I receive the following errors using the Arduino IDE with an ESP32 WROOM V1 using the example SimpleTime.ino; and many other examples. The sketch compiles ok but will not upload. I have tried several high-quality cables. and I can compile and upload blink OK.
Traceback (most recent call last):
File "esptool.py", line 3682, in
File "esptool.py", line 3675, in _main
File "esptool.py", line 3330, in main
File "esptool.py", line 512, in connect
File "esptool.py", line 492, in _connect_attempt
File "esptool.py", line 431, in sync
File "esptool.py", line 369, in command
File "esptool.py", line 332, in write
File "site-packages\serial\serialwin32.py", line 323, in write
serial.serialutil.SerialTimeoutException: Write timeout
Failed to execute script esptool
Failed uploading: uploading error: exit status 0xffffffff
i've gotten that error many times, along with many other similar errors because i often switch between avr and esp32 and the esp32 boards operate on different com ports, 3 & 4.
suggest you try again. make sure the board is plugged in, and the proper com and board type are selected.
i just got the following. it downloaded fine after trying again (see further below.
Sketch uses 729014 bytes (55%) of program storage space. Maximum is 1310720 bytes.
Global variables use 40124 bytes (12%) of dynamic memory, leaving 287556 bytes for local variables. Maximum is 327680 bytes.
esptool.py v3.0-dev
Serial port COM3
File "esptool.py", line 3682, in <module>
File "esptool.py", line 3329, in main
File "esptool.py", line 263, in __init__
File "site-packages\serial\__init__.py", line 88, in serial_for_url
File "site-packages\serial\serialwin32.py", line 62, in open
serial.serialutil.SerialException: could not open port 'COM3': WindowsError(5, 'Access is denied.')
the selected serial port Failed to execute script esptool
does not exist or your board is not connected
esptool.py v3.0-dev
Serial port COM3
Connecting....
Chip is ESP32-D0WD (revision 1)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: c8:2b:96:ba:a7:b4
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
Configuring flash size...
Auto-detected Flash size: 4MB
Compressed 8192 bytes to 47...
Writing at 0x0000e000... (100 %)
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.0 seconds (effective 13106.9 kbit/s)...
Hash of data verified.
Compressed 18656 bytes to 12053...
Writing at 0x00001000... (100 %)
Wrote 18656 bytes (12053 compressed) at 0x00001000 in 0.2 seconds (effective 899.1 kbit/s)...
Compressed 729136 bytes to 417698...
Writing at 0x00010000... (3 %)
Writing at 0x00014000... (7 %)
Writing at 0x00018000... (11 %)
Writing at 0x0001c000... (15 %)
Writing at 0x00020000... (19 %)
Writing at 0x00024000... (23 %)
Writing at 0x00028000... (26 %)
Writing at 0x0002c000... (30 %)
Writing at 0x00030000... (34 %)
Writing at 0x00034000... (38 %)
Writing at 0x00038000... (42 %)
Writing at 0x0003c000... (46 %)
Writing at 0x00040000... (50 %)
Writing at 0x00044000... (53 %)
Writing at 0x00048000... (57 %)
Writing at 0x0004c000... (61 %)
Writing at 0x00050000... (65 %)
Writing at 0x00054000... (69 %)
Writing at 0x00058000... (73 %)
Writing at 0x0005c000... (76 %)
Writing at 0x00060000... (80 %)
Writing at 0x00064000... (84 %)
Writing at 0x00068000... (88 %)
Writing at 0x0006c000... (92 %)
Writing at 0x00070000... (96 %)
Writing at 0x00074000... (100 %)
Wrote 729136 bytes (417698 compressed) at 0x00010000 in 6.7 seconds (effective 865.6 kbit/s)...
Compressed 3072 bytes to 128...
Writing at 0x00008000... (100 %)
Wrote 3072 bytes (128 compressed) at 0x00008000 in 0.0 seconds (effective 3071.9 kbit/s)...
Leaving...
Hard resetting via RTS pin...
