i'm working now with nodeMCU as a sender and ESP32 as receiver , I will add another 3 nodemcus that will send data to ESP32
The case is each NodeMCU packet will be different , but in the same time I need in the receiver to define the message that will arrive from the sender, and every tutorial I saw works with same message structure,
is there a way to be somewhat dynamic?
these are example for the first sender and the receiver
I want to add another nodeMCU sender which will send
typedef struct message {
char peerId;
int mositure; // must be unique for each sender board
int EC;
receiver :
#include <Arduino.h>
#include <WiFi.h>
#include <esp_now.h>
char peerId;
int flowRate; // must be unique for each sender board
int totalLitres;
typedef struct flow_meter {
char peerId;
int totalLitres;
} flow_meter;
struct flow_meter myMessage;
void onDataReceiver(const uint8_t * mac, const uint8_t *incomingData, int len) {
Serial.println("Message received.");
// We don't use mac to verify the sender
// Let us transform the incomingData into our message structure
memcpy(&myMessage, incomingData, sizeof(myMessage));
Serial.println("=== Data ===");
Serial.print("Mac address: ");
for (int i = 0; i < 6; i++) {
Serial.print("0x");
Serial.print(mac[i], HEX);
Serial.print(":");
/*Serial.println("*******");
Serial.print(incomingData.peerId);
Serial.println("*********");*/
Serial.print("\n\npeerId: ");
Serial.print(myMessage.peerId);
Serial.print("\n\nflowRate: ");
Serial.println(myMessage.flowRate);
Serial.print("\n\ntotalLitres: ");
Serial.println(myMessage.totalLitres);
WiFi.mode(WIFI_STA);
// Get Mac Add
Serial.print("Mac Address: ");
Serial.print(WiFi.macAddress());
Serial.println("ESP32 ESP-Now Broadcast");
// Initializing the ESP-NOW
if (esp_now_init() != 0) {
Serial.println("Problem during ESP-NOW init");
return;
esp_now_register_recv_cb(onDataReceiver);
sender :
* ESP-NOW
* Sender
#include <ESP8266WiFi.h>
#include <espnow.h>
#include <SPI.h>
uint8_t peer1[] = {0x24, 0x62, 0xAB, 0xFF, 0x2C, 0x5C};
typedef struct struct_message {
char peerId;
int totalLitres;
} struct_message;
struct struct_message myMessage;
// Initialize DHT sensor.
void onSent(uint8_t *mac_addr, uint8_t sendStatus) {
Serial.print("Last Packet Send Status: ");
if (sendStatus == 0){
Serial.println("Delivery success");
else{
Serial.println("Delivery fail");
myMessage.peerId = 'w';
// Get Mac Add
Serial.println("ESP-Now Sender");
return;
esp_now_set_self_role(ESP_NOW_ROLE_CONTROLLER);
// Register the peer
Serial.println("Registering a peer");
esp_now_add_peer(peer1, ESP_NOW_ROLE_SLAVE, 1, NULL, 0);
Serial.println("Registering send callback function");
esp_now_register_send_cb(onSent);
myMessage.flowRate = 33;
myMessage.totalLitres = 90000/1000;
Serial.println("Send a new message");
esp_now_send(NULL, (uint8_t *) &myMessage, sizeof(myMessage));
delay(3000);
