Good day!
My task is as follows:
- increase the amount of esp 32 memory to 4MB (because I use bluetooth and wi-fi in the same project). I have broken down the partition table as follows:
# Name, Type, SubType, Offset, Size, Flags
otadata, data, ota, 0x009000, 0x002000,
nvs, data, nvs, 0x00b000, 0xf5000,
app0, app, ota_0, 0x100000, 0x180000,
app1, app, ota_1, 0x280000, 0x180000,
I don't know how true this is, but the controller is flashed and works fine
- I need to flash the controller via wi-fi on a local site. I used the basic example from the ArduinOta library
#include <WiFi.h>
#include <WiFiClient.h>
#include <WebServer.h>
#include <ESPmDNS.h>
#include <Update.h>
const char* host = "incubator";
char* ssid = "TP-Link_805E";
char* password = "57085289";
WebServer server(80);
* Login page
const char* loginIndex =
"<form name='loginForm'>"
"<table width='20%' bgcolor='A09F9F' align='center'>"
"<tr>"
"<td colspan=2>"
"<center><font size=4><b>Incubator Login Page</b></font></center>"
"<br>"
"</td>"
"<br>"
"<br>"
"</tr>"
"<tr>"
"<td>Username:</td>"
"<td><input type='text' size=25 name='userid'><br></td>"
"</tr>"
"<br>"
"<br>"
"<tr>"
"<td>Password:</td>"
"<td><input type='Password' size=25 name='pwd'><br></td>"
"<br>"
"<br>"
"</tr>"
"<tr>"
"<td><input type='submit' onclick='check(this.form)' value='Login'></td>"
"</tr>"
"</table>"
"</form>"
"<script>"
"function check(form)"
"if(form.userid.value=='admin' && form.pwd.value=='admin')"
"window.open('/serverIndex')"
"else"
" alert('Error Password or Username')/*displays error message*/"
"</script>";
* Server Index Page
const char* serverIndex =
"<script src='https://ajax.googleapis.com/ajax/libs/jquery/3.2.1/jquery.min.js'></script>"
"<form method='POST' action='#' enctype='multipart/form-data' id='upload_form'>"
"<input type='file' name='update'>"
"<input type='submit' value='Update'>"
"</form>"
"<div id='prg'>progress: 0%</div>"
"<script>"
"$('form').submit(function(e){"
"e.preventDefault();"
"var form = $('#upload_form')[0];"
"var data = new FormData(form);"
" $.ajax({"
"url: '/update',"
"type: 'POST',"
"data: data,"
"contentType: false,"
"processData:false,"
"xhr: function() {"
"var xhr = new window.XMLHttpRequest();"
"xhr.upload.addEventListener('progress', function(evt) {"
"if (evt.lengthComputable) {"
"var per = evt.loaded / evt.total;"
"$('#prg').html('progress: ' + Math.round(per*100) + '%');"
"}, false);"
"return xhr;"
"success:function(d, s) {"
"console.log('success!')"
"error: function (a, b, c) {"
"</script>";
* setup function
void setup(void) {
delay(5000);
// Connect to WiFi network
WiFi.begin(ssid, password);
Serial.println("");
// Wait for connection
Serial.print(".");
Serial.println("");
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
/*use mdns for host name resolution*/
if (!MDNS.begin(host)) { //http://incubator.local
Serial.println("Error setting up MDNS responder!");
while (1) {
Serial.println("mDNS responder started");
/*return index page which is stored in serverIndex */
server.on("/", HTTP_GET, []() {
server.sendHeader("Connection", "close");
server.send(200, "text/html", loginIndex);
server.on("/serverIndex", HTTP_GET, []() {
server.send(200, "text/html", serverIndex);
/*handling uploading firmware file */
server.on("/update", HTTP_POST, []() {
server.send(200, "text/plain", (Update.hasError()) ? "FAIL" : "OK");
ESP.restart();
HTTPUpload& upload = server.upload();
if (upload.status == UPLOAD_FILE_START) {
Serial.printf("Update: %s\n", upload.filename.c_str());
if (!Update.begin(UPDATE_SIZE_UNKNOWN)) { //start with max available size
Update.printError(Serial);
} else if (upload.status == UPLOAD_FILE_WRITE) {
/* flashing firmware to ESP*/
if (Update.write(upload.buf, upload.currentSize) != upload.currentSize) {
} else if (upload.status == UPLOAD_FILE_END) {
if (Update.end(true)) { //true to set the size to the current progress
Serial.printf("Update Success: %u\nRebooting...\n", upload.totalSize);
server.begin();
void loop(void) {
server.handleClient();
delay(1);
And it works. However, when I add to my project, it didn't work: I think this is due to memory overflow (in small sketches it works until the memory runs out). Initially, the following message came to the series port:
rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1100
load:0x40078000,len:9232
load:0x40080400,len:6400
I went to the (Arduino IDE) section Tools -> Partitioning Scheme -> No OTA (2 MB of application / 2 MB of SPIFFS), and this partially helped: my sketch worked, the local domain for the firmware was open. But, when I select a binary file to upload to the controller, the download does not work. On the Internet, a person says that you need to select a service -> Partitioning scheme -> By default 4 MB with spiffs (application 1.2 MB / SPIFFS 1.5 MB), but sketch stops working altogether, the same error appears: rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)...
I think the error is in the memory partition, but I can't figure out exactly how to split the memory. I will be glad of your help...
