I want to control a relay using firebase and esp8266 can someone say which lib is best for this I try many but each lib have problem
Please suggest me lib for esp8266
What have you tried? What were the results? Show your work.
#include <ESP8266WiFi.h>
#include <FirebaseArduino.h>
#define FIREBASE_HOST "@@@@@@@@@@@@@@@@" // Replace with your Firebase Host URL
#define FIREBASE_AUTH "@@@@@@@@@@@" // Replace with your Firebase Auth Token
#define WIFI_SSID "................" // Replace with your WiFi SSID
#define WIFI_PASSWORD "@@@@" // Replace with your WiFi Password
// Connect to Wi-Fi
Serial.print("Connecting to WiFi");
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
Serial.print(".");
Serial.print("Connected to WiFi, IP address: ");
// Connect to Firebase
Serial.print("Connecting to Firebase");
Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH);
// Test writing to Firebase
Firebase.setFloat("test/path", 123.45);
if (Firebase.failed()) {
Serial.print("Failed to write to Firebase: ");
Serial.println(Firebase.error());
return;
Serial.println("Successfully wrote to Firebase.");
// Test reading from Firebase
float value = Firebase.getFloat("test/path");
Serial.print("Failed to read from Firebase: ");
return;
Serial.print("Read value from Firebase: ");
Serial.println(value);
// Empty loop
problem is firebase not connected to to my node mcu no any compile error my node mcu keep resetting
Show the compile results, which might have clues.
Is this just the board, or are devices connected by wires?
now it working i just was used wrong lib
now i nam using
https://github.com/mobizt/Firebase-ESP-Client
Is this using the FirebaseArduino library?
And it's working fine as my expectations
