Sorry for all the confusion I created. Here is a better example of the problem I am facing and the approach I was taking.
I have 3 unsigned long multidimensional arrays, UL_ts_2(2x20x2), UL_ts_4(2x20x2) and UL_ts_6(2x20x2)
I have a variable, useMAT based on which I have to access the array, if useMAT == 2, then use UL_ts_2 and so on.
Below is the sketch that I had in my mind but I am running into some error.
while (!Serial) { // disable this for transmission using battery
delay(1);
delay(100);
unsigned long UL_ts_2[][20][2]=
{7183521,15054358},
{3513525,8095206},
{14289139,25676226},
{1438732,25810399},
{12734911,27752201},
{7532396,24679878},
{2375081,11911922},
{6631203,10418229},
{10659272,16612285},
{2870464,27492940},
{11161411,28184787},
{9372707,13017339},
{6841159,19607751},
{9283986,14364804},
{13050979,17856866},
{8380888,29756762},
{14965214,19634068},
{539149,27658707},
{11515074,19730461},
{2405716,10706691}
{5255281,9612658},
{3649293,20408857},
{3909713,7839397},
{1620755,15952189},
{12801070,23459946},
{7888263,21641568},
{3170487,22381978},
{8678940,23113224},
{11832601,26125492},
{21130673,26650729},
{10577002,19285681},
{17484013,29492016},
{11572296,26676557},
{2744130,19929664},
{8170272,16269506},
{19962353,23032229},
{8432494,22504018},
{10968127,17327825},
{4708815,21788327},
{9024753,25027543}
unsigned long UL_ts_4[][20][4]=
{6887281,10431377,14423387,29674734},
{855699,5098194,10242602,23615717},
{4323598,14050633,18232002,24837308},
{2982369,8723629,14223922,24219092},
{1282346,5451338,10084374,14973366},
{5712674,18121455,25252334,29896816},
{1035543,16138287,22178944,25212051},
{3800102,7582790,19654775,24427522},
{1942666,12166996,15289004,25081034},
{2690345,8934233,18047413,29214025},
{10720888,15339088,20359357,24424755},
{286892,3680907,14440622,19757335},
{4714656,13245326,21583348,28553461},
{2276352,14794345,19847612,23185080},
{4585811,7820858,18270903,29470193},
{929590,11070559,21511264,28843956},
{3472109,10359105,21641005,28730096},
{6451108,14675222,18325881,27205782},
{4872556,11708752,23940426,29627903},
{7523500,10620609,17997105,22909985}
{2277384,5849626,12747672,27537002},
{12427873,19583864,23396268,28215977},
{15936,7300593,19855615,27500166},
{1861495,5051385,12380484,16559917},
{2498732,13970187,18269857,21547339},
{257490,8074439,19440059,27705543},
{8595783,12750304,17737653,23715377},
{9408004,15430112,24526746,29522393},
{33062,3817775,19011799,23459314},
{13221256,16602003,22287298,28334250},
{1669342,6866398,18033594,22029610},
{2501358,10429401,14576182,27148973},
{5940817,10792858,23395714,27157834},
{1436617,10737688,14920309,27477426},
{3353771,6904451,25699090,29642159},
{508353,9430217,19479526,27139704},
{3499431,8412216,17947618,28908203},
{1503919,6786951,13933212,18247236},
{3433393,10113238,14835269,18437638},
{3242247,7549632,24961022,28128484}
unsigned long UL_ts_6[][20][6]=
{3584199,9136465,13135067,19773816,25621416,29703935},
{1381758,6033833,11619288,18804660,22389595,28293969},
{2367247,8588529,12836317,17117675,21077918,27199653},
{877638,5513161,9501931,13075653,19263225,26468018},
{615544,5166129,13396518,20100612,23861985,29916158},
{1586096,5264406,8357912,13077912,16087379,26310919},
{1578205,4721599,9105696,16808426,23549719,28291025},
{1986143,9782852,16949818,20185690,23232901,26274562},
{472024,8851744,16977463,20267644,23569043,29946695},
{419760,6598479,12746651,20653097,25489445,29228192},
{1572567,8037902,11722386,16578727,20872337,26419726},
{8686876,13420708,17122344,20875842,26408806,29466540},
{1402967,4534198,10051747,17665808,23340667,29968602},
{2573376,5700811,8780160,15545675,20219416,23578274},
{224071,7305928,10851017,15882044,19362372,28919877},
{925432,6344691,12985969,20906068,24293489,29197976},
{1068664,5160175,10955417,16252120,24023426,28421952},
{1179614,5843778,10725696,18685967,22620575,27818098},
{2269792,7957493,12483714,16687262,25139037,28437653},
{38318,7757025,11224176,17466179,25406833,29230408}
{2508040,6715843,11035756,14174431,18750190,22786456},
{2598405,7692101,13139918,19433181,23891611,29371969},
{2702313,6440898,11071549,20183194,25120749,29364404},
{658615,4465203,7475132,22435346,25793851,28820982},
{1264532,5941628,9282194,15920263,21775578,28353777},
{982084,5248110,8624975,11700015,23231676,27221707},
{23833,4362240,7557470,19199918,23528300,29153991},
{186646,6652909,11086423,20733630,24488609,28102442},
{1314926,6125311,10628668,15478645,22475695,27399227},
{1222408,4613857,12848034,18218949,24566076,29731693},
{849785,5621619,10210910,14857732,17899447,20907680},
{1499914,5668550,8816382,13471028,17359170,23390633},
{171495,3506970,8024148,12050697,21125753,27819109},
{1224563,4396521,8345902,19423314,24143913,27368122},
{2988573,6382336,16968949,20669024,24542018,29219150},
{88424,3574307,13247207,16289786,19985104,24138245},
{1050217,6544856,14524617,20523404,26504647,29640818},
{1038791,8185018,13421103,17327727,22079179,27829221},
{345602,5766500,9062088,12450047,21810047,27889992},
{6737160,10826723,15717352,20259086,23358502,26673468}
size_t const useMAT = 4;
if(useMAT == 2){
unsigned long (*pointerArr)[20][2] = UL_ts_2;
else if(useMAT ==4){
unsigned long (*pointerArr)[20][4] = UL_ts_4;
else{
unsigned long (*pointerArr)[20][6] = UL_ts_6;
Serial.print("useMAT: ");
Serial.println(useMAT);
Serial.println(pointerArr[0][0][0]);
Serial.println(pointerArr[1][0][0]);
Serial.println(pointerArr[2][0][0]);
ERROR:
test:381:18: error: 'pointerArr' was not declared in this scope
381 | Serial.println(pointerArr[0][0][0]);
exit status 1
