I am not use the standard arduino board, I use the board from other manufacture which is cheaper.
But I got Some problems when I Want to fix the ip.
Everything works fine when I use the example of the web server in arduino IDE:
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
But it always return the random IP Which is hard to handle.
So I check this link : Fixed IP with ESP8266WiFi · Issue #1959 · esp8266/Arduino · GitHub
And make my code to:
// config static IP
IPAddress ip(192, 168, 1, 200); // where xx is the desired IP Address
IPAddress gateway(192, 168, 1, 1); // set gateway to match your network
Serial.print(F("Setting static ip to : "));
Serial.println(ip);
IPAddress subnet(255, 255, 255, 0); // set subnet mask to match your network
WiFi.config(ip, gateway, subnet);
But is not worked when I connect the url: http://192.168.1.200/gpio/0
So can anyone tell me why this happened? It is related to my board is not standard?
I get it from a youtuber recommand.
Here is my all code :
This sketch demonstrates how to set up a simple HTTP-like server.
The server will set a GPIO pin depending on the request
http://server_ip/gpio/0 will set the GPIO2 low,
http://server_ip/gpio/1 will set the GPIO2 high
server_ip is the IP address of the ESP8266 module, will be
printed to Serial when the module is connected.
#include <ESP8266WiFi.h>
#ifndef STASSID
#define STASSID "HUAWEI-WQAB58"
#define STAPSK "fighttilldie"
#endif
const char* ssid = STASSID;
const char* password = STAPSK;
// Create an instance of the server
// specify the port to listen on as an argument
WiFiServer server(80);
// prepare LED
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, 0);
// Connect to WiFi network
Serial.print(F("Connecting to "));
Serial.println(ssid);
// config static IP
Serial.println(ip);
Serial.print(F("."));
Serial.println(F("WiFi connected"));
// Start the server
server.begin();
Serial.println(F("Server started"));
// Print the IP address
// Check if a client has connected
WiFiClient client = server.available();
if (!client) {
return;
Serial.println(F("new client"));
client.setTimeout(5000); // default is 1000
// Read the first line of the request
String req = client.readStringUntil('\r');
Serial.println(F("request: "));
Serial.println(req);
// Match the request
int val;
if (req.indexOf(F("/gpio/0")) != -1) {
val = 0;
} else if (req.indexOf(F("/gpio/1")) != -1) {
val = 1;
Serial.println(F("invalid request"));
val = digitalRead(LED_BUILTIN);
// Set LED according to the request
digitalWrite(LED_BUILTIN, val);
// read/ignore the rest of the request
// do not client.flush(): it is for output only, see below
while (client.available()) {
// byte by byte is not very efficient
client.read();
// Send the response to the client
// it is OK for multiple small client.print/write,
// because nagle algorithm will group them into one single packet
client.print(F("HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n<!DOCTYPE HTML>\r\n<html>\r\nGPIO is now "));
client.print((val) ? F("high") : F("low"));
client.print(F("
Click <a href='http://"));
client.print(WiFi.localIP());
client.print(F("/gpio/1'>here</a> to switch LED GPIO on, or <a href='http://"));
client.print(F("/gpio/0'>here</a> to switch LED GPIO off.</html>"));
// The client will actually be *flushed* then disconnected
// when the function returns and 'client' object is destroyed (out-of-scope)
// flush = ensure written data are received by the other side
Serial.println(F("Disconnecting from client"));
