im using an ESP-01 as a standalone microcontroller, and i was using it to send data from a sensor to the web
and it was working perfectly, but suddenly it just didnt. i went testing around and found out that apparently it was having trouble connecting to my wifi, even though the SSID and Password that i hardcoded in havent changed
next i also tested the same sketch on a diffrent ESP-O1, and it started working again
that lead me to believe i somehow blew the esp, but after a bit of testing it can still run every example sketch perfectly, even the WifiScan
this is the connecting part of the code
delay(2000);
WiFi.begin(ssid, pass);
Serial.println("connecting");
while(WiFi.status() != WL_CONNECTED){
Serial.println(WiFi.status());
if(WiFi.status() == WL_CONNECT_FAILED){
Serial.println("failed to connect to wifi");
}else{
Serial.println("connected succesfully!");
Wifi.status()
here returns 7 for a while, and then 4
which i found out later that each number corresponds to a code
WL_NO_SHIELD = 255, // for compatibility with WiFi Shield library
WL_IDLE_STATUS = 0,
WL_NO_SSID_AVAIL = 1,
WL_SCAN_COMPLETED = 2,
WL_CONNECTED = 3,
WL_CONNECT_FAILED = 4,
WL_CONNECTION_LOST = 5,
WL_DISCONNECTED = 6
but 7 is unlisted...
im completely stumped here
