ESP-NOW on 8266 with many to one setup
Hi all,
I have been using ESP-NOW for a while with one to one and one to many options. Now I decided to make a project with multiple 8266 boards and I would like to send different data from multiple boards to one receiver. I would like to separate the different incoming data on the receiver side.
I've read a lot about it, but I got stuck with it. It is working if I send the same data form all of the boards, but it isn't when I send different.
I use this tutorial to setup the ESP-NOW for many to one.
ESP-NOW: Receive Data from Multiple ESP8266 Boards (many-to-one) | Random Nerd Tutorials
The thing that I don't understand is in the receiver code, when it call the callback function.
It is from the tutorial, what should I change in the code in order to I could receive different types of data?
void OnDataRecv(uint8_t * mac_addr, uint8_t *incomingData, uint8_t len) {
  char macStr[18];
  Serial.print("Packet received from: ");
  snprintf(macStr, sizeof(macStr), "%02x:%02x:%02x:%02x:%02x:%02x",
           mac_addr[0], mac_addr[1], mac_addr[2], mac_addr[3], mac_addr[4], mac_addr[5]);
  Serial.println(macStr);
  memcpy(&myData, incomingData, sizeof(myData));
  Serial.printf("Board ID %u: %u bytes\n", myData.id, len);
  // Update the structures with the new incoming data
  boardsStruct[myData.id-1].x = myData.x;
  boardsStruct[myData.id-1].y = myData.y;
  Serial.printf("x value: %d \n", boardsStruct[myData.id-1].x);
  Serial.printf("y value: %d \n", boardsStruct[myData.id-1].y);
I would like to make a network like in the picture.
Thank you for answers in advance!
you need to have some means of identifing the different message types, e.g.
typedef struct struct_message {
  int type;
  float c;
} struct_message;
typedef struct struct_message2 {
  int type;
  String s;
} struct_message2;
// Create a struct_message called myData
struct_message myData;
struct_message2 myData2;
the structures start with an int called type which will be used to identify the message type, e.g. containing a float or a string
the transmitter would set up the type and the data float (type 0) or string (type 1), e.g.
  if ((millis() - lastTime) > timerDelay) {
    static int type = 0;
    if(type == 0) {
      // Set values to send
      myData.type = type;
      myData.c = 1.2 + random(1,20);
      type=1;
      // Send message via ESP-NOW
      esp_now_send(broadcastAddress, (uint8_t *) &myData, sizeof(myData));
    else {
      myData2.type = type;
      Serial.print("Enter a string ? ");
      myData2.s = Serial.readStringUntil('\n');     // <<<< read string
      type=0;
      esp_now_send(broadcastAddress, (uint8_t *) &myData2, sizeof(myData2));
    lastTime = millis();
and the receiver when it received a message would look at the type and then extract data either float (type 0) or string (type 1)
// Callback function that will be executed when data is received
void OnDataRecv(uint8_t * mac, uint8_t *incomingData, uint8_t len) {
  Serial.print("Bytes received: ");
  Serial.println(len);
  int type;
  memcpy(&type, incomingData, sizeof(int));
  Serial.print("type: ");
  Serial.println(type);
  if(type == 0){
      Serial.print("Float: ");
      Serial.println(myData.c);
  else {
      memcpy(&myData2, incomingData, sizeof(myData2));
      Serial.print("String: ");
      Serial.println(myData2.s);
the transmitter alternates sending a float (type 0) then a string (type 1) etc etc in loop()
here is a run of the receiver
ESP-NOW initialised
Bytes received: 16
type: 1
String: hello joe
Bytes received: 8
type: 0
Float: 11.20
Bytes received: 16
type: 1
String: rrr
Bytes received: 8
type: 0
Float: 20.20
It's working in this way. Thanks a lot! :slight_smile:
