Help with Errors in code for using Arduino Mega as MIDI encoder
I am a cellist and organist and I am trying to convert a 32 note organ pedal board to MIDI for practice at home. I am using the book “MIDI and ARDUINO: organ bass pedal encoders” by Tom Scarff. I plan to use an ARDUINO Mega 2560. I don’t know anything about entering or programming code. I haven’t bought the ARDUINO so it is not connected to my laptop yet. After entering the whole program and verifying I get the following error messages:
C:\Users\macon\OneDrive\Documents\Arduino\Arduino12345\Arduino12345.ino: In function 'void loop()':
C:\Users\macon\OneDrive\Documents\Arduino\Arduino12345\Arduino12345.ino:79:5: error: 'noteOff' was not declared in this scope
noteOff(MIDIchannel,note,velocity);
C:\Users\macon\OneDrive\Documents\Arduino\Arduino12345\Arduino12345.ino:79:5: note: suggested alternative: 'noteff'
noteff
C:\Users\macon\OneDrive\Documents\Arduino\Arduino12345\Arduino12345.ino: In function 'void noteOn(byte, byte, byte)':
C:\Users\macon\OneDrive\Documents\Arduino\Arduino12345\Arduino12345.ino:138:19: error: lvalue required as left operand of assignment
midiMsg((0x90 = channel), note + startNote + octave,
exit status 1
Compilation error: 'noteOff' was not declared in this scope
This is how I entered the program:
//PROGRAM: A design with an 32 switch encoder circuit, to produce Bass pedal outputs,
//with Octave UP/DOWN switches.
//variables setup
int octave = 0;
int midiByte;
byte MIDIchannel = 2;// midi channel 3
byte channel;
byte x;
byte LedPin = 13; // select the pin for the LED
byte count;
byte note;
byte velocity = 100;
byte currentSwitch = 0;
int startNote = 36;
//32 bass switches + octave and Channel up + octave down switches = 36 switch inputs-
byte switches[36] = {
22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,8,9,10,11
byte switchState[36] = {
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
void setup(){
//Set Inputs for Octave up/down Switches
pinMode(8, INPUT_PULLUP);
pinMode(9, INPUT_PULLUP);
//Set Inputs for Channel up/down Switches
pinMode(10, INPUT_PULLUP);
pinMode(11, INPUT_PULLUP);
//pins 22 to 53 corresponding to switches 1 to 32
for (x = 22;x < 54;x++){
pinMode(x, INPUT);
digitalWrite(x, HIGH);
//declare the LED's pin as output
pinMode(LedPin, OUTPUT);
for (x = 1; x <= 4;x++){
digitalWrite( LedPin, HIGH );
delay(300);
digitalWrite( LedPin, LOW );
delay(300);
//start serial with midi baudrate 31250
Serial.begin(31250);
Serial.flush();
void loop(){
//scan 32 switches on inputs
for (int n = 0;n < 32;n++) {
currentSwitch = digitalRead(switches[n]);
//switch pressed and NOT pressed previously
if (currentSwitch == LOW &&switchState[n] == LOW)
  switchState[n] = HIGH;
  note = n;
  noteOn(MIDIchannel, note, velocity);
// switch released AND pressed previosly
if ( currentSwitch == HIGH && switchState[n] ==
HIGH){
switchState[n] = LOW;
note = n;
//scan 2 Octave and Channel switches on inputs
for (int n = 32;n < 36; n++){
  // switch pressed and NOT pressed previosly
  if (currentSwitch == LOW && switchState[n] == LOW)
if (n == 32){
octave = octave + 12;
if (octave >= 12){
octave = 12;
if (n == 33){
octave = octave - 12;
if (octave <= -12){
octave = -12;
if (n == 34){
MIDIchannel = MIDIchannel + 1;
if (MIDIchannel >= 15){
MIDIchannel = 15;
if (n == 35){
MIDIchannel = MIDIchannel - 1;
if (MIDIchannel <= 0){
MIDIchannel = 0;
  if (currentSwitch == HIGH && switchState[n] ==
HIGH){
 delay(20);
//Send a MIDI note-on message.
void noteOn(byte channel, byte note, byte velocity){
velocity);
//Send a MIDI note-off message.
void noteff(byte channel, byte note, byte velocity){
midiMsg((0x80 + channel), note + startNote + octave,
velocity);
//Send a general MIDI message
void midiMsg(byte cmd, byte data1, byte data2)
digitalWrite(LedPin, HIGH);
Serial.write(cmd);
Serial.write(data1);
Serial.write(data2);
digitalWrite(LedPin,LOW);
I am wondering what did I do wrong.
Sincerely
Dr. Juan Jose Gutierrez
You might want to look at this How to get the best out of this forum before you proceed any further.
It tells you how to post code correctly on this forum.
It looks like you haven't installed the libraries correctly.
Welcome to the forum
Your topic has been moved to the Programming Questions category of the forum
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
In my experience the easiest way to tidy up the code and add the code tags is as follows
Start by tidying up your code by using Tools/Auto Format in the IDE to make it easier to read. Then use Edit/Copy for Forum and paste what was copied in a new reply. Code tags will have been added to the code to make it easy to read in the forum thus making it easier to provide help.
