You can control its speed by changing the voltage applied to it or by using Pulse Width Modulation (PWM) to vary the average voltage applied to it. The latter is the job of the ESC which may also enable you to control the direction of rotation of the motor
To provide more help then full details of the ESC will be required
Hey Mr. UKHeliBob, I only have this datasheet which might help you. Sorry, I'm not sure with this ESC as it is an old ESC. Please take note that this DC motor is for speeding / reversing. So I guess it should turn 360° so that the tires rotate as it should.
You're suggesting 2 things here, does this means that I need to buy any components ?
If you can get the ESC working then you do not need to buy any more components
The ESC can be controlled by the Servo library, but the main problem may be setting it up. The PDF describes a procedure (step 6) based on the ESC being connected to an RC receiver so you will need to mimic those inputs
First of all, I need to clarify that this is the first time I playing with Arduino, since this is my first project. Btw, the controller doesn't have any battery on it, and I couldn't find one. But, does that necessary since I need to control it through bluetooth ? As you can see from the circuit above, I already connected the yellow wire ESC to ~3 ( to control the brushed motor ) and blue wire PS201S - 6V to ~5 in arduino pin.
To avoid confusion, PS201S - 6V is for controlling front tyre for left and right turn, while ESC DC Brushed Motor for forward and reverse of the tires.
From your reply I am sorry to say that this project is probably too difficult for you at this stage of your knowledge. My advice would be to get the basics of Arduino programming under your belt before considering trying to use this ESC.
If you are determined to use this particular brushed motor then consider getting a modern ESC which will come with instructions and support, but make sure that it is designed to be used with a a brushed motor. ESCs for brushless motors are more common and are unsuitable
An alternative is to use a motor driver board rather than an ESC which, once again, will be supported and a library for it will be available
