ESC goes wild when arduino nano powered from battery
i have a working circuit and code for an esc and an arduino nano, and for some reason when i connect the arduino with power via usb, everything is fine, but if i use a 9V battery, the motor starts going on maximum speed, as if it was stuck in the calibration process. (I also use an nrf24l01 module to communicate with a transmitter, and the connection seems to work)
the code for the part that causes problems:
/* Receiver code for the Arduino Radio control with PWM output
 * Install the NRF24 library to your IDE
 * Upload this code to the Arduino UNO, NANO, Pro mini (5V,16MHz)
 * Connect a NRF24 module to it:
    Module // Arduino UNO,NANO
    GND    ->   GND
    Vcc    ->   3.3V
    CE     ->   D9
    CSN    ->   D10
    CLK    ->   D13
    MOSI   ->   D11
    MISO   ->   D12
This code receive 7 channels and create a PWM output for each one on D2, D3, D4, D5, D6, D7and D8
Please, like share and subscribe : https://www.youtube.com/c/ELECTRONOOBS
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#include <Servo.h>  //To create PWM signals we need this lybrary
const uint64_t pipeIn = 0xE8E8F0F0E1LL;     //Remember that this code is the same as in the transmitter
RF24 radio(9, 10);  //CSN and CE pins
// The sizeof this struct should not exceed 32 bytes
struct Received_data {
  byte ch1;
  byte ch2;
  byte ch3;
  byte ch4;
Received_data received_data;
Servo channel_1;
Servo channel_2;
Servo channel_3;
Servo channel_4;
Servo channel_5;
int ch1_value = 0;
int ch2_value = 0;
int ch3_value = 0;
int ch4_value = 0;
int ch5_value = 0;
void reset_the_Data()
  // 'safe' values to use when NO radio input is detected
  received_data.ch1 = 0;      //Throttle (channel 1) to 0
  received_data.ch2 = 127;
  received_data.ch3 = 127;
  received_data.ch4 = 127;
  //Attach the servo signal on pins from D2 to D8
  channel_1.attach(2);
  channel_2.attach(3);
  channel_3.attach(4);
  channel_4.attach(5);
  channel_5.attach(6);
  //We reset the received values
  reset_the_Data();
  //Once again, begin and radio configuration
  radio.begin();
  radio.setAutoAck(false);
  radio.setDataRate(RF24_250KBPS);
  radio.openReadingPipe(1,pipeIn);
  //We start the radio comunication
  radio.startListening();
  channel_1.writeMicroseconds(2000);
  delay(5000);
  channel_1.writeMicroseconds(1000);
  delay(2000);
  channel_1.write(10);
unsigned long lastRecvTime = 0;
//We create the function that will read the data each certain time
void receive_the_data()
  while ( radio.available() ) {
  radio.read(&received_data, sizeof(Received_data));
  lastRecvTime = millis(); //Here we receive the data
  //Receive the radio data
  receive_the_data();
//////////This small if will reset the data if signal is lost for 1 sec.
  unsigned long now = millis();
  if ( now - lastRecvTime > 1000 ) {
    // signal lost?
    reset_the_Data();
    //Go up and change the initial values if you want depending on
    //your aplications. Put 0 for throttle in case of drones so it won't
    //fly away
  ch1_value = map(received_data.ch1,123,255,1000,2000);
  ch2_value = map(received_data.ch2,0,255,1000,2000);
  ch3_value = map(received_data.ch3,0,255,1000,2000);
  ch4_value = map(received_data.ch4,0,255,1000,2000);
  ch5_value = map(received_data.ch4,0,255,1000,2000);
  //Create the PWM signals
  channel_1.writeMicroseconds(ch1_value);
  channel_2.writeMicroseconds(ch2_value);
  channel_3.writeMicroseconds(ch3_value);
  channel_4.writeMicroseconds(ch4_value);
  channel_5.writeMicroseconds(ch5_value);
}//Loop end
Show the circuit.
[edit]
It looks like your sketch looks to see if any radio information is available, and if not, runs the motors.
A PP3, fire alarm battery? Not good. 6xAA would be a minimum.
solved it thx
