i am using ESP-WROOM-32 Device with Rainmaker App and having a problem tried with BLE and SoftAp, no luck BLE Error message "Communication Failed" sometime it says "Cannot find the device"
SoftAP Error message "Assisted Claiming not supported for SoftAP. Cannot Proceed" again tried to flashed with new firmware using espressif firmware tool still no luck. Tried to connect with nRF Connect App, got an error in log "Error (0x85): GATT ERROR" if i use auto connect it will get connect after long time to nRF Connect App
Did you find any solution if so Please help me? I have attached the device image and code below
#include "RMaker.h"
#include "WiFi.h"
#include "WiFiProv.h"
const char *service_name = "PROV_12345";
const char *pop = "123456";
// define the Device Names
char deviceName_1[] = "Switch1";
char deviceName_2[] = "Switch2";
char deviceName_3[] = "Switch3";
char deviceName_4[] = "Switch4";
// define the GPIO connected with Relays and switches
static uint8_t RelayPin1 = 23; //D23
static uint8_t RelayPin2 = 22; //D22
static uint8_t RelayPin3 = 21; //D21
static uint8_t RelayPin4 = 19; //D19
static uint8_t SwitchPin1 = 13; //D13
static uint8_t SwitchPin2 = 12; //D12
static uint8_t SwitchPin3 = 14; //D14
static uint8_t SwitchPin4 = 27; //D27
static uint8_t wifiLed = 2; //D2
static uint8_t gpio_reset = 0;
/* Variable for reading pin status*/
// Relay State
bool toggleState_1 = LOW; //Define integer to remember the toggle state for relay 1
bool toggleState_2 = LOW; //Define integer to remember the toggle state for relay 2
bool toggleState_3 = LOW; //Define integer to remember the toggle state for relay 3
bool toggleState_4 = LOW; //Define integer to remember the toggle state for relay 4
// Switch State
bool SwitchState_1 = LOW;
bool SwitchState_2 = LOW;
bool SwitchState_3 = LOW;
bool SwitchState_4 = LOW;
//The framework provides some standard device types like switch, lightbulb, fan, temperature sensor.
static Switch my_switch1(deviceName_1, &RelayPin1);
static Switch my_switch2(deviceName_2, &RelayPin2);
static Switch my_switch3(deviceName_3, &RelayPin3);
static Switch my_switch4(deviceName_4, &RelayPin4);
void sysProvEvent(arduino_event_t *sys_event)
switch (sys_event->event_id) {
case ARDUINO_EVENT_PROV_START:
#if CONFIG_IDF_TARGET_ESP32
Serial.printf("\nProvisioning Started with name \"%s\" and PoP \"%s\" on BLE\n", service_name, pop);
printQR(service_name, pop, "ble");
// digitalWrite(wifiLed, true);
#else
Serial.printf("\nProvisioning Started with name \"%s\" and PoP \"%s\" on SoftAP\n", service_name, pop);
printQR(service_name, pop, "softap");
#endif
case ARDUINO_EVENT_WIFI_STA_CONNECTED:
Serial.printf("\nConnected to Wi-Fi!\n");
void write_callback(Device *device, Param *param, const param_val_t val, void *priv_data, write_ctx_t *ctx)
const char *device_name = device->getDeviceName();
const char *param_name = param->getParamName();
if(strcmp(device_name, deviceName_1) == 0) {
Serial.printf("Lightbulb = %s\n", val.val.b? "true" : "false");
if(strcmp(param_name, "Power") == 0) {
Serial.printf("Received value = %s for %s - %s\n", val.val.b? "true" : "false", device_name, param_name);
toggleState_1 = val.val.b;
(toggleState_1 == false) ? digitalWrite(RelayPin1, HIGH) : digitalWrite(RelayPin1, LOW);
param->updateAndReport(val);
} else if(strcmp(device_name, deviceName_2) == 0) {
Serial.printf("Switch value = %s\n", val.val.b? "true" : "false");
toggleState_2 = val.val.b;
(toggleState_2 == false) ? digitalWrite(RelayPin2, HIGH) : digitalWrite(RelayPin2, LOW);
} else if(strcmp(device_name, deviceName_3) == 0) {
toggleState_3 = val.val.b;
(toggleState_3 == false) ? digitalWrite(RelayPin3, HIGH) : digitalWrite(RelayPin3, LOW);
} else if(strcmp(device_name, deviceName_4) == 0) {
toggleState_4 = val.val.b;
(toggleState_4 == false) ? digitalWrite(RelayPin4, HIGH) : digitalWrite(RelayPin4, LOW);
void manual_control()
if (digitalRead(SwitchPin1) == LOW && SwitchState_1 == LOW) {
toggleState_1 = 1;
SwitchState_1 = HIGH;
my_switch1.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_1);
Serial.println("Switch-1 on");
if (digitalRead(SwitchPin1) == HIGH && SwitchState_1 == HIGH) {
digitalWrite(RelayPin1, HIGH);
toggleState_1 = 0;
Serial.println("Switch-1 off");
if (digitalRead(SwitchPin2) == LOW && SwitchState_2 == LOW) {
toggleState_2 = 1;
SwitchState_2 = HIGH;
my_switch2.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_2);
Serial.println("Switch-2 on");
if (digitalRead(SwitchPin2) == HIGH && SwitchState_2 == HIGH) {
digitalWrite(RelayPin2, HIGH);
toggleState_2 = 0;
Serial.println("Switch-2 off");
if (digitalRead(SwitchPin3) == LOW && SwitchState_3 == LOW) {
toggleState_3 = 1;
SwitchState_3 = HIGH;
my_switch3.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_3);
Serial.println("Switch-3 on");
if (digitalRead(SwitchPin3) == HIGH && SwitchState_3 == HIGH) {
digitalWrite(RelayPin3, HIGH);
toggleState_3 = 0;
Serial.println("Switch-3 off");
if (digitalRead(SwitchPin4) == LOW && SwitchState_4 == LOW) {
toggleState_4 = 1;
SwitchState_4 = HIGH;
my_switch4.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, toggleState_4);
Serial.println("Switch-4 on");
if (digitalRead(SwitchPin4) == HIGH && SwitchState_4 == HIGH) {
digitalWrite(RelayPin4, HIGH);
toggleState_4 = 0;
Serial.println("Switch-4 off");
uint32_t chipId = 0;
// Set the Relays GPIOs as output mode
pinMode(RelayPin1, OUTPUT);
pinMode(RelayPin2, OUTPUT);
pinMode(RelayPin3, OUTPUT);
pinMode(RelayPin4, OUTPUT);
pinMode(wifiLed, OUTPUT);
// Configure the input GPIOs
pinMode(SwitchPin1, INPUT_PULLUP);
pinMode(SwitchPin2, INPUT_PULLUP);
pinMode(SwitchPin3, INPUT_PULLUP);
pinMode(SwitchPin4, INPUT_PULLUP);
pinMode(gpio_reset, INPUT);
// Write to the GPIOs the default state on booting
digitalWrite(RelayPin1, !toggleState_1);
digitalWrite(RelayPin2, !toggleState_2);
digitalWrite(RelayPin3, !toggleState_3);
digitalWrite(RelayPin4, !toggleState_4);
digitalWrite(wifiLed, LOW);
Node my_node;
my_node = RMaker.initNode("ESP32_Relay_4");
//Standard switch device
my_switch1.addCb(write_callback);
my_switch2.addCb(write_callback);
my_switch3.addCb(write_callback);
my_switch4.addCb(write_callback);
//Add switch device to the node
my_node.addDevice(my_switch1);
my_node.addDevice(my_switch2);
my_node.addDevice(my_switch3);
my_node.addDevice(my_switch4);
//This is optional
RMaker.enableOTA(OTA_USING_PARAMS);
//If you want to enable scheduling, set time zone for your region using setTimeZone().
//The list of available values are provided here https://rainmaker.espressif.com/docs/time-service.html
// RMaker.setTimeZone("Asia/Shanghai");
// Alternatively, enable the Timezone service and let the phone apps set the appropriate timezone
RMaker.enableTZService();
RMaker.enableSchedule();
//Service Name
for(int i=0; i<17; i=i+8) {
chipId |= ((ESP.getEfuseMac() >> (40 - i)) & 0xff) << i;
Serial.printf("\nChip ID: %d Service Name: %s\n", chipId, service_name);
Serial.printf("\nStarting ESP-RainMaker\n");
RMaker.start();
WiFi.onEvent(sysProvEvent);
WiFiProv.beginProvision(WIFI_PROV_SCHEME_BLE, WIFI_PROV_SCHEME_HANDLER_FREE_BTDM, WIFI_PROV_SECURITY_1, pop, service_name);
#else
WiFiProv.beginProvision(WIFI_PROV_SCHEME_SOFTAP, WIFI_PROV_SCHEME_HANDLER_NONE, WIFI_PROV_SECURITY_1, pop, service_name);
#endif
my_switch1.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, false);
my_switch2.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, false);
my_switch3.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, false);
my_switch4.updateAndReportParam(ESP_RMAKER_DEF_POWER_NAME, false);
// Read GPIO0 (external button to reset device
if(digitalRead(gpio_reset) == LOW) { //Push button pressed
Serial.printf("Reset Button Pressed!\n");
// Key debounce handling
delay(100);
int startTime = millis();
while(digitalRead(gpio_reset) == LOW) delay(50);
int endTime = millis();
if ((endTime - startTime) > 10000) {
// If key pressed for more than 10secs, reset all
Serial.printf("Reset to factory.\n");
RMakerFactoryReset(2);
} else if ((endTime - startTime) > 3000) {
Serial.printf("Reset Wi-Fi.\n");
// If key pressed for more than 3secs, but less than 10, reset Wi-Fi
RMakerWiFiReset(2);
delay(100);
if (WiFi.status() != WL_CONNECTED)
//Serial.println("WiFi Not Connected");
// digitalWrite(wifiLed, false);
ledBlink();
//Serial.println("WiFi Connected");
manual_control();
void ledBlink(){
delay(300);
