using : esp8266 (nodemcu) and uhf-rfid
I am trying to send data from UHF-RFID to firebase using 'Firebase_ESP_Client.h' and 'Wiegand' libraries in the following links,
they both worked well in their examples,
I followed this code: from (ESP8266 NodeMCU: Getting Started with Firebase (Realtime Database) | Random Nerd Tutorials)
#include <Arduino.h>
#if defined(ESP32)
#include <WiFi.h>
#elif defined(ESP8266)
#include <ESP8266WiFi.h>
#endif
#include <Firebase_ESP_Client.h>
//Provide the token generation process info.
#include "addons/TokenHelper.h"
//Provide the RTDB payload printing info and other helper functions.
#include "addons/RTDBHelper.h"
// Insert your network credentials
#define WIFI_SSID "REPLACE_WITH_YOUR_SSID"
#define WIFI_PASSWORD "REPLACE_WITH_YOUR_PASSWORD"
// Insert Firebase project API Key
#define API_KEY "REPLACE_WITH_YOUR_FIREBASE_PROJECT_API_KEY"
// Insert RTDB URLefine the RTDB URL */
#define DATABASE_URL "REPLACE_WITH_YOUR_FIREBASE_DATABASE_URL"
//Define Firebase Data object
FirebaseData fbdo;
FirebaseAuth auth;
FirebaseConfig config;
unsigned long sendDataPrevMillis = 0;
int count = 0;
bool signupOK = false;
void setup(){
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
Serial.print("Connecting to Wi-Fi");
while (WiFi.status() != WL_CONNECTED){
Serial.print(".");
delay(300);
Serial.print("Connected with IP: ");
/* Assign the api key (required) */
config.api_key = API_KEY;
/* Assign the RTDB URL (required) */
config.database_url = DATABASE_URL;
/* Sign up */
if (Firebase.signUp(&config, &auth, "", "")){
Serial.println("ok");
signupOK = true;
else{
Serial.printf("%s\n", config.signer.signupError.message.c_str());
/* Assign the callback function for the long running token generation task */
config.token_status_callback = tokenStatusCallback; //see addons/TokenHelper.h
Firebase.begin(&config, &auth);
Firebase.reconnectWiFi(true);
void loop(){
if (Firebase.ready() && signupOK && (millis() - sendDataPrevMillis > 15000 || sendDataPrevMillis == 0)){
sendDataPrevMillis = millis();
// Write an Int number on the database path test/int
if (Firebase.RTDB.setInt(&fbdo, "test/int", count)){
Serial.println("PASSED");
Serial.println("PATH: " + fbdo.dataPath());
Serial.println("TYPE: " + fbdo.dataType());
else {
Serial.println("FAILED");
Serial.println("REASON: " + fbdo.errorReason());
count++;
// Write an Float number on the database path test/float
if (Firebase.RTDB.setFloat(&fbdo, "test/float", 0.01 + random(0,100))){
else {
and this code from (Wiegand-Protocol-Library-for-Arduino/WiegandTest.ino at master · monkeyboard/Wiegand-Protocol-Library-for-Arduino · GitHub)
#include <Wiegand.h>
WIEGAND wg;
// default Wiegand Pin 2 and Pin 3 see image on README.md
// for non UNO board, use wg.begin(pinD0, pinD1) where pinD0 and pinD1
// are the pins connected to D0 and D1 of wiegand reader respectively.
wg.begin();
if(wg.available())
Serial.print("Wiegand HEX = ");
Serial.print(wg.getCode(),HEX);
Serial.print(", DECIMAL = ");
Serial.print(wg.getCode());
Serial.print(", Type W");
Serial.println(wg.getWiegandType());
what I found is, when I call wg.getCode() inside 'Firebase.RTDB.setInt(&fbdo, "test/code", wg.getCode() )'
I tried to do this :
void loop(){
if (wg.available())
int x = wg.getCode();
Serial.print(x);
y = String(x);
sendDataPrevMillis = millis();}
if (Firebase.RTDB.setString(&fbdo, "test/int", y )){
else {
Serial.println("REASON: " + fbdo.errorReason()); }}
did not work, I am sorry that I dont share the full script due to several scripts that I have open for testing ,, most sensors worked well ( temprature and gps ..etc) only we Wiegand didnot , from my test I assume the problem resides in the void loop section
becase when I write the previous code like:
while(wg.available()){
if (Firebase.RTDB.setInt(&fbdo, "tags/id", wg.getCode())){
else {
it connects to firebase as normal, but does not read from the RFID to the firebase
