Still a big mess..
what happens when you change..
.fb_count = 2
to equal 1..
.fb_count = 1
/* Edge Impulse Arduino examples
```* Copyright (c) 2022 EdgeImpulse Inc.
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files (the "Software"), to deal
in the Software without restriction, including without limitation the rights
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in
all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
SOFTWARE.
// These sketches are tested with 2.0.4 ESP32 Arduino Core
/* Includes ---------------------------------------------------------------- */
#include <Skittle_sorter_inferencing.h>
#include ""
#include "esp_camera.h"
// Select camera model - find more camera models in camera_pins.h file here
int in1 = 12;
int in2 = 13;
int in3 = 14;
int in4 = 15;
int speed_gear = 1;
//Slide--------------------------
int in5 = 16;
int in6 = 0;
int in7 = 2;
int in8 = 4; // flash LED pin
int speed_slide = 1;
int Step = 32;
int Currentposition;
int Finalposition;
int Stepsneeded;
//#define CAMERA_MODEL_ESP_EYE // Has PSRAM
#define CAMERA_MODEL_AI_THINKER // Has PSRAM
#if defined(CAMERA_MODEL_ESP_EYE)
#define PWDN_GPIO_NUM -1
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM 4
#define SIOD_GPIO_NUM 18
#define SIOC_GPIO_NUM 23
#define Y9_GPIO_NUM 36
#define Y8_GPIO_NUM 37
#define Y7_GPIO_NUM 38
#define Y6_GPIO_NUM 39
#define Y5_GPIO_NUM 35
#define Y4_GPIO_NUM 14
#define Y3_GPIO_NUM 13
#define Y2_GPIO_NUM 34
#define VSYNC_GPIO_NUM 5
#define HREF_GPIO_NUM 27
#define PCLK_GPIO_NUM 25
#elif defined(CAMERA_MODEL_AI_THINKER)
#define PWDN_GPIO_NUM 32
#define XCLK_GPIO_NUM 0
#define SIOD_GPIO_NUM 26
#define SIOC_GPIO_NUM 27
#define Y9_GPIO_NUM 35
#define Y8_GPIO_NUM 34
#define Y7_GPIO_NUM 39
#define Y6_GPIO_NUM 36
#define Y5_GPIO_NUM 21
#define Y4_GPIO_NUM 19
#define Y3_GPIO_NUM 18
#define Y2_GPIO_NUM 5
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM 23
#define PCLK_GPIO_NUM 22
#else
#error "Camera model not selected"
#endif
/* Constant defines -------------------------------------------------------- */
#define EI_CAMERA_RAW_FRAME_BUFFER_COLS 320
#define EI_CAMERA_RAW_FRAME_BUFFER_ROWS 240
#define EI_CAMERA_FRAME_BYTE_SIZE 3
/* Private variables ------------------------------------------------------- */
static bool debug_nn = false; // Set this to true to see e.g. features generated from the raw signal
static bool is_initialised = false;
uint8_t *snapshot_buf; //points to the output of the capture
static camera_config_t camera_config = {
.pin_pwdn = PWDN_GPIO_NUM,
.pin_reset = RESET_GPIO_NUM,
.pin_xclk = XCLK_GPIO_NUM,
.pin_sscb_sda = SIOD_GPIO_NUM,
.pin_sscb_scl = SIOC_GPIO_NUM,
.pin_d7 = Y9_GPIO_NUM,
.pin_d6 = Y8_GPIO_NUM,
.pin_d5 = Y7_GPIO_NUM,
.pin_d4 = Y6_GPIO_NUM,
.pin_d3 = Y5_GPIO_NUM,
.pin_d2 = Y4_GPIO_NUM,
.pin_d1 = Y3_GPIO_NUM,
.pin_d0 = Y2_GPIO_NUM,
.pin_vsync = VSYNC_GPIO_NUM,
.pin_href = HREF_GPIO_NUM,
.pin_pclk = PCLK_GPIO_NUM,
//XCLK 20MHz or 10MHz for OV2640 double FPS (Experimental)
.xclk_freq_hz = 10000000,
.ledc_timer = LEDC_TIMER_0,
.ledc_channel = LEDC_CHANNEL_0,
.pixel_format = PIXFORMAT_JPEG, // camera will output JPEG (matches fmt2rgb888 call)
.frame_size = FRAMESIZE_QQVGA, // 320x240 - matches EI_CAMERA_RAW_FRAME_BUFFER_COLS/ROWS
.jpeg_quality = 12,
.fb_count = 2, // 2 buffers ok for JPEG (double buffering)
.fb_location = CAMERA_FB_IN_PSRAM,
.grab_mode = CAMERA_GRAB_WHEN_EMPTY,
/* Function definitions ------------------------------------------------------- */
bool ei_camera_init(void);
void ei_camera_deinit(void);
bool ei_camera_capture(uint32_t img_width, uint32_t img_height, uint8_t *out_buf) ;
@brief Arduino setup function
//comment out the below line to start inference immediately after upload
while (!Serial);
Serial.println("Edge Impulse Inferencing Demo");
if (ei_camera_init() == false) {
ei_printf("Failed to initialize Camera!\\r\\n");
else {
ei_printf("Camera initialized\\r\\n");
//Serial.end();
ei_printf("\\nStarting continious inference in 2 seconds...\\n");
ei_sleep(2000);
if (psramFound()) {
Serial.println("PSRAM is Ok!");
Serial.println("PSRAM NOT found!");
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
//Slide------------
pinMode(in5, OUTPUT); //
pinMode(in6, OUTPUT); //
pinMode(in7, OUTPUT);
pinMode(in8, OUTPUT);
@brief Get data and run inferencing
[in] debug Get debug info if true
Rotation_gear();
// for (int i = 0; i <= 40; i++) {
// Left_slide();
// Right_slide();
// instead of wait_ms, we'll wait on the signal, this allows threads to cancel us...
if (ei_sleep(5) != EI_IMPULSE_OK) {
return;
snapshot_buf = (uint8_t\*)malloc(EI_CAMERA_RAW_FRAME_BUFFER_COLS \* EI_CAMERA_RAW_FRAME_BUFFER_ROWS \* EI_CAMERA_FRAME_BYTE_SIZE);
// check if allocation was successful
if (snapshot_buf == nullptr) {
ei_printf("ERR: Failed to allocate snapshot buffer!\\n");
return;
ei::signal_t signal;
signal.total_length = EI_CLASSIFIER_INPUT_WIDTH \* EI_CLASSIFIER_INPUT_HEIGHT;
signal.get_data = &ei_camera_get_data;
if (ei_camera_capture((size_t)EI_CLASSIFIER_INPUT_WIDTH, (size_t)EI_CLASSIFIER_INPUT_HEIGHT, snapshot_buf) == false) {
ei_printf("Failed to capture image\\r\\n");
free(snapshot_buf);
return;
// Run the classifier
ei_impulse_result_t result = { 0 };
EI_IMPULSE_ERROR err = run_classifier(&signal, &result, debug_nn);
if (err != EI_IMPULSE_OK) {
ei_printf("ERR: Failed to run classifier (%d)\\n", err);
return;
// print the predictions
ei_printf("Predictions (DSP: %d ms., Classification: %d ms., Anomaly: %d ms.): \\n",
result.timing.dsp, result.timing.classification, result.timing.anomaly);
#if EI_CLASSIFIER_OBJECT_DETECTION == 1
ei_printf("Object detection bounding boxes:\\r\\n");
for (uint32_t i = 0; i < result.bounding_boxes_count; i++) {
ei_impulse_result_bounding_box_t bb = result.bounding_boxes\[i\];
if (bb.value == 0) {
continue;
ei_printf(" %s (%f) \[ x: %u, y: %u, width: %u, height: %u \]\\r\\n",
bb.label,
bb.value,
bb.x,
bb.y,
bb.width,
bb.height);
Rotation_slide(bb.label);
// Print the prediction results (classification)
#else
ei_printf("Predictions:\\r\\n");
for (uint16_t i = 0; i < EI_CLASSIFIER_LABEL_COUNT; i++) {
ei_printf(" %s: ", ei_classifier_inferencing_categories\[i\]);
ei_printf("%.5f\\r\\n", result.classification\[i\].value);
#endif
// Print anomaly result (if it exists)
#if EI_CLASSIFIER_HAS_ANOMALY
ei_printf("Anomaly prediction: %.3f\\r\\n", result.anomaly);
#endif
#if EI_CLASSIFIER_HAS_VISUAL_ANOMALY
ei_printf("Visual anomalies:\\r\\n");
for (uint32_t i = 0; i < result.visual_ad_count; i++) {
ei_impulse_result_bounding_box_t bb = result.visual_ad_grid_cells\[i\];
if (bb.value @brief = 0) {
@brief contin@briefe;
@brief
ei_@retvalrintf(" %s (%f@retva@retva@retval \[ x: %u, y: %u, width: %u, height: %u \]\\r\\n",
bb.label,
bb.value,
bb.x,
bb.y,
bb.width,
bb.height);
#endif
free(snapshot_buf);
@brief Setup image sensor & start streaming
@retval false if initialisation failed
bool ei_camera_init(void) {
if (is_initialised) return true;
pinMode(13, INPUT_PULLUP);
pinMode(14, INPUT_PULLUP);
#endif
//initialize the camera
esp_err_t err = esp_camera_init(&camera_config);
if (err != ESP_OK) {
Serial.printf("Camera init failed with error 0x%x\\n", err);
return false;
sensor_t \* s = esp_camera_sensor_get();
// initial sensors are flipped vertically and colors are a bit saturated
if (s->id.PID == OV3660_PID) {
s->set_vflip(s, 1); // flip it back
s->set_brightness(s, 1); // up@briefthe brightness just a@briefbit
s - @briefset_@briefaturation(s, 0); // lower the saturation
#if defined(CAMERA_MODEL_M5STACK_WIDE)
s->set_vflip(s, 1);
s->set_hmirror(s, 1);
#elif defined(CAMERA_MODEL_ESP_EYE)
s->set_vflip(s, 1);
s->set_awb_@briefain(s, 1);
#endif
is_ini@briefialis@brie@briefd = true;
return true;
@brief Stop streaming of sensor data
void ei_camera_deinit(void) {
//deinitialize the camera
esp_err_t err = esp_camera_deinit();
if (err != ESP_OK)
ei_printf("Camera deinit failed\\n");
return;
is_initialised = fals@retval;
return;
@brief Ca@retva@retva@retvalture, rescale and crop image
[in] img_width width of output image
[in] img_height height of output image
[in] out_buf pointer to store output image, NULL may be used
if ei_camera_frame_buffer is to be used for capture and resize/cropping.
@retval false if not initialised, image captured, rescaled or cropped failed
bool ei_camera_capture(uint32_t img_width, uint32_t img_height, uint8_t *out_buf) {
bool do_resize = false;
if (!is_initialised) {
ei_printf("ERR: Camera is not initialized\\r\\n");
return false;
camera_fb_t \*fb = esp_camera_fb_get();
if (!fb) {
ei_printf("Camera capture failed\\n");
return false;
bool converted = fmt2rgb888(fb->buf, fb->len, PIXFORMAT_JPEG, snapshot_buf);
esp_camera_fb_return(fb);
if (!converted) {
ei_printf("Conversion failed\\n");
return false;
if ((img_width != EI_CAMERA_RAW_FRAME_BUFFER_COLS)
|| (img_height != EI_CAMERA_RAW_FRAME_BUFFER_ROWS)) {
do_resize = true;
if (do_resize) {
ei::image::processing::crop_and_interpolate_rgb888(
out_buf,
EI_CAMERA_RAW_FRAME_BUFFER_COLS,
EI_CAMERA_RAW_FRAME_BUFFER_ROWS,
out_buf,
img_width,
img_height);
return true;
static int ei_camera_get_data(size_t offset, size_t length, float *out_ptr)
// we already have a RGB888 buffer, so recalculate offset into pixel index
size_t pixel_ix = offset \ * 3;
size_t pixels_left = length;
size_t out_ptr_ix = 0;
while (pixels_left != 0) {
// Swap BGR to RGB here
// due to
out_ptr\[out_ptr_ix\] = (snapshot_buf\[pixel_ix + 2\] << 16) + (snapshot_buf\[pixel_ix + 1\] << 8) + snapshot_buf\[pixel_ix\];
// go to the next pixel
out_ptr_ix++;
pixel_ix += 3;
pixels_left--;
// and done!
return 0;
#if !defined(EI_CLASSIFIER_SENSOR) || EI_CLASSIFIER_SENSOR != EI_CLASSIFIER_SENSOR_CAMERA
#error "Invalid model for current sensor"
#endif
//Gear-------------------------------
void step1_gear() {
digitalWrite(in1, HIGH);
digitalWrite(in2, LOW);
digitalWrite(in3, LOW);
digitalWrite(in4, LOW);
delay(speed_gear);
void step2_gear() {
digitalWrite(in2, HIGH);
delay(speed_gear);
void step3_gear() {
digitalWrite(in1, LOW);
delay(speed_gear);
void step4_gear() {
digitalWrite(in3, HIGH);
delay(speed_gear);
void step5_gear() {
delay(speed_gear);
void step6_gear() {
digitalWrite(in4, HIGH);
delay(speed_gear);
void step7_gear() {
delay(speed_gear);
void step8_gear() {
delay(speed_gear);
void Foward_gear()
step8_gear();
step7_gear();
step6_gear();
step5_gear();
step4_gear();
step3_gear();
step2_gear();
step1_gear();
void Backward_gear()
step1_gear();
step2_gear();
step3_gear();
step4_gear();
step5_gear();
step6_gear();
step7_gear();
step8_gear();
void Rotation_gear() {
// 512 pro plnou rotaci
Backward_gear();
for (int i = 0; i <= 113; i++) {
Foward_gear();
//Slide-------------------------------
void step1_slide() {
digitalWrite(in5, HIGH);
digitalWrite(in6, LOW);
digitalWrite(in7, LOW);
digitalWrite(in8, LOW);
delay(speed_slide);
void step2_slide() {
digitalWrite(in6, HIGH);
delay(speed_slide);
void step3_slide() {
digitalWrite(in5, LOW);
delay(speed_slide);
void step4_slide() {
digitalWrite(in7, HIGH);
delay(speed_slide);
void step5_slide() {
delay(speed_slide);
void step6_slide() {
digitalWrite(in8, HIGH);
delay(speed_slide);
void step7_slide() {
delay(speed_slide);
void step8_slide() {
delay(speed_slide);
void Right_slide()
step8_slide();
step7_slide();
step6_slide();
step5_slide();
step4_slide();
step3_slide();
step2_slide();
step1_slide();
void Left_slide()
step1_slide();
step2_slide();
step3_slide();
step4_slide();
step5_slide();
step6_slide();
step7_slide();
step8_slide();
void Rotation_slide (String Label)
if (Label == "Red")
Finalposition = 5;
Stepsneeded = Finalposition - Currentposition;
} else if (Label == "Green")
Finalposition = 4;
} else if (Label == "Yellow")
Finalposition = 3;
} else if (Label == "Orange")
Finalposition = 2;
} else if (Label == "Purple")
Finalposition = 1;
} else
if (Stepsneeded < 0)
for (int i; i < Stepsneeded\*Step\ * (-1); i++)
Left_slide();
} else
for (int i; i < Stepsneeded\*Step; i++)
Right_slide();
good luck.. ~q
