ?
I was looking for how to implement a timeout for the serial port and that it would give me a flag if it was completed and it was the only thing I found, do you have another suggestion?
Yes, put the code that you have put in the macros directly into the sketch
All your macros do is to replace the macro name with the defined text before compiling. Take a look at reply #5 for an example of what your code at that time looks like after the macro substitution and before compiling
