ESP 8266 HELP
im Trying to make a temperature sensor send data to my webpage, however I keep getting errors and expected ; before my sensor definition. Any help? here is my arduino uno code and my webpage code
#include "SoftwareSerial.h"
#include <OneWire.h>
#include <DallasTemperature.h>
#define ONE_WIRE_BUS 2
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
String ssid ="....";
String password="....";
SoftwareSerial esp(6, 7);// RX, TX
String data;
String server = "...."; // www.example.com
String uri = "/esp8266.php";// our example is /esppost.php
byte dat [5];
esp.begin(9600);
reset();
connectWifi();
//reset the esp8266 module
void reset() {
esp.println("AT+RST");
if(esp.find("OK") ) Serial.println("Module Reset");
//connect to your wifi network
void connectWifi() {
String cmd = "AT+CWJAP=\"" +ssid+"\",\"" + password + "\"";
esp.println(cmd);
delay(4000);
if(esp.find("OK")) {
Serial.println("Connected!");
else {
connectWifi();
Serial.println("Cannot connect to wifi"); }
byte read_data () {
byte data;
for (int i = 0; i < 8; i ++) {
if (digitalRead (ONE_WIRE_BUS) == LOW) {
while (digitalRead (ONE_WIRE_BUS) == LOW); // wait for 50us
delayMicroseconds (30); // determine the duration of the high level to determine the data is '0 'or '1'
if (digitalRead (ONE_WIRE_BUS) == HIGH)
data |= (1 << (7-i)); // high front and low in the post
while (digitalRead (ONE_WIRE_BUS) == HIGH);
// data '1 ', wait for the next one receiver
} return data; }
void start_test () {
digitalWrite ONE_WIRE_BUS, LOW); // bus down, send start signal
delay (30); // delay greater than 18ms, so DHT11 start signal can be detected
digitalWrite (ONE_WIRE_BUS, HIGH);
delayMicroseconds (40); // Wait for DHT11 response
pinMode (ONE_WIRE_BUS, INPUT);
while (digitalRead (DHpin) == HIGH);
delayMicroseconds (80);
// DHT11 response, pulled the bus 80us
if (digitalRead (ONE_WIRE_BUS) == LOW);
// DHT11 80us after the bus pulled to start sending data
for (int i = 0; i < 4; i ++)
// receive temperature and humidity data, the parity bit is not considered
dat[i] = read_data ();
pinMode (ONE_WIRE_BUS, OUTPUT);
// send data once after releasing the bus, wait for the host to open the next Start signal
void loop () {
start_test ();
// convert the bit data to string form
hum = String(dat[0]);
temp= String(dat[2]);
data = "temperature=" + temp + "&humidity=" + hum;// data sent must be under this form //name1=value1&name2=value2.
httppost();
void httppost () {
esp.println("AT+CIPSTART=\"TCP\",\"" + server + "\",80");//start a TCP connection.
if( esp.find("OK")) {
Serial.println("TCP connection ready");
} delay(1000);
String postRequest =
"POST " + uri + " HTTP/1.0\r\n" +
"Host: " + server + "\r\n" +
"Accept: *" + "/" + "*\r\n" +
"Content-Length: " + data.length() + "\r\n" +
"Content-Type: application/x-www-form-urlencoded\r\n" +
"\r\n" + data;
String sendCmd = "AT+CIPSEND=";//determine the number of caracters to be sent.
esp.print(sendCmd);
esp.println(postRequest.length() );
if(esp.find(">")) { Serial.println("Sending.."); esp.print(postRequest);
if( esp.find("SEND OK")) { Serial.println("Packet sent");
while (esp.available()) {
String tmpResp = esp.readString();
Serial.println(tmpResp);
// close the connection
esp.println("AT+CIPCLOSE");
<?php
$Temp=$_POST["temperature"];
$Write-"<p>Temperature : "  .  $Temp . " Celsius </p>";
file_put_contents('sensor.html',$Write);
it is really
hard
to
read
your
code with
such
poor
formatting.bad
indenting, too many
empty
lines and curly
braces
belong on a line
of their own:
example:
  for(auto i : tempSensors)
    sensors.setResolution(i, TEMPERATURE_PRECISION);
  updateTemperatures(0);
you can try to use auto format in the IDE to get the indentation correct (you will have to do the white space and braces on your own) and update your posted code..
this is my error Arduino:1.8.1 (Windows 7), Tarjeta:"Arduino/Genuino Uno"
C:\Users\Julian\Documents\Arduino\esp\esp.ino: In function 'void reset()':
C:\Users\Julian\Documents\Arduino\esp\esp.ino:47:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
C:\Users\Julian\Documents\Arduino\esp\esp.ino: In function 'void connectWifi()':
C:\Users\Julian\Documents\Arduino\esp\esp.ino:61:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
C:\Users\Julian\Documents\Arduino\esp\esp.ino: In function 'void start_test()':
esp:4: error: expected ';' before numeric constant
C:\Users\Julian\Documents\Arduino\esp\esp.ino:101:14: note: in expansion of macro 'ONE_WIRE_BUS'
esp:111: error: 'DHpin' was not declared in this scope
esp:137: error: a function-definition is not allowed here before '{' token
void loop () {
esp:155: error: a function-definition is not allowed here before '{' token
void httppost () {
esp:205: error: expected '}' at end of input
exit status 1
Este reporte podría tener más información con
"Mostrar salida detallada durante la compilación"
opción habilitada en Archivo -> Preferencias.
You are missing an opening parenthesis in function start_test():
Fix that, auto format your code and retry. Many of the errors are derived from that. The warnings you have got are not causing the compilation to fail.
