I need to connect esp-01 to arduino mega for a project but i gives this error:
A fatal esptool.py error occurred: Failed to connect to ESP8266: Timed out waiting for packet header
This sketch demonstrates how to scan WiFi networks.
The API is almost the same as with the WiFi Shield library,
the most obvious difference being the different file you need to include:
#include <ESP8266WiFi.h>
Serial.println(F("\nESP8266 WiFi scan example"));
// Set WiFi to station mode
WiFi.mode(WIFI_STA);
// Disconnect from an AP if it was previously connected
WiFi.disconnect();
delay(100);
String ssid;
int32_t rssi;
uint8_t encryptionType;
uint8_t *bssid;
int32_t channel;
bool hidden;
int scanResult;
Serial.println(F("Starting WiFi scan..."));
scanResult = WiFi.scanNetworks(/*async=*/false, /*hidden=*/true);
if (scanResult == 0) {
Serial.println(F("No networks found"));
} else if (scanResult > 0) {
Serial.printf(PSTR("%d networks found:\n"), scanResult);
// Print unsorted scan results
for (int8_t i = 0; i < scanResult; i++) {
WiFi.getNetworkInfo(i, ssid, encryptionType, rssi, bssid, channel, hidden);
// get extra info
const bss_info *bssInfo = WiFi.getScanInfoByIndex(i);
String phyMode;
const char *wps = "";
if (bssInfo) {
phyMode.reserve(12);
phyMode = F("802.11");
String slash;
if (bssInfo->phy_11b) {
phyMode += 'b';
slash = '/';
if (bssInfo->phy_11g) {
phyMode += slash + 'g';
slash = '/';
if (bssInfo->phy_11n) {
phyMode += slash + 'n';
if (bssInfo->wps) {
wps = PSTR("WPS");
Serial.printf(PSTR(" %02d: [CH %02d] [%02X:%02X:%02X:%02X:%02X:%02X] %ddBm %c %c %-11s %3S %s\n"), i, channel, bssid[0], bssid[1], bssid[2], bssid[3], bssid[4], bssid[5], rssi, (encryptionType == ENC_TYPE_NONE) ? ' ' : '*', hidden ? 'H' : 'V', phyMode.c_str(), wps, ssid.c_str());
yield();
Serial.printf(PSTR("WiFi scan error %d"), scanResult);
// Wait a bit before scanning again
delay(5000);
