WiFi.config() allows you to configure a static IP address as well as change the DNS, gateway, and subnet addresses on the WiFi shield.
Unlike WiFi.begin() which automatically configures the WiFi shield to use DHCP, WiFi.config() allows you to manually set the network address of the shield.
Calling WiFi.config() before WiFi.begin() forces begin() to configure the WiFi shield with the network addresses specified in config().
You can call WiFi.config() after WiFi.begin(), but the shield will initialize with begin() in the default DHCP mode. Once the config() method is called, it will change the network address as requested.
There seems to be something else going on, as the static IP does not work to talk with the ESP-8266.
