Errors in my code...HELP! (32 note organ pedalboard using Arduino Mega)
I am a cellist and organist and I am trying to convert a 32-note organ pedal board to MIDI for practice at home. I am using the book “MIDI and ARDUINO: organ bass pedal encoders” by Tom Scarff. I plan to use an ARDUINO Mega 2560 and a MIDI board. I don’t know anything about entering or programming code. I haven’t bought the ARDUINO board, so it is not connected to my laptop yet. I hope this time I correctly followed the rules of this forum. After entering the whole program and verifying I get the following error messages:
C:\Users\macon\OneDrive\Documents\Arduino\Arduino12345678\Arduino12345678.ino: In function 'void loop()':
C:\Users\macon\OneDrive\Documents\Arduino\Arduino12345678\Arduino12345678.ino:103:7: error: 'noteOff' was not declared in this scope
noteOff(MIDIchannel, note, velocity);
C:\Users\macon\OneDrive\Documents\Arduino\Arduino12345678\Arduino12345678.ino:103:7: note: suggested alternative: 'noteff'
noteff
exit status 1
Compilation error: 'noteOff' was not declared in this scope
Here is my code:
#include <MIDI.h>
//PROGRAM: A design with an 32 switch encoder circuit, to produce Bass pedal outputs,
//with Octave UP/DOWN switches.
//variables setup
int octave = 0;
int midiByte;
byte MIDIchannel = 2;  // midi channel 3
byte channel;
byte x;
byte LedPin = 13;  // select the pin for the LED
byte count;
byte note;
byte velocity = 100;
byte currentSwitch = 0;
int startNote = 36;
//32 bass switches + octave and Channel up + octave down switches = 36 switch inputs-
byte switches[36] = {
  22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 8, 9, 10, 11
byte switchState[36] = {
  0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  //GND 0 Volt supply to opto-coupler
  digitalWrite(3, LOW);
  // +5 Volt supply to opto-coupler
  digitalWrite(2, HIGH);
  //Set Inputs for 4 way DIP Switch
  pinMode(4, INPUT_PULLUP);
  pinMode(5, INPUT_PULLUP);
  pinMode(6, INPUT_PULLUP);
  pinMode(7, INPUT_PULLUP);
  //Set Inputs for Octave up/down Switches
  pinMode(8, INPUT_PULLUP);
  pinMode(9, INPUT_PULLUP);
  //Set Inputs for Channel up/down Switches
  pinMode(10, INPUT_PULLUP);
  pinMode(11, INPUT_PULLUP);
  //pins 22 to 53 corresponding to switches 1 to 32
  for (x = 22; x < 54; x++) {
    pinMode(x, INPUT);
    digitalWrite(x, HIGH);
  //declare the LED's pin as output
  pinMode(LedPin, OUTPUT);
  for (x = 1; x <= 4; x++) {
    digitalWrite(LedPin, HIGH);
    delay(300);
    digitalWrite(LedPin, LOW);
    delay(300);
  //start serial with midi baudrate 31250
  Serial.begin(31250);
  Serial.flush();
  //Read 4-Way DIP switch
  MIDIchannel = digitalRead(4) + (digitalRead(5) << 1) + (digitalRead(6) << 2) + (digitalRead(7 << 3));
  MIDIchannel + MIDIchannel + 1;
#include <MIDI.h>
  MIDI_CREATE_DEFAULT_INSTANCE();
  MIDI.begin(MIDI_CHANNEL_OMNI);
  //scan 32 switches on inputs
  for (int n = 0; n < 32; n++) {
    currentSwitch = digitalRead(switches[n]);
    //switch pressed and NOT pressed previously
    if (currentSwitch == LOW && switchState[n] == LOW) {
      switchState[n] = HIGH;
      note = n;
      noteOn(MIDIchannel, note, velocity);
    // switch released AND pressed previosly
    if (currentSwitch == HIGH && switchState[n] == HIGH) {
      switchState[n] = LOW;
      note = n;
  //scan 2 Octave and Channel switches on inputs
  for (int n = 32; n < 36; n++) {
    // switch pressed and NOT pressed previosly
      if (n == 32) {
        octave = octave + 12;
        if (octave >= 12) {
          octave = 12;
      if (n == 33) {
        octave = octave - 12;
        if (octave <= -12) {
          octave = -12;
      if (n == 34) {
        MIDIchannel = MIDIchannel + 1;
        if (MIDIchannel >= 15) {
          MIDIchannel = 15;
      if (n == 35) {
        MIDIchannel = MIDIchannel - 1;
        if (MIDIchannel <= 0) {
          MIDIchannel = 0;
  delay(20);
//Send a MIDI note-on message.
void noteOn(byte channel, byte note, byte velocity) {
  midiMsg((0x90 + channel), note + startNote + octave,
          velocity);
//Send a MIDI note-off message.
void noteff(byte channel, byte note, byte velocity) {
  midiMsg((0x80 + channel), note + startNote + octave,
          velocity);
//Send a general MIDI message
void midiMsg(byte cmd, byte data1, byte data2) {
  Serial.write(cmd);
  Serial.write(data1);
  Serial.write(data2);
The compiler is quite unforgiving about spelling mistakes. However, it is equally helpful in pointing them out and suggesting what you might correct.
