If I try to upload code to an esp 32 Wroom it won´t work. I already checked if I use the right com, but everything seems to be fine. I also use the esp 32 board manager library
Here is the error message:
Arduino: 1.8.19 (Windows 10), Board: "ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, None"
Sketch uses 214849 bytes (16%) of program storage space. Maximum is 1310720 bytes.
Global variables use 15388 bytes (4%) of dynamic memory, leaving 312292 bytes for local variables. Maximum is 327680 bytes.
esptool.py v2.6
Serial port COM3
Connecting...
Traceback (most recent call last):
File "esptool.py", line 2959, in <module>
File "esptool.py", line 2952, in _main
File "esptool.py", line 2653, in main
File "esptool.py", line 460, in connect
File "esptool.py", line 440, in _connect_attempt
File "esptool.py", line 379, in sync
File "esptool.py", line 322, in command
File "esptool.py", line 285, in write
File "site-packages\serial\serialwin32.py", line 323, in write
serial.serialutil.SerialTimeoutException: Write timeout
Failed to execute script esptool
An error occurred while uploading the sketch
option enabled in File -> Preferences.
If you have Question or if anything is not clear just write a question.
Hi there, which esp32 wroom board are you using to upload the sketch? Because they´re different versions with the same esp32 chip and is this the first time you upload a sketch to this board or not? Please paste a link of the board you´re using.
You can find a lot of free e-books on the following link, I always buy my boards here:
In this e-book they explain how to setup your board. The ESP32 Dev Kit C version 4 is the latest one, but you can use the same library on your version without problems, only the pins/GPIO's can be different. To download you only have to register and login.
@einkleinesquack I wrote a little testcode which you can upload to the board, hold in mind to hold down the boot button on the board for a second or 2 (the button on the right side next to the µusb port) when you see in the output panel connecting... else you will see an exit status.
#include <SPI.h> // In board manager search esp8266 for ESP8266 Community and install library
Serial.println("Testing ESP32 board");
delay(2000);
When you open the Serial monitor (Tools > Serial Monitor) now, you'll see the test text in the panel send from the ESP32.
