// CODE STARTS HERE AND THE ERRORS ARE AFTER IT
#include <Arduino_PMIC.h>
#include <ArduinoMotorCarrier.h>
//#include <MKRMotorCarrier.h>
//#include <MKRMotorCarrier_REV2.h>
#define INTERRUPT_PIN 6
//Serial port initialization
//while (!Serial);
//Establishing the communication with the Motor Carrier
if (controller.begin())
Serial.print("Motor Carrier connected, firmware version ");
Serial.println(controller.getFWVersion());
Serial.println("Couldn't connect! Is the red LED blinking? You may need to update the firmware with FWUpdater sketch");
while (1);
// Reboot the motor controller; brings every value back to default
Serial.println("reboot");
controller.reboot();
M1.setDuty(0);
M2.setDuty(0);
M3.setDuty(0);
M4.setDuty(0);
if (!PMIC.enableBoostMode()) {
Serial.println("Error enabling Boost Mode");
//Servo sweep from 0 position to 180
for (int i = 0; i < 180; i += 1)
//Choose which of the servo connectors you want to use: servo1(default), servo2, servo3 or servo4
servo1.setAngle(i);
servo2.setAngle(i);
servo3.setAngle(i);
servo4.setAngle(i);
Serial.print("Servos position");
Serial.println(i);
delay(20);
delay(200);
//Servo sweep from 180 position to 0
for (int i = 180; i > 0; i -= 1)
servo1.setAngle(i);
servo2.setAngle(i);
servo3.setAngle(i);
servo4.setAngle(i);
Serial.print("Servos position: ");
Serial.println(i);
delay(20);
//Keep active the communication between MKR board & MKR Motor Carrier
//Ping the SAMD11
controller.ping();
//wait
delay(50);
// ERRORS START HERE!
Arduino: 1.8.15 (Mac OS X), Board: "Arduino NANO 33 IoT"
In file included from /Users/sanperez/Documents/MATLAB/SupportPackages/R2021a/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/samd21/include/samd21.h:69:0,
from /Users/sanperez/Documents/MATLAB/SupportPackages/R2021a/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/samd.h:105,
from /Users/sanperez/Documents/MATLAB/SupportPackages/R2021a/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.11/cores/arduino/WVariant.h:22,
from /Users/sanperez/Documents/MATLAB/SupportPackages/R2021a/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.11/variants/nano_33_iot/variant.h:25,
from /Users/sanperez/Documents/MATLAB/SupportPackages/R2021a/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.11/libraries/Wire/Wire.h:24,
from /Users/sanperez/Documents/Arduino/libraries/Arduino_BQ24195/src/BQ24195.h:20,
from /Users/sanperez/Documents/Arduino/libraries/Arduino_BQ24195/src/BQ24195.cpp:20:
/Users/sanperez/Documents/MATLAB/SupportPackages/R2021a/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/samd21/include/samd21g18a.h:226:0: warning: "LITTLE_ENDIAN" redefined
#define LITTLE_ENDIAN 1
In file included from /Users/sanperez/Documents/MATLAB/SupportPackages/R2021a/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/arm-none-eabi/include/sys/types.h:67:0,
from /Users/sanperez/Documents/MATLAB/SupportPackages/R2021a/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/arm-none-eabi/include/stdio.h:61,
from /Users/sanperez/Documents/MATLAB/SupportPackages/R2021a/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.11/cores/arduino/api/Print.h:22,
from /Users/sanperez/Documents/MATLAB/SupportPackages/R2021a/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.11/cores/arduino/api/Stream.h:25,
from /Users/sanperez/Documents/MATLAB/SupportPackages/R2021a/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.11/cores/arduino/api/HardwareI2C.h:22,
from /Users/sanperez/Documents/MATLAB/SupportPackages/R2021a/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.11/libraries/Wire/Wire.h:23,
/Users/sanperez/Documents/MATLAB/SupportPackages/R2021a/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/arm-none-eabi/include/machine/endian.h:17:0: note: this is the location of the previous definition
#define LITTLE_ENDIAN _LITTLE_ENDIAN
/Users/sanperez/Documents/Arduino/libraries/Arduino_BQ24195/src/BQ24195.cpp: In member function 'bool PMICClass::begin()':
/Users/sanperez/Documents/Arduino/libraries/Arduino_BQ24195/src/BQ24195.cpp:70:13: error: 'PIN_USB_HOST_ENABLE' was not declared in this scope
pinMode(PIN_USB_HOST_ENABLE, OUTPUT);
/Users/sanperez/Documents/Arduino/libraries/Arduino_BQ24195/src/BQ24195.cpp:70:13: note: suggested alternative: 'REG_USB_HOST_INTFLAG'
/Users/sanperez/Documents/Arduino/libraries/Arduino_BQ24195/src/BQ24195.cpp: In member function 'void PMICClass::end()':
/Users/sanperez/Documents/Arduino/libraries/Arduino_BQ24195/src/BQ24195.cpp:94:13: error: 'PIN_USB_HOST_ENABLE' was not declared in this scope
pinMode(PIN_USB_HOST_ENABLE, INPUT);
/Users/sanperez/Documents/Arduino/libraries/Arduino_BQ24195/src/BQ24195.cpp:94:13: note: suggested alternative: 'REG_USB_HOST_INTFLAG'
/Users/sanperez/Documents/Arduino/libraries/Arduino_BQ24195/src/BQ24195.cpp: In member function 'bool PMICClass::enableCharge()':
/Users/sanperez/Documents/Arduino/libraries/Arduino_BQ24195/src/BQ24195.cpp:110:18: error: 'PIN_USB_HOST_ENABLE' was not declared in this scope
digitalWrite(PIN_USB_HOST_ENABLE, LOW);
/Users/sanperez/Documents/Arduino/libraries/Arduino_BQ24195/src/BQ24195.cpp:110:18: note: suggested alternative: 'REG_USB_HOST_INTFLAG'
/Users/sanperez/Documents/Arduino/libraries/Arduino_BQ24195/src/BQ24195.cpp: In member function 'bool PMICClass::enableBoostMode()':
/Users/sanperez/Documents/Arduino/libraries/Arduino_BQ24195/src/BQ24195.cpp:166:18: error: 'PIN_USB_HOST_ENABLE' was not declared in this scope
/Users/sanperez/Documents/Arduino/libraries/Arduino_BQ24195/src/BQ24195.cpp:166:18: note: suggested alternative: 'REG_USB_HOST_INTFLAG'
/Users/sanperez/Documents/Arduino/libraries/Arduino_BQ24195/src/BQ24195.cpp: In member function 'bool PMICClass::disableBoostMode()':
/Users/sanperez/Documents/Arduino/libraries/Arduino_BQ24195/src/BQ24195.cpp:247:18: error: 'PIN_USB_HOST_ENABLE' was not declared in this scope
digitalWrite(PIN_USB_HOST_ENABLE, HIGH);
/Users/sanperez/Documents/Arduino/libraries/Arduino_BQ24195/src/BQ24195.cpp:247:18: note: suggested alternative: 'REG_USB_HOST_INTFLAG'
exit status 1
Error compiling for board Arduino NANO 33 IoT.
option enabled in File -> Preferences.
// Im getting these weird errors, can anyone help please?
// I am running the nano 33 IoT with the nano motor carrier that came with the engineering kit
// Im running off of my MacBook Pro
Hi, @perezs
Welcome to the forum.
Please read the post at the start of any forum , entitled "How to use this Forum".
This will help with advice on how to present your code and problems.
Thanks.. Tom...
