Hi all ,
can you please tell me where the mistake was happened and I don't understand also
why my Wi-Fi module isn't connecting to Wi-Fi here is code .
#include<SoftwareSerial.h>
int sensor;
int data;
int pump_status;
SoftwareSerial esp(3, 4);
#define SSID "ram"
#define PASS "ramgopal"
// send at commands to ESP8266
void sendAT(String cmd) {
Serial.print("SEND: ");
esp.println(cmd);
Serial.println(cmd);
boolean connectwifi() {
Serial.println("AT+CWMODE=1");
delay(2000);
Serial.println("AT+CWLAP");
String cmd = "AT+CWJAP=""SSID"",""PASS""";
sendAT(cmd);
delay(5000);
if (Serial.find("Error")) {
Serial.println("Received:Error couldn't connect to network");
return false;
else {
Serial.print("wifi connected \n");
cmd = "AT+CIPMUX=0";
sendAT(cmd);
esp.print("Received: Error");
return false;
esp.begin(9600);
sendAT("AT");
Serial.println("Received : OK \n ESP8266 ready to send data outside if block\n");
Serial.println(Serial.find("OK"));
if (Serial.find("OK")) {
Serial.println("Received : OK \n ESP8266 ready to send data \n");
connectwifi();
sensor = analogRead(A0);
data = map(sensor, 0, 1023, 100, 0);
String sensor_value = String(data);
Serial.print("Soil Moisture: ");
Serial.println(data);
if (data < 76) {
digitalWrite(8, HIGH);
pump_status = 100;
else {
digitalWrite(8, LOW);
pump_status = 0;
String pump = String(pump_status);
updateTS(sensor_value, pump);
delay(3000);
void updateTS(String T, String P) {
String cmd = "AT+CIPSTART="TCP","api.thingspeak.com",81";
sendAT(cmd);
Serial.print("TemparatureData And Pump Status ");
Serial.print(T);
Serial.print(P);
delay(2000);
esp.print("Received Error \n EXIT1:");
return;
// cmd = "GET /update?key=https://api.thingspeak.com/update?api_key=KZQ30BI64ZOLF9CY&field1=" + T + "&field2=" + P + "\r\n";
cmd="GET /update?key=KZQ30BI64ZOLF9CY&field1="+T+"&field2="+P+"\r\n"; // update the temprature and humidity values on thingspeak url,replace xxxxxxx with your write api key
Serial.print("AT+CIPSEND=");
Serial.println(cmd.length());
if (Serial.find(">")) {
esp.print(">");
esp.print(cmd);
Serial.print(cmd);
else {
sendAT("AT+CIPCLOSE");
esp.println("Received : Error \n EXIT2");
