Error
Hallo,
Please some help…
I got the message “lcd” was not declared in this scope, see lowest syntax of the sketch
What can I dor to make this program run ??
regards Bob
zhtech@zhtech.nl
// http://www.vbotix.com/up-down-counter-using-arduino/
// set up the LCD’s number of columns and rows:
lcd.begin(16, 2);
// Print a message to the LCD.
// lcd.print(“Up-Down Counter”);
// Declare Switches as INPUT to Arduino
pinMode(sw1,INPUT);
pinMode(sw2,INPUT);
digitalWrite(sw1,HIGH);
digitalWrite(sw2,HIGH);
if(digitalRead(sw1) == LOW) // if SW1 is pressed perform action described in loop
count++; // Increment Count by 1
lcd.setCursor(0, 1);
lcd.print(count);
delay(400);
if(digitalRead(sw2) == LOW) // if SW2 is pressed perform action described in loop
count–; // Decrement Count by 1
if(count < 0)
count = 0;
lcd.print(count);
delay(400);
include the lcd library and create an instance named lcd would seem to be a good idea.
Look at the Examples presented under the LCD library.
