Hi.
I've just started trying to make my code into a library instead, as that would be easier.
The only problem is, that the code uses the NewSoftSerial library, and I don't know if it's possible for a library to include and use another library!
But anyways, I'm getting alot of errors when i start Arduino (it compiles the new library)
So here is my GPU.h file:
GPU.h - Library for Serial GPU.
Created by Thomas Jespersen, May 8, 2009.
Released into the public domain.
#ifndef GPU_h
#define GPU_h
#include "WConstants.h"
class GPU
public:
GPU(int ser1, int ser2, int ledPin);
void Transmit(byte msg);
void ClearTV();
void ChangeType(char type);
void WriteChar(char x, char y, char chr);
void WriteText(char x, char y, char str[])
void Pixel(char x, char y)
private:
int _ledPin;
#endif
And here is my GPU.cpp file:
#include "WProgram.h"
#include "GPU.h"
#include <NewSoftSerial.h>
GPU::GPU(int ser1, int ser2, int ledPin)
NewSoftSerial GPU(ser1,ser2);
GPU.begin(9600);
pinMode(ledPin, OUTPUT);
_ledPin = ledPin;
void GPU::Transmit(byte msg)
byte cnt = 0;
GPU.print(msg, BYTE);
while (true) {
if (GPU.available() > 0) {
incoming = GPU.read();
if (incoming == msg) {
cnt++;
if (cnt >= 10) {
cnt = 0;
delay(1); //Delay to wait for response
void GPU::ClearTV()
//Send "Clear Screen" command
digitalWrite(_ledPin, HIGH); // sets the LED on
Transmit(255);
digitalWrite(_ledPin, LOW); // sets the LED on
while (true) {
if (incoming == 11) {
void GPU::ChangeType(char type)
Transmit(254);
Transmit(type);
while (true) {
void GPU::WriteChar(char x, char y, char chr)
Transmit(x); // X
Transmit(y); // Y
Transmit(chr);
Transmit(13);
while (true) {
void GPU::WriteText(char x, char y, char str[])
int i;
Transmit(x); // X
Transmit(y); // Y
for (i = 0; i <= strlen(str); i++) {
Transmit(str[i]);
Transmit(13);
while (true) {
void GPU::Pixel(char x, char y)
int i;
Transmit(x); // X
Transmit(y); // Y
Transmit(13);
while (true) {
