Arduino: 1.8.19 (Windows 7), Board: "NodeMCU 0.9 (ESP-12 Module), 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexRtc.cpp: In member function 'bool NexRtc::write_rtc_time(uint32_t*)':
F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexRtc.cpp:123:1: error: no return statement in function returning non-void [-Werror=return-type]
123 | }
F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexRtc.cpp: In member function 'uint32_t NexRtc::read_rtc_time(char*, uint32_t)':
F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexRtc.cpp:238:1: error: no return statement in function returning non-void [-Werror=return-type]
238 | }
F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexRtc.cpp: In member function 'uint32_t NexRtc::read_rtc_time(uint32_t*, uint32_t)':
F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexRtc.cpp:285:1: error: no return statement in function returning non-void [-Werror=return-type]
285 | }
F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexRtc.cpp: In member function 'bool NexRtc::write_rtc_time(char*)':
F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexRtc.cpp:20:30: error: control reaches end of non-void function [-Werror=return-type]
20 | String cmd = String("rtc");
cc1plus.exe: some warnings being treated as errors
F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexUpload.cpp: In member function 'bool NexUpload::_downloadTftFile()':
F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexUpload.cpp:197:30: error: control reaches end of non-void function [-Werror=return-type]
197 | String string = String("");
exit status 1
Error compiling for board NodeMCU 0.9 (ESP-12 Module).
option enabled in File -> Preferences.
qualcuno sa darmi come posso risolvere ? Grazie !!
Magari postando lo sketch?
Ecco lo sketch
#define ENCODER_OPTIMIZE_INTERRUPTS
#include <Nextion.h>
#include <Encoder.h>
#include <EasyNextionLibrary.h>
EasyNex myNex(Serial);
NexDSButton b_ss = NexDSButton (0, 32, "bt0");
NexButton b_ret = NexButton (0, 13, "b1");
NexButton b_loa = NexButton (0, 19, "b2");
NexNumber thread_n = NexNumber (0, 30, "va0");
NexNumber depth_n = NexNumber (0, 32, "va1");
//NexNumber ret_st = NexNumber (0,34,"n3");
NexProgressBar bar = NexProgressBar (0, 21, "j0");
NexTouch *nex_listen_list[] = {
&b_ss, &b_ret, &b_loa, &thread_n, &depth_n, NULL
Encoder enc(2, 3);
int rele_a = 4; // pin rele A
int rele_b = 5; //pin rele B
volatile float pos = 0; // posizione corrente encoder
volatile float old_pos = 0; // vecchia posizione encoder
int pos_2 = 0; //
uint32_t thread = 0; // passo selezionato in mm
uint32_t depth = 0; // valore profondità da raggiungere in mm
uint32_t b_ss_st = 0; //stato pulsante start stop
uint32_t b_ret_st = 0; //stato bottone ritorno
float Step = 0; // numero rotazioni
bool milling = false; //filetttura
bool pause = false; //intervallo
bool escape = false; //fine ciclo
bool zero_enc = false; //azzeramento encoder
int ret_st = 0; //stato di RETURN
int max_step = 600; //NUMERO PASSI TOTALI ENCODER
int step_2 = 0; //conversione mm profondità in step ( step da raggiungere)
float depth_2 = 0; // profondità
float thread_2 = 0; //conversione passo in step
int comp_cic = 0; //cicli completati
int bar_value = 0; // variabile per progress bar
pinMode (rele_a, OUTPUT);
pinMode (rele_b, OUTPUT);
digitalWrite (rele_a, LOW);
digitalWrite (rele_b, LOW);
myNex.begin(9600);
b_ss_st = 0;
b_ret_st = 0;
b_ss.attachPop(start_stop, &b_ss);
b_loa.attachPop(loading, &b_loa);
b_ret.attachPush(INDIETRO_ON, &b_ret);
b_ret.attachPop(INDIETRO_OFF, &b_ret);
nexInit();
delay (1000);
ENCODER();
myNex.NextionListen();
nexLoop(nex_listen_list);
if (b_ss_st == 1) {
RUN();
PAUSE();
void ENCODER() {
volatile float encoderPos = enc.read() / 4;
if (encoderPos != pos) {
pos = encoderPos;
pos_2 = (thread_2 / 60000) * pos;
PROG_BAR();
myNex.writeNum("page0.n1.val", pos);
if (thread != 0) {
myNex.writeNum("page0.x5.val", pos_2);
void loading (void *ptr) {
Soft_reset ();
thread_n.getValue (&thread);
depth_n.getValue (&depth);
thread_2 = thread * 100;
depth_2 = depth * 100;
Step = (depth_2 / thread_2);
step_2 = Step * max_step;
myNex.writeNum ("page0.x4.val", thread);
myNex.writeNum ("page0.x1.val", depth);
myNex.writeNum ("page0.n2.val", step_2);
delay (100);
void start_stop (void *ptr) {
b_ss.getValue (&b_ss_st);
void Soft_reset () {
enc.write (0);
pos = 0;
pos_2 = 0;
b_ss_st = 0;
milling = false;
pause = false;
escape = false;
zero_enc = false;
myNex.writeNum ("page0.bt0.val", 0);
void PAUSE () {
void PROG_BAR () {
if (b_ss_st == 1) {
bar_value = map (pos, 0, step_2, 0, 100);
bar.setValue (bar_value);
void INDIETRO_ON (void *ptr) {
digitalWrite (rele_b, HIGH);
void INDIETRO_OFF (void *ptr) {
void RUN () {
if (zero_enc == false) {
enc.write (0);
zero_enc = true;
if ((milling == false) && (pause == false) && (pos <= step_2) && (escape == false)) {
digitalWrite (rele_a, HIGH);
if ((milling == false) && (pause == false) && (pos >= step_2) && (escape == false)) {
milling = true;
pause = true;
delay (2000);
if ((milling == true) && (escape == false) && (pause == true) && (pos > -max_step)) {
if ((milling == true) && (escape == false) && (pause == true) && (pos <= -max_step)) {
escape = true;
comp_cic = comp_cic + 1;
myNex.writeNum ("page0.n0.val", comp_cic);
myNex.writeNum ("page0.t3.aph", 127);
myNex.writeNum ("page0.t3.aph", 0);
Soft_reset ();
delay (1500);
Ma lo sketch di per sè è a posto, penso che il problema sia dato dalla libreria Nextion.h
... da quanto dice sta trattando i "warning" come fossero "errors" ... mi pare di ricordare che siano opzioni di compilazione che si trovano in "platform.txt" (relativo alla board scelta) ... ![]()
@cotestatnt: mi pare che tu una volta avevi indicato come aggirare il problema ... o era per ESP32?
Guglielmo
Si, nel platform.txt del "core" ESP8266 c'è una riga che dice:
compiler.c.flags=-c "{compiler.warning_flags}-cflags" -std=gnu17 {build.stacksmash_flags} -g -free -fipa-pta -Werror=return-type -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -ffunction-sections -fdata-sections {build.exception_flags} {build.sslflags} {build.mmuflags} {build.non32xferflags}
Come vedi ad un certo punto c'è -Werror=return-type che, stando a quanto viene descritto sui reference di gcc, indica di considerare errore il warning relativo a qualsiasi cosa non vada con il valore di ritorno di una funzione.
Ora, il compilatore, nella compilazione della libreria Nextion, segnala più e più volte:
Potreti provare ad editare il platform.txt relativo al "core" ESP8266 ed eliminare SOLO quel pezzo così da NON considerare errore il mancato ritorno di un valore da parte di una funzione ... ![]()
Guglielmo
Ciao Guglielmo e grazie per la risposta, purtroppo le mie conoscenze non sono così avanzate, per favore potresti dirmi in quale cartella dovrei trovare questo file da modificare ?
Ci provo ... io sono sotto macOS e, sotto l'unica macchina Win che ho, ho un installazione "portable" (... e mi sa non aggiornatissima), comunque, da qualche parte, DENTRO la cartella Arduino, dovresti avere un percorso che , più o meno, dovrebbe essere:
\packages\esp8266\hardware\esp8266\3.1.1
prima di packages c'è sicuramente qualche cosa e 3.1.1 potrebbe anche essere 3.1.2 ... dentro a detta cartella c'è il file platform.txt che dovresti editare con il notepad (per non aggiungere caratteri strani).
Guglielmo
Mmmm ... guardando su github il file nel "core" vedo che la cosa compare in DUE punti:
In QUESTA riga ed in QUESTA riga ... lo devi eliminare da entrambe (solo il pezzetto: -Werror=return-type).
Guglielmo
P.S.: QUI le opzioni di warning di gcc.
ok conosco la cartella, ma è normale che sia inserita nella cartella (per altro nascosta) appData/local/Arduino15/packages/.... ? quando ho installato il supporto per esp8266 tramite ide è stata infilata lì in automatico , non mi sembra tanto normale ... o sbaglio ?
Mah ... Win fa strane cose ... per questo io faccio sempre un installazione "portable", per avere TUTTO racchiuso nella cartella Arduino che dico io ... così posso anche avere diverse versioni delle stesse cose per fare le prova.
Comunque, se l'ha messo li ... prova a cercare li ... ![]()
Guglielmo
il file l'ho trovato , ti posto quello che c'è scritto dentro :
# ESP8266 platform
# For more info:
# https://github.com/arduino/Arduino/wiki/Arduino-IDE-1.5-3rd-party-Hardware-specification
name=ESP8266 Boards (3.1.2)
version=3.1.2
# These will be removed by the packager script when doing a JSON release
runtime.tools.signing={runtime.platform.path}/tools/signing.py
runtime.tools.elf2bin={runtime.platform.path}/tools/elf2bin.py
runtime.tools.sizes={runtime.platform.path}/tools/sizes.py
runtime.tools.makecorever={runtime.platform.path}/tools/makecorever.py
runtime.tools.mkbuildoptglobals={runtime.platform.path}/tools/mkbuildoptglobals.py
runtime.tools.mkdir={runtime.platform.path}/tools/mkdir.py
runtime.tools.cp={runtime.platform.path}/tools/cp.py
runtime.tools.eboot={runtime.platform.path}/bootloaders/eboot/eboot.elf
compiler.warning_flags=@{runtime.platform.path}/tools/warnings/none
compiler.warning_flags.none=@{runtime.platform.path}/tools/warnings/none
compiler.warning_flags.default=@{runtime.platform.path}/tools/warnings/default
compiler.warning_flags.more=@{runtime.platform.path}/tools/warnings/more
compiler.warning_flags.all=@{runtime.platform.path}/tools/warnings/extra
build.lwip_lib=-llwip_gcc
build.lwip_include=lwip/include
build.lwip_flags=-DLWIP_OPEN_SRC
build.vtable_flags=-DVTABLES_IN_FLASH
build.sslflags=
build.mmuflags=
build.non32xferflags=
build.exception_flags=-fno-exceptions
build.stdcpp_lib=-lstdc++
build.stdcpp_level=-std=gnu++17
build.stacksmash_flags=
build.float=-u _printf_float -u _scanf_float
build.led=
# default SDK for all boards
# (generic board overrides this variable)
build.sdk=NONOSDK22x_190703
#build.sdk=NONOSDK22x_191024
#build.sdk=NONOSDK22x_191105
# These are not overriden when FS is not configured
build.eeprom_start=
build.spiffs_start=
build.spiffs_end=
build.spiffs_blocksize=
# Fully qualified file names for processing sketch global options
globals.h.source.fqfn={build.source.path}/{build.project_name}.globals.h
commonhfile.fqfn={build.core.path}/CommonHFile.h
build.opt.fqfn={build.path}/core/build.opt
build.opt.flags="@{build.opt.fqfn}"
mkbuildoptglobals.extra_flags=
compiler.path={runtime.tools.xtensa-lx106-elf-gcc.path}/bin/
compiler.sdk.path={runtime.platform.path}/tools/sdk
compiler.libc.path={runtime.platform.path}/tools/sdk/libc/xtensa-lx106-elf
compiler.cpreprocessor.flags=-D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 {build.opt.flags} "-I{compiler.sdk.path}/include" "-I{compiler.sdk.path}/{build.lwip_include}" "-I{compiler.libc.path}/include" "-I{build.path}/core"
# support precompiled libraries in IDE v1.8.6+
compiler.libraries.ldflags=
compiler.c.cmd=xtensa-lx106-elf-gcc
compiler.c.flags=-c "{compiler.warning_flags}-cflags" -std=gnu17 {build.stacksmash_flags} -Os -g -free -fipa-pta -Werror=return-type -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -ffunction-sections -fdata-sections {build.exception_flags} {build.sslflags} {build.mmuflags} {build.non32xferflags}
compiler.S.cmd=xtensa-lx106-elf-gcc
compiler.S.flags=-c -g -x assembler-with-cpp -MMD -mlongcalls "-I{runtime.tools.xtensa-lx106-elf-gcc.path}/include/"
compiler.c.elf.flags=-g "{compiler.warning_flags}-cflags" -Os -nostdlib -Wl,--no-check-sections -u app_entry {build.float} -Wl,-static "-L{compiler.sdk.path}/lib" "-L{compiler.sdk.path}/lib/{build.sdk}" "-L{build.path}" "-L{compiler.libc.path}/lib" "-Tlocal.eagle.flash.ld" -Wl,--gc-sections -Wl,-wrap,system_restart_local -Wl,-wrap,spi_flash_read
compiler.c.elf.cmd=xtensa-lx106-elf-gcc
compiler.c.elf.libs=-lhal -lphy -lpp -lnet80211 {build.lwip_lib} -lwpa -lcrypto -lmain -lwps -lbearssl -lespnow -lsmartconfig -lairkiss -lwpa2 {build.stdcpp_lib} -lm -lc -lgcc
compiler.cpp.cmd=xtensa-lx106-elf-g++
compiler.cpp.flags=-c "{compiler.warning_flags}-cppflags" {build.stacksmash_flags} -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 {build.stdcpp_level} -MMD -ffunction-sections -fdata-sections {build.exception_flags} {build.sslflags} {build.mmuflags} {build.non32xferflags}
compiler.as.cmd=xtensa-lx106-elf-as
compiler.ar.cmd=xtensa-lx106-elf-ar
compiler.ar.flags=cru
compiler.elf2hex.cmd=esptool
compiler.elf2hex.flags=
compiler.size.cmd=xtensa-lx106-elf-size
# This can be overridden in boards.txt
build.extra_flags=
# These can be overridden in platform.local.txt
compiler.c.extra_flags=
compiler.c.elf.extra_flags=
compiler.S.extra_flags=
compiler.cpp.extra_flags=
compiler.ar.extra_flags=
compiler.objcopy.eep.extra_flags=
compiler.elf2hex.extra_flags=
## generate file with git version number
## needs git
recipe.hooks.sketch.prebuild.pattern="{runtime.tools.python3.path}/python3" -I "{runtime.tools.signing}" --mode header --publickey "{build.source.path}/public.key" --out "{build.path}/core/Updater_Signing.h"
# This is quite a working hack. This form of prebuild hook, while intuitive, is not explicitly documented.
# Handle processing sketch global options
recipe.hooks.prebuild.2.pattern="{runtime.tools.python3.path}/python3" -I "{runtime.tools.mkbuildoptglobals}" "{runtime.ide.path}" {runtime.ide.version} "{build.path}" "{build.opt.fqfn}" "{globals.h.source.fqfn}" "{commonhfile.fqfn}" {mkbuildoptglobals.extra_flags}
## Build the app.ld linker file
recipe.hooks.linking.prelink.1.pattern="{runtime.tools.python3.path}/python3" -I "{runtime.tools.mkdir}" -p "{build.path}/ld_h/"
recipe.hooks.linking.prelink.2.pattern="{runtime.tools.python3.path}/python3" -I "{runtime.tools.cp}" "{runtime.platform.path}/tools/sdk/ld/{build.flash_ld}" "{build.path}/ld_h/local.eagle.flash.ld.h"
recipe.hooks.linking.prelink.3.pattern="{compiler.path}{compiler.c.cmd}" -CC -E -P {build.vtable_flags} {build.mmuflags} "{build.path}/ld_h/local.eagle.flash.ld.h" -o "{build.path}/local.eagle.flash.ld"
recipe.hooks.linking.prelink.4.pattern="{compiler.path}{compiler.c.cmd}" -CC -E -P {build.vtable_flags} {build.mmuflags} "{runtime.platform.path}/tools/sdk/ld/eagle.app.v6.common.ld.h" -o "{build.path}/local.eagle.app.v6.common.ld"
## Compile c files
recipe.c.o.pattern="{compiler.path}{compiler.c.cmd}" {compiler.cpreprocessor.flags} {compiler.c.flags} -D{build.sdk}=1 -DF_CPU={build.f_cpu} {build.lwip_flags} {build.debug_port} {build.debug_level} -DARDUINO={runtime.ide.version} -DARDUINO_{build.board} -DARDUINO_ARCH_{build.arch} -DARDUINO_BOARD="{build.board}" -DARDUINO_BOARD_ID="{_id}" {build.led} {build.flash_flags} {compiler.c.extra_flags} {build.extra_flags} {includes} "{source_file}" -o "{object_file}"
## Compile c++ files
recipe.cpp.o.pattern="{compiler.path}{compiler.cpp.cmd}" {compiler.cpreprocessor.flags} {compiler.cpp.flags} -D{build.sdk}=1 -DF_CPU={build.f_cpu} {build.lwip_flags} {build.debug_port} {build.debug_level} -DARDUINO={runtime.ide.version} -DARDUINO_{build.board} -DARDUINO_ARCH_{build.arch} -DARDUINO_BOARD="{build.board}" -DARDUINO_BOARD_ID="{_id}" {build.led} {build.flash_flags} {compiler.cpp.extra_flags} {build.extra_flags} {includes} "{source_file}" -o "{object_file}"
## Compile S files
recipe.S.o.pattern="{compiler.path}{compiler.c.cmd}" {compiler.cpreprocessor.flags} {compiler.S.flags} -D{build.sdk}=1 -DF_CPU={build.f_cpu} {build.lwip_flags} {build.debug_port} {build.debug_level} -DARDUINO={runtime.ide.version} -DARDUINO_{build.board} -DARDUINO_ARCH_{build.arch} -DARDUINO_BOARD="{build.board}" -DARDUINO_BOARD_ID="{_id}" {build.led} {build.flash_flags} {compiler.S.extra_flags} {build.extra_flags} {includes} "{source_file}" -o "{object_file}"
## Create archives
recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}"
## Combine gc-sections, archives, and objects
recipe.c.combine.pattern="{compiler.path}{compiler.c.elf.cmd}" {build.exception_flags} -Wl,-Map "-Wl,{build.path}/{build.project_name}.map" {compiler.c.elf.flags} {compiler.c.elf.extra_flags} -o "{build.path}/{build.project_name}.elf" -Wl,--start-group {object_files} "{archive_file_path}" {compiler.c.elf.libs} {compiler.libraries.ldflags} -Wl,--end-group "-L{build.path}"
## Create eeprom
recipe.objcopy.eep.pattern=
## Create hex
recipe.objcopy.hex.1.pattern="{runtime.tools.python3.path}/python3" -I "{runtime.tools.elf2bin}" --eboot "{runtime.tools.eboot}" --app "{build.path}/{build.project_name}.elf" --flash_mode {build.flash_mode} --flash_freq {build.flash_freq} --flash_size {build.flash_size} --path "{runtime.tools.xtensa-lx106-elf-gcc.path}/bin" --out "{build.path}/{build.project_name}.bin"
recipe.objcopy.hex.2.pattern="{runtime.tools.python3.path}/python3" -I "{runtime.tools.signing}" --mode sign --privatekey "{build.source.path}/private.key" --bin "{build.path}/{build.project_name}.bin" --out "{build.path}/{build.project_name}.bin.signed" --legacy "{build.path}/{build.project_name}.bin.legacy_sig"
recipe.objcopy.hex.3.pattern="{runtime.tools.python3.path}/python3" -X utf8 -I "{runtime.tools.sizes}" --elf "{build.path}/{build.project_name}.elf" --path "{runtime.tools.xtensa-lx106-elf-gcc.path}/bin" --mmu "{build.mmuflags}"
## Save hex
recipe.output.tmp_file={build.project_name}.bin
recipe.output.save_file={build.project_name}.{build.variant}.bin
## Compute size
recipe.size.pattern="{compiler.path}{compiler.size.cmd}" -A "{build.path}/{build.project_name}.elf"
recipe.size.regex=^(?:\.irom0\.text|\.text|\.text1|\.data|\.rodata|)\s+([0-9]+).*
recipe.size.regex.data=^(?:\.data|\.rodata|\.bss)\s+([0-9]+).*
#recipe.size.regex.eeprom=^(?:\.eeprom)\s+([0-9]+).*
tools.esptool.path=
# Because the variable expansion doesn't allow one tool to find another, the following lines
# will point to "{runtime.platform.path}/tools/python3/python3" in GIT and
# "{runtime.tools.python3.path}/python3" for JSON board manager releases.
tools.esptool.cmd={runtime.tools.python3.path}/python3
tools.esptool.network_cmd={runtime.tools.python3.path}/python3
tools.esptool.upload.protocol=esp
# esptool.py --trace option is a debug option, not a verbose option
tools.esptool.upload.params.verbose=
tools.esptool.upload.params.quiet=
# First, potentially perform an erase or nothing
# Next, do the binary upload
# Combined in one rule because Arduino doesn't support upload.1.pattern/upload.3.pattern
tools.esptool.upload.pattern="{cmd}" -I "{runtime.platform.path}/tools/upload.py" --chip esp8266 --port "{serial.port}" --baud "{upload.speed}" "{upload.verbose}" {upload.erase_cmd} {upload.resetmethod} write_flash 0x0 "{build.path}/{build.project_name}.bin"
tools.esptool.upload.network_pattern="{network_cmd}" -I "{runtime.platform.path}/tools/espota.py" -i "{serial.port}" -p "{network.port}" "--auth={network.password}" -f "{build.path}/{build.project_name}.bin"
tools.mkspiffs.cmd=mkspiffs
tools.mkspiffs.cmd.windows=mkspiffs.exe
tools.mkspiffs.path={runtime.tools.mkspiffs.path}
tools.mklittlefs.cmd=mklittlefs
tools.mklittlefs.cmd.windows=mklittlefs.exe
tools.mklittlefs.path={runtime.platform.path}/tools/mklittlefs
Cerca le righe che ti ho indicato e prova ad eliminare solo quella parte ... vediamo che succede ...
Guglielmo
ok provo
NO.... niente da fare , ho eliminato quello che hai detto ma il problema persiste ![]()
Mostra gli errori ... ed il file modificato.
Guglielmo
# ESP8266 platform
# For more info:
version=3.1.2
build.sslflags=
build.mmuflags=
build.led=
build.eeprom_start=
build.spiffs_start=
build.spiffs_end=
compiler.c.flags=-c "{compiler.warning_flags}-cflags" -std=gnu17 {build.stacksmash_flags} -Os -g -free -fipa-pta -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -ffunction-sections -fdata-sections {build.exception_flags} {build.sslflags} {build.mmuflags} {build.non32xferflags}
compiler.cpp.flags=-c "{compiler.warning_flags}-cppflags" {build.stacksmash_flags} -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 {build.stdcpp_level} -MMD -ffunction-sections -fdata-sections {build.exception_flags} {build.sslflags} {build.mmuflags} {build.non32xferflags}
build.extra_flags=
## needs git
## Compile c files
## Compile S files
## Create archives
## Create eeprom
## Create hex
## Save hex
## Compute size
tools.esptool.path=
Un'altra cosa ... ti dice chiaramente di andare nelle "preferenze" dell'IDE ed abilitare il "verbose" nella compilazione per avere più dettagli ...
In pratica, vai nelle preferenze del IDE e metti il segno di spunta nei due box per avere più dettagli sia in fase di compilazione che in fase di caricamento ... così i messaggi di errore saranno piû specifici.
Guglielmo
faccio subito
F:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware F:\Program Files (x86)\Arduino\hardware -hardware F:\Users\Michele\AppData\Local\Arduino15\packages -tools F:\Program Files (x86)\Arduino\tools-builder -tools F:\Program Files (x86)\Arduino\hardware\tools\avr -tools F:\Users\Michele\AppData\Local\Arduino15\packages -built-in-libraries F:\Program Files (x86)\Arduino\libraries -libraries F:\Users\Michele\Documents\Arduino\libraries -fqbn=esp8266:esp8266:nodemcu:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,eesz=4M2M,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -vid-pid=2A03_0043 -ide-version=10819 -build-path F:\Users\Michele\AppData\Local\Temp\arduino_build_894937 -warnings=none -build-cache F:\Users\Michele\AppData\Local\Temp\arduino_cache_52645 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=F:\Users\Michele\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.mkspiffs-3.1.0-gcc10.3-e5f9fec.path=F:\Users\Michele\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.mklittlefs.path=F:\Users\Michele\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.mklittlefs-3.1.0-gcc10.3-e5f9fec.path=F:\Users\Michele\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.python3.path=F:\Users\Michele\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=F:\Users\Michele\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=F:\Users\Michele\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.1.0-gcc10.3-e5f9fec.path=F:\Users\Michele\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec -verbose F:\Users\Michele\Documents\Arduino\MARK_IV\mark_IV_esp8266\mark_IV_esp8266.ino
F:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware F:\Program Files (x86)\Arduino\hardware -hardware F:\Users\Michele\AppData\Local\Arduino15\packages -tools F:\Program Files (x86)\Arduino\tools-builder -tools F:\Program Files (x86)\Arduino\hardware\tools\avr -tools F:\Users\Michele\AppData\Local\Arduino15\packages -built-in-libraries F:\Program Files (x86)\Arduino\libraries -libraries F:\Users\Michele\Documents\Arduino\libraries -fqbn=esp8266:esp8266:nodemcu:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,eesz=4M2M,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -vid-pid=2A03_0043 -ide-version=10819 -build-path F:\Users\Michele\AppData\Local\Temp\arduino_build_894937 -warnings=none -build-cache F:\Users\Michele\AppData\Local\Temp\arduino_cache_52645 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=F:\Users\Michele\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.mkspiffs-3.1.0-gcc10.3-e5f9fec.path=F:\Users\Michele\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.mklittlefs.path=F:\Users\Michele\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.mklittlefs-3.1.0-gcc10.3-e5f9fec.path=F:\Users\Michele\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.python3.path=F:\Users\Michele\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=F:\Users\Michele\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=F:\Users\Michele\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.1.0-gcc10.3-e5f9fec.path=F:\Users\Michele\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.1.0-gcc10.3-e5f9fec -verbose F:\Users\Michele\Documents\Arduino\MARK_IV\mark_IV_esp8266\mark_IV_esp8266.ino
Using board 'nodemcu' from platform in folder: F:\Users\Michele\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2
Using core 'esp8266' from platform in folder: F:\Users\Michele\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2
"F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" -I "F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/mkbuildoptglobals.py" "F:\\Program Files (x86)\\Arduino" 10819 "F:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937" "F:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core/build.opt" "F:\\Users\\Michele\\Documents\\Arduino\\MARK_IV\\mark_IV_esp8266/mark_IV_esp8266.ino.globals.h" "F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266/CommonHFile.h"
default_encoding: cp1252
Assume aggressive 'core.a' caching enabled.
Note: optional global include file 'F:\Users\Michele\Documents\Arduino\MARK_IV\mark_IV_esp8266\mark_IV_esp8266.ino.globals.h' does not exist.
Read more at https://arduino-esp8266.readthedocs.io/en/latest/faq/a06-global-build-options.html
Detecting libraries used...
"F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@F:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core/build.opt" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IF:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core" -c "@F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12\"" "-DARDUINO_BOARD_ID=\"nodemcu\"" -DFLASHMODE_QIO "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "F:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937\\sketch\\mark_IV_esp8266.ino.cpp" -o nul
Alternatives for Nextion.h: [ITEADLIB_Arduino_Nextion-master]
ResolveLibrary(Nextion.h)
-> candidates: [ITEADLIB_Arduino_Nextion-master]
"F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@F:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core/build.opt" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IF:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core" -c "@F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12\"" "-DARDUINO_BOARD_ID=\"nodemcu\"" -DFLASHMODE_QIO "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-IF:\\Program Files (x86)\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "F:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937\\sketch\\mark_IV_esp8266.ino.cpp" -o nul
Alternatives for Encoder.h: [Encoder-1.4.2@1.4.2]
ResolveLibrary(Encoder.h)
-> candidates: [Encoder-1.4.2@1.4.2]
"F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@F:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core/build.opt" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IF:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core" -c "@F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12\"" "-DARDUINO_BOARD_ID=\"nodemcu\"" -DFLASHMODE_QIO "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-IF:\\Program Files (x86)\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "-IF:\\Program Files (x86)\\Arduino\\libraries\\Encoder-1.4.2" "F:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937\\sketch\\mark_IV_esp8266.ino.cpp" -o nul
Alternatives for EasyNextionLibrary.h: [EasyNextionLibrary-master@1.0.6]
ResolveLibrary(EasyNextionLibrary.h)
-> candidates: [EasyNextionLibrary-master@1.0.6]
"F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@F:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core/build.opt" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IF:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core" -c "@F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12\"" "-DARDUINO_BOARD_ID=\"nodemcu\"" -DFLASHMODE_QIO "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-IF:\\Program Files (x86)\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "-IF:\\Program Files (x86)\\Arduino\\libraries\\Encoder-1.4.2" "-IF:\\Program Files (x86)\\Arduino\\libraries\\EasyNextionLibrary-master\\src" "F:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937\\sketch\\mark_IV_esp8266.ino.cpp" -o nul
Using cached library dependencies for file: F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexButton.cpp
Using cached library dependencies for file: F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexCheckbox.cpp
Using cached library dependencies for file: F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexCrop.cpp
Using cached library dependencies for file: F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexDualStateButton.cpp
Using cached library dependencies for file: F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexGauge.cpp
Using cached library dependencies for file: F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexGpio.cpp
Using cached library dependencies for file: F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexHardware.cpp
Using cached library dependencies for file: F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexHotspot.cpp
Using cached library dependencies for file: F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexNumber.cpp
Using cached library dependencies for file: F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexObject.cpp
Using cached library dependencies for file: F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexPage.cpp
Using cached library dependencies for file: F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexPicture.cpp
Using cached library dependencies for file: F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexProgressBar.cpp
Using cached library dependencies for file: F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexRadio.cpp
Using cached library dependencies for file: F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexRtc.cpp
Using cached library dependencies for file: F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexScrolltext.cpp
Using cached library dependencies for file: F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexSlider.cpp
Using cached library dependencies for file: F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexText.cpp
Using cached library dependencies for file: F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexTimer.cpp
Using cached library dependencies for file: F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexTouch.cpp
"F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@F:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core/build.opt" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IF:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core" -c "@F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12\"" "-DARDUINO_BOARD_ID=\"nodemcu\"" -DFLASHMODE_QIO "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-IF:\\Program Files (x86)\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "-IF:\\Program Files (x86)\\Arduino\\libraries\\Encoder-1.4.2" "-IF:\\Program Files (x86)\\Arduino\\libraries\\EasyNextionLibrary-master\\src" "F:\\Program Files (x86)\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master\\NexUpload.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
"F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@F:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core/build.opt" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IF:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core" -c "@F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12\"" "-DARDUINO_BOARD_ID=\"nodemcu\"" -DFLASHMODE_QIO "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-IF:\\Program Files (x86)\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "-IF:\\Program Files (x86)\\Arduino\\libraries\\Encoder-1.4.2" "-IF:\\Program Files (x86)\\Arduino\\libraries\\EasyNextionLibrary-master\\src" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SPI" "F:\\Program Files (x86)\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master\\NexUpload.cpp" -o nul
Alternatives for SD.h: [SD@1.2.4 SD_SD@2.0.0]
ResolveLibrary(SD.h)
-> candidates: [SD@1.2.4 SD_SD@2.0.0]
"F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@F:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core/build.opt" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IF:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core" -c "@F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12\"" "-DARDUINO_BOARD_ID=\"nodemcu\"" -DFLASHMODE_QIO "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-IF:\\Program Files (x86)\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "-IF:\\Program Files (x86)\\Arduino\\libraries\\Encoder-1.4.2" "-IF:\\Program Files (x86)\\Arduino\\libraries\\EasyNextionLibrary-master\\src" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SPI" "-IF:\\Program Files (x86)\\Arduino\\libraries\\SD\\src" "F:\\Program Files (x86)\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master\\NexUpload.cpp" -o nul
Alternatives for SoftwareSerial.h: [SoftwareSerial@8.0.1]
ResolveLibrary(SoftwareSerial.h)
-> candidates: [SoftwareSerial@8.0.1]
"F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@F:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core/build.opt" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IF:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core" -c "@F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12\"" "-DARDUINO_BOARD_ID=\"nodemcu\"" -DFLASHMODE_QIO "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-IF:\\Program Files (x86)\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "-IF:\\Program Files (x86)\\Arduino\\libraries\\Encoder-1.4.2" "-IF:\\Program Files (x86)\\Arduino\\libraries\\EasyNextionLibrary-master\\src" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SPI" "-IF:\\Program Files (x86)\\Arduino\\libraries\\SD\\src" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SoftwareSerial\\src" "F:\\Program Files (x86)\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master\\NexUpload.cpp" -o nul
Error while detecting libraries included by F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexUpload.cpp
Using cached library dependencies for file: F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexVariable.cpp
Using cached library dependencies for file: F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexWaveform.cpp
"F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@F:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core/build.opt" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IF:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core" -c "@F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12\"" "-DARDUINO_BOARD_ID=\"nodemcu\"" -DFLASHMODE_QIO "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-IF:\\Program Files (x86)\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "-IF:\\Program Files (x86)\\Arduino\\libraries\\Encoder-1.4.2" "-IF:\\Program Files (x86)\\Arduino\\libraries\\EasyNextionLibrary-master\\src" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SPI" "-IF:\\Program Files (x86)\\Arduino\\libraries\\SD\\src" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SoftwareSerial\\src" "-IF:\\Program Files (x86)\\Arduino\\libraries\\Encoder-1.4.2\\utility" "F:\\Program Files (x86)\\Arduino\\libraries\\Encoder-1.4.2\\Encoder.cpp" -o nul
"F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@F:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core/build.opt" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IF:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core" -c "@F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12\"" "-DARDUINO_BOARD_ID=\"nodemcu\"" -DFLASHMODE_QIO "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-IF:\\Program Files (x86)\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "-IF:\\Program Files (x86)\\Arduino\\libraries\\Encoder-1.4.2" "-IF:\\Program Files (x86)\\Arduino\\libraries\\EasyNextionLibrary-master\\src" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SPI" "-IF:\\Program Files (x86)\\Arduino\\libraries\\SD\\src" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SoftwareSerial\\src" "F:\\Program Files (x86)\\Arduino\\libraries\\EasyNextionLibrary-master\\src\\EasyNextionLibrary.cpp" -o nul
"F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@F:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core/build.opt" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IF:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core" -c "@F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12\"" "-DARDUINO_BOARD_ID=\"nodemcu\"" -DFLASHMODE_QIO "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-IF:\\Program Files (x86)\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "-IF:\\Program Files (x86)\\Arduino\\libraries\\Encoder-1.4.2" "-IF:\\Program Files (x86)\\Arduino\\libraries\\EasyNextionLibrary-master\\src" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SPI" "-IF:\\Program Files (x86)\\Arduino\\libraries\\SD\\src" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SoftwareSerial\\src" "F:\\Program Files (x86)\\Arduino\\libraries\\EasyNextionLibrary-master\\src\\callTriggers.cpp" -o nul
"F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@F:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core/build.opt" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IF:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core" -c "@F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12\"" "-DARDUINO_BOARD_ID=\"nodemcu\"" -DFLASHMODE_QIO "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-IF:\\Program Files (x86)\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "-IF:\\Program Files (x86)\\Arduino\\libraries\\Encoder-1.4.2" "-IF:\\Program Files (x86)\\Arduino\\libraries\\EasyNextionLibrary-master\\src" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SPI" "-IF:\\Program Files (x86)\\Arduino\\libraries\\SD\\src" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SoftwareSerial\\src" "F:\\Program Files (x86)\\Arduino\\libraries\\EasyNextionLibrary-master\\src\\readCustomCommands.cpp" -o nul
"F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@F:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core/build.opt" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IF:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core" -c "@F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12\"" "-DARDUINO_BOARD_ID=\"nodemcu\"" -DFLASHMODE_QIO "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-IF:\\Program Files (x86)\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "-IF:\\Program Files (x86)\\Arduino\\libraries\\Encoder-1.4.2" "-IF:\\Program Files (x86)\\Arduino\\libraries\\EasyNextionLibrary-master\\src" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SPI" "-IF:\\Program Files (x86)\\Arduino\\libraries\\SD\\src" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SoftwareSerial\\src" "F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SPI\\SPI.cpp" -o nul
"F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@F:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core/build.opt" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IF:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core" -c "@F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12\"" "-DARDUINO_BOARD_ID=\"nodemcu\"" -DFLASHMODE_QIO "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-IF:\\Program Files (x86)\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "-IF:\\Program Files (x86)\\Arduino\\libraries\\Encoder-1.4.2" "-IF:\\Program Files (x86)\\Arduino\\libraries\\EasyNextionLibrary-master\\src" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SPI" "-IF:\\Program Files (x86)\\Arduino\\libraries\\SD\\src" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SoftwareSerial\\src" "F:\\Program Files (x86)\\Arduino\\libraries\\SD\\src\\File.cpp" -o nul
Error while detecting libraries included by F:\Program Files (x86)\Arduino\libraries\SD\src\File.cpp
"F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@F:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core/build.opt" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IF:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core" -c "@F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12\"" "-DARDUINO_BOARD_ID=\"nodemcu\"" -DFLASHMODE_QIO "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-IF:\\Program Files (x86)\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "-IF:\\Program Files (x86)\\Arduino\\libraries\\Encoder-1.4.2" "-IF:\\Program Files (x86)\\Arduino\\libraries\\EasyNextionLibrary-master\\src" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SPI" "-IF:\\Program Files (x86)\\Arduino\\libraries\\SD\\src" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SoftwareSerial\\src" "F:\\Program Files (x86)\\Arduino\\libraries\\SD\\src\\SD.cpp" -o nul
Error while detecting libraries included by F:\Program Files (x86)\Arduino\libraries\SD\src\SD.cpp
"F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@F:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core/build.opt" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IF:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core" -c "@F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12\"" "-DARDUINO_BOARD_ID=\"nodemcu\"" -DFLASHMODE_QIO "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-IF:\\Program Files (x86)\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "-IF:\\Program Files (x86)\\Arduino\\libraries\\Encoder-1.4.2" "-IF:\\Program Files (x86)\\Arduino\\libraries\\EasyNextionLibrary-master\\src" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SPI" "-IF:\\Program Files (x86)\\Arduino\\libraries\\SD\\src" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SoftwareSerial\\src" "F:\\Program Files (x86)\\Arduino\\libraries\\SD\\src\\utility\\Sd2Card.cpp" -o nul
Error while detecting libraries included by F:\Program Files (x86)\Arduino\libraries\SD\src\utility\Sd2Card.cpp
"F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@F:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core/build.opt" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IF:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core" -c "@F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12\"" "-DARDUINO_BOARD_ID=\"nodemcu\"" -DFLASHMODE_QIO "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-IF:\\Program Files (x86)\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "-IF:\\Program Files (x86)\\Arduino\\libraries\\Encoder-1.4.2" "-IF:\\Program Files (x86)\\Arduino\\libraries\\EasyNextionLibrary-master\\src" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SPI" "-IF:\\Program Files (x86)\\Arduino\\libraries\\SD\\src" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SoftwareSerial\\src" "F:\\Program Files (x86)\\Arduino\\libraries\\SD\\src\\utility\\SdFile.cpp" -o nul
Error while detecting libraries included by F:\Program Files (x86)\Arduino\libraries\SD\src\utility\SdFile.cpp
"F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@F:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core/build.opt" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IF:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core" -c "@F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12\"" "-DARDUINO_BOARD_ID=\"nodemcu\"" -DFLASHMODE_QIO "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-IF:\\Program Files (x86)\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "-IF:\\Program Files (x86)\\Arduino\\libraries\\Encoder-1.4.2" "-IF:\\Program Files (x86)\\Arduino\\libraries\\EasyNextionLibrary-master\\src" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SPI" "-IF:\\Program Files (x86)\\Arduino\\libraries\\SD\\src" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SoftwareSerial\\src" "F:\\Program Files (x86)\\Arduino\\libraries\\SD\\src\\utility\\SdVolume.cpp" -o nul
Error while detecting libraries included by F:\Program Files (x86)\Arduino\libraries\SD\src\utility\SdVolume.cpp
"F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@F:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core/build.opt" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IF:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core" -c "@F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12\"" "-DARDUINO_BOARD_ID=\"nodemcu\"" -DFLASHMODE_QIO "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-IF:\\Program Files (x86)\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "-IF:\\Program Files (x86)\\Arduino\\libraries\\Encoder-1.4.2" "-IF:\\Program Files (x86)\\Arduino\\libraries\\EasyNextionLibrary-master\\src" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SPI" "-IF:\\Program Files (x86)\\Arduino\\libraries\\SD\\src" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SoftwareSerial\\src" "F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SoftwareSerial\\src\\SoftwareSerial.cpp" -o nul
Generating function prototypes...
"F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@F:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core/build.opt" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IF:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core" -c "@F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12\"" "-DARDUINO_BOARD_ID=\"nodemcu\"" -DFLASHMODE_QIO "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-IF:\\Program Files (x86)\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "-IF:\\Program Files (x86)\\Arduino\\libraries\\Encoder-1.4.2" "-IF:\\Program Files (x86)\\Arduino\\libraries\\EasyNextionLibrary-master\\src" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SPI" "-IF:\\Program Files (x86)\\Arduino\\libraries\\SD\\src" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SoftwareSerial\\src" "F:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937\\sketch\\mark_IV_esp8266.ino.cpp" -o "F:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"F:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "F:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" -I "F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/signing.py" --mode header --publickey "F:\\Users\\Michele\\Documents\\Arduino\\MARK_IV\\mark_IV_esp8266/public.key" --out "F:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core/Updater_Signing.h"
"F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@F:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core/build.opt" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IF:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core" -c "@F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12\"" "-DARDUINO_BOARD_ID=\"nodemcu\"" -DFLASHMODE_QIO "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-IF:\\Program Files (x86)\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "-IF:\\Program Files (x86)\\Arduino\\libraries\\Encoder-1.4.2" "-IF:\\Program Files (x86)\\Arduino\\libraries\\EasyNextionLibrary-master\\src" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SPI" "-IF:\\Program Files (x86)\\Arduino\\libraries\\SD\\src" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SoftwareSerial\\src" "F:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937\\sketch\\mark_IV_esp8266.ino.cpp" -o "F:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937\\sketch\\mark_IV_esp8266.ino.cpp.o"
Compiling libraries...
Compiling library "ITEADLIB_Arduino_Nextion-master"
Using previously compiled file: F:\Users\Michele\AppData\Local\Temp\arduino_build_894937\libraries\ITEADLIB_Arduino_Nextion-master\NexButton.cpp.o
Using previously compiled file: F:\Users\Michele\AppData\Local\Temp\arduino_build_894937\libraries\ITEADLIB_Arduino_Nextion-master\NexDualStateButton.cpp.o
Using previously compiled file: F:\Users\Michele\AppData\Local\Temp\arduino_build_894937\libraries\ITEADLIB_Arduino_Nextion-master\NexCheckbox.cpp.o
Using previously compiled file: F:\Users\Michele\AppData\Local\Temp\arduino_build_894937\libraries\ITEADLIB_Arduino_Nextion-master\NexCrop.cpp.o
Using previously compiled file: F:\Users\Michele\AppData\Local\Temp\arduino_build_894937\libraries\ITEADLIB_Arduino_Nextion-master\NexHotspot.cpp.o
Using previously compiled file: F:\Users\Michele\AppData\Local\Temp\arduino_build_894937\libraries\ITEADLIB_Arduino_Nextion-master\NexHardware.cpp.o
Using previously compiled file: F:\Users\Michele\AppData\Local\Temp\arduino_build_894937\libraries\ITEADLIB_Arduino_Nextion-master\NexGauge.cpp.o
Using previously compiled file: F:\Users\Michele\AppData\Local\Temp\arduino_build_894937\libraries\ITEADLIB_Arduino_Nextion-master\NexGpio.cpp.o
Using previously compiled file: F:\Users\Michele\AppData\Local\Temp\arduino_build_894937\libraries\ITEADLIB_Arduino_Nextion-master\NexNumber.cpp.o
Using previously compiled file: F:\Users\Michele\AppData\Local\Temp\arduino_build_894937\libraries\ITEADLIB_Arduino_Nextion-master\NexPage.cpp.o
Using previously compiled file: F:\Users\Michele\AppData\Local\Temp\arduino_build_894937\libraries\ITEADLIB_Arduino_Nextion-master\NexPicture.cpp.o
Using previously compiled file: F:\Users\Michele\AppData\Local\Temp\arduino_build_894937\libraries\ITEADLIB_Arduino_Nextion-master\NexObject.cpp.o
Using previously compiled file: F:\Users\Michele\AppData\Local\Temp\arduino_build_894937\libraries\ITEADLIB_Arduino_Nextion-master\NexRtc.cpp.o
Using previously compiled file: F:\Users\Michele\AppData\Local\Temp\arduino_build_894937\libraries\ITEADLIB_Arduino_Nextion-master\NexScrolltext.cpp.o
Using previously compiled file: F:\Users\Michele\AppData\Local\Temp\arduino_build_894937\libraries\ITEADLIB_Arduino_Nextion-master\NexRadio.cpp.o
Using previously compiled file: F:\Users\Michele\AppData\Local\Temp\arduino_build_894937\libraries\ITEADLIB_Arduino_Nextion-master\NexText.cpp.o
Using previously compiled file: F:\Users\Michele\AppData\Local\Temp\arduino_build_894937\libraries\ITEADLIB_Arduino_Nextion-master\NexTouch.cpp.o
Using previously compiled file: F:\Users\Michele\AppData\Local\Temp\arduino_build_894937\libraries\ITEADLIB_Arduino_Nextion-master\NexProgressBar.cpp.o
Using previously compiled file: F:\Users\Michele\AppData\Local\Temp\arduino_build_894937\libraries\ITEADLIB_Arduino_Nextion-master\NexTimer.cpp.o
"F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@F:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core/build.opt" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IF:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937/core" -c "@F:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_NODEMCU_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12\"" "-DARDUINO_BOARD_ID=\"nodemcu\"" -DFLASHMODE_QIO "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-IF:\\Program Files (x86)\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "-IF:\\Program Files (x86)\\Arduino\\libraries\\Encoder-1.4.2" "-IF:\\Program Files (x86)\\Arduino\\libraries\\EasyNextionLibrary-master\\src" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SPI" "-IF:\\Program Files (x86)\\Arduino\\libraries\\SD\\src" "-IF:\\Users\\Michele\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\SoftwareSerial\\src" "F:\\Program Files (x86)\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master\\NexUpload.cpp" -o "F:\\Users\\Michele\\AppData\\Local\\Temp\\arduino_build_894937\\libraries\\ITEADLIB_Arduino_Nextion-master\\NexUpload.cpp.o"
Using previously compiled file: F:\Users\Michele\AppData\Local\Temp\arduino_build_894937\libraries\ITEADLIB_Arduino_Nextion-master\NexWaveform.cpp.o
Using previously compiled file: F:\Users\Michele\AppData\Local\Temp\arduino_build_894937\libraries\ITEADLIB_Arduino_Nextion-master\NexVariable.cpp.o
Using previously compiled file: F:\Users\Michele\AppData\Local\Temp\arduino_build_894937\libraries\ITEADLIB_Arduino_Nextion-master\NexSlider.cpp.o
In file included from F:\Program Files (x86)\Arduino\libraries\SD\src/utility/Sd2Card.h:26,
from F:\Program Files (x86)\Arduino\libraries\SD\src/utility/SdFat.h:29,
from F:\Program Files (x86)\Arduino\libraries\SD\src/SD.h:20,
from F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexUpload.h:20,
from F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexUpload.cpp:16:
F:\Program Files (x86)\Arduino\libraries\SD\src/utility/Sd2PinMap.h:524:2: error: #error Architecture or board not supported.
524 | #error Architecture or board not supported.
F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexUpload.cpp: In member function 'bool NexUpload::_downloadTftFile()':
F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master\NexUpload.cpp:197:30: warning: control reaches end of non-void function [-Wreturn-type]
197 | String string = String("");
Multiple libraries were found for "SD.h"
Used: F:\Program Files (x86)\Arduino\libraries\SD
Not used: F:\Users\Michele\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SD_SD
Using library ITEADLIB_Arduino_Nextion-master in folder: F:\Program Files (x86)\Arduino\libraries\ITEADLIB_Arduino_Nextion-master (legacy)
Using library Encoder-1.4.2 at version 1.4.2 in folder: F:\Program Files (x86)\Arduino\libraries\Encoder-1.4.2
Using library EasyNextionLibrary-master at version 1.0.6 in folder: F:\Program Files (x86)\Arduino\libraries\EasyNextionLibrary-master
Using library SPI at version 1.0 in folder: F:\Users\Michele\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SPI
Using library SD at version 1.2.4 in folder: F:\Program Files (x86)\Arduino\libraries\SD
Using library SoftwareSerial at version 8.0.1 in folder: F:\Users\Michele\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SoftwareSerial
exit status 1
Error compiling for board NodeMCU 0.9 (ESP-12 Module).
