//Esp_now_NodeMcu_M_S1A2B_en_4
//based on sketch Esp_now_NodeMcu_M_S1A2B_po_3
//sketch of Master station what can simply communicate
//with two Slave stations A a B (1 a 2) via ESP-NOW system
based on projects and guidance by Rui Santos
Complete project details at https://RandomNerdTutorials.com/esp-now-two-way-communication-esp8266-nodemcu/
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files.
The above copyright notice and this permission notice shall be included in all
copies or substantial portions of the Software.
#include <ESP8266WiFi.h>
#include <espnow.h>
String masterName = "Esp_now_NodeMcu_M_S1A2B_en_4";
String slaveNameA = "NodeMcu S1A-M NodeMcu V1.0 ECG AD8232";
String slaveNameB = "Wemos S2B-M Wemos D1 R1 BPM HW-827";
String slaveName = "";
String boardMacAddress = "?";
int slaveNumber = 1; // A = 1, B = 2;
// REPLACE WITH THE MAC Address of your receivers or sender
//uint8_t broadcastAddress[] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF}; // example of not used mac address
//uint8_t broadcastAddress[] = {0xEC, 0xFA, 0xBC, 0xC9, 0x65, 0x17}; // ESP-now - master V1(3) NodeMcu V0.9 ESP-12
//uint8_t slaveMacAddress[] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF}; // example of not used mac address
//ESP-now - slave A NodeMcu V1.0 ESP-12E
uint8_t slaveMacAddressA[] = {0x84, 0xCC, 0xA8, 0x97, 0xEE, 0x08}; // ESP-now - slave A NodeMcu V1.0 ESP-12E
//ESP-now - slave B Wemos D1 R1 Lolin mac address 48:55:19:17:1C:50
uint8_t slaveMacAddressB[] = {0x48, 0x55, 0x19, 0x17, 0x1C, 0x50}; // ESP-now - slave B Wemos D1 R1 ESP-12
byte dataAcommand;
byte dataAstatus;
unsigned int dataAindex;
byte dataA1;
unsigned int dataA2;
unsigned int dataA3;
byte dataA4;
//Structure example to send data
//Must match in the receiver structure
typedef struct struct_message
byte dataCommand;
byte data1; //dataStep
unsigned int data2; //dataNumber or dataIndex
unsigned int data3; //data or time
byte data4; //dataOffset
} struct_message;
// Create a struct_message called espReadMessage to hold sensor readings
struct_message espReadMessage;
// Create a struct_message called espSendMessage to hold sensor readings
struct_message espSendMessage;
unsigned int greenLED = 15; // D8 = Green led
int yellowLED = 13; // D7 = Yellow led
int redLED = 12; // D6 = Red led
int analogPin = 0; // ADC0 = A0
bool dataSendOK = false;
bool dataReceivedOK = false;
bool espnowOK = false;
unsigned int espWaitTime = 100;
int espWaitTimeStepDown = 100;
unsigned int dataOsc;
unsigned int dataOscOffset = 0;
unsigned int dataOscArray[401];
unsigned int dataPocetOscMax = 401;
unsigned int dataPocetOsc = 401;
bool dataStopOn = false;
int LoPlus = 300; //not used in this sketch
int LoMinus = 200;
int dataPar[6]; // 0=not used, dataStep, dataPocetOsc, 3=dataTime, 4=dataOscOffset,
// 5=dataPocetOscMax,
unsigned long timeStart = 0;
byte loopMode = 0;
int I = 0;
int J = 0;
bool menuOn = false;
char markRx = 0;
byte dataStep = 20;
unsigned int dataTime = 0;
bool serialPrintOn = false;
void PrintEspSendMessage()
// Print Esp sended message in Serial Monitor
Serial.println("ESP send data :");
Serial.print("Command: ");
Serial.print(dataAcommand);
Serial.print(", A1: ");
Serial.print(dataA1);
Serial.print(", A2: ");
Serial.print(dataA2);
Serial.print(", A3: ");
Serial.print(dataA3);
Serial.print(", A4: ");
Serial.println(dataA4);
void PrintEspReadMessage()
// Print Esp readed message in Serial Monitor
Serial.println("ESP readed data:");
Serial.print(", Status: ");
Serial.print(dataAstatus);
Serial.print(", Index: ");
Serial.print(dataAindex);
void LoadSendMessage()
espSendMessage.dataCommand = dataAcommand;
espSendMessage.data1 = dataA1;
espSendMessage.data2 = dataA2;
espSendMessage.data3 = dataA3;
espSendMessage.data4 = dataA4;
// Callback when data is sent
void OnDataSent(uint8_t *mac_addr, uint8_t sendStatus)
if (sendStatus == 0)
dataSendOK = true;
if (serialPrintOn)
Serial.print("Last Packet Send Status: ");
Serial.println("Delivery success");
if (dataAcommand == 75) // K set number of slave station
dataSendOK = true;
Serial.println("*K,0,#,");
if (serialPrintOn)
Serial.println("Delivery failed");
loopMode = 0;
// Callback when data is received
void OnDataRecv(uint8_t * mac, uint8_t *espReadData, uint8_t len)
//memcpy(&incommingMessage, incommingData, sizeof(incommingMessage));
memcpy(&espReadMessage, espReadData, sizeof(espReadMessage));
if (serialPrintOn)
Serial.print("Bytes received: ");
Serial.println(len);
dataAcommand = espReadMessage.dataCommand;
dataA1 = espReadMessage.data1;
dataA2 = espReadMessage.data2;
dataA3 = espReadMessage.data3;
dataA4 = espReadMessage.data4;
if (serialPrintOn)
PrintEspReadMessage();
if (dataAcommand == 65) // A command serial
dataAstatus = 0;
dataAindex = 1;
loopMode = 7;
if (dataAcommand == 66) // B command serial in cycle
dataAstatus = 1;
dataAindex = dataAindex + 1;
loopMode = 7;
if (dataAcommand == 67) // C command serial in cycle
dataAstatus = 1;
loopMode = 7;
if (dataAcommand == 68) // D command for direct plotter
dataAstatus = 1;
loopMode = 7;
loopMode = 7;
if (dataAcommand == 85) // received data from memoey
dataAstatus = 1;
dataAindex = dataA2;
dataOscArray[dataAindex] = dataA3;
loopMode = 7;
if (dataAcommand == 77) // confirmed measuring data to to slave memory
dataAstatus = 0;
dataPar[1] = dataA1;
dataPar[2] = dataA2;
dataPar[3] = dataA3;
dataPar[4] = dataA4;
dataAindex = 0;
dataA2 = dataPar[2];
dataA3 = 0;
loopMode = 7;
if (dataAcommand == 78) // start receiving data fro slave memorz
dataAstatus = 1;
dataAindex = 0;
loopMode = 7;
if (dataAcommand == 80) // readed set of parameters for measuring
dataAstatus = 0;
loopMode = 7;
if (dataAcommand == 83) // stop for reading data in cycles with parameters
dataAstatus = 0;
dataStopOn = true;
loopMode = 7;
dataReceivedOK = true;
// Init Serial Monitor
Serial.println(masterName);
pinMode(analogPin, INPUT);
pinMode(greenLED, OUTPUT);
digitalWrite(greenLED, HIGH);
delay(2000);
digitalWrite(greenLED, LOW);
pinMode(yellowLED, OUTPUT);
digitalWrite(yellowLED, HIGH);
delay(2000);
digitalWrite(yellowLED, LOW);
pinMode(redLED, OUTPUT);
digitalWrite(redLED, HIGH);
delay(2000);
digitalWrite(redLED, LOW);
menuOn = true; //on-line verze
//menuOn = false; // run version
slaveNumber = 1;
I = 1;
dataPar[0] = 0;
dataStep = 20;
dataPar[1] = dataStep;
dataPocetOsc = 401;
dataPar[2] = dataPocetOsc-1;
dataTime = 0;
dataPar[3] = dataTime;
dataOscOffset = 0;
dataPar[4] = dataOscOffset;
dataPar[5] = dataPocetOscMax-1;
espWaitTime = 100;
dataAcommand = 0;
dataAstatus = 0;
//dataNindex = 0;
serialPrintOn = true;
loopMode = 0; // 0 = idle menu, 1+2+3 etc. = master menu,
dataSendOK = true;
// Set device as a Wi-Fi Station
boardMacAddress = WiFi.macAddress();
Serial.print("ESP Master Board MAC Address: ");
Serial.println(boardMacAddress);
WiFi.mode(WIFI_STA);
WiFi.disconnect();
// Init ESP-NOW
if (esp_now_init() != 0)
Serial.println("Error initializing ESP-NOW !");
espnowOK = false;
//return;
Serial.println("Initializing ESP-NOW OK !");
espnowOK = true;
if (espnowOK)
// Set ESP-NOW Role
esp_now_set_self_role(ESP_NOW_ROLE_COMBO);
// Once ESPNow is successfully Init, we will register for Send CB to
// get the status of Trasnmitted packet
esp_now_register_send_cb(OnDataSent);
// Register peer
if (slaveNumber==1)
esp_now_add_peer(slaveMacAddressA, ESP_NOW_ROLE_COMBO, 1, NULL, 0);
if (slaveNumber==2)
esp_now_add_peer(slaveMacAddressB, ESP_NOW_ROLE_COMBO, 1, NULL, 0);
// Register for a callback function that will be called when data is received
esp_now_register_recv_cb(OnDataRecv);
void PrintMenuEsp()
//ESP-NOW test
if (!espnowOK)
Serial.println("Error in initializing ESP-NOW !");
Serial.print("Master Staion Name: ");
Serial.print("Master Mac Address: ");
Serial.print("Slave Number: ");
Serial.println(slaveNumber);
if (slaveNumber==1)
slaveName = slaveNameA; // test
if (slaveNumber==2)
slaveName = slaveNameB; // test
Serial.print("Slave Name: ");
Serial.println(slaveName);
Serial.print("Data to/from Esp-now-two-way master station ");
Serial.println("Menu :");
Serial.println("I=Station info");
Serial.println("A=data test out (*A,data,#,), B=print data for serial (*B,data,#,)CRLF");
Serial.println("C=Data print for serial (*,data,#,)CRLF D=Data for plotter (data)CRLF");
Serial.println("Exx=Pause(ms), Lxxx=Nr of data to memory, Oxxx=Ofset of data,");
Serial.println("F=Serial Print On, Q=Serial Print Off, S=Data in cycle Stop");
Serial.println("G=Yellow LED On, H=Red LED On, J=GreenLed On test");
Serial.println("Kx=slave station number, slaveNumber=1 (A=NodeMcu), slaveNumber=2 (B=Wemos),");
Serial.println("M=Meas data into slave Esp memory, N=read data from slave Esp memory,");
Serial.println("P=read set of parameters, R=read parameters, Txxx=Esp wait time");
Serial.print("SerialPrintOn = ");
Serial.println(serialPrintOn);
dataSendOK = true;
menuOn = false;
if (menuOn == true)
PrintMenuEsp();
if (Serial.available())
markRx = Serial.read();
if (markRx == 65) // A - read one data example *A,data,#,CRLF
dataAcommand = 65;
dataA1 = 0;
loopMode = 1;
//markRx = 0;
if (markRx == 66) // B - read data in cycle example *B,data,#,CRLF
dataStopOn = false;
dataAindex = 0;
dataAstatus = 1;
dataStep = dataPar[1];
dataPocetOsc = dataPar[2]+1;
dataTime = 0;
dataOscOffset = dataPar[4];
dataAcommand = 66;
dataA1 = dataStep;
dataA2 = dataAindex;
dataA3 = 0;
dataA4 = dataOscOffset;
timeStart = millis();
loopMode = 1;
if (markRx == 67) // C data example *,100,#,CRLF
// c - Vypisuje merena data anlog from slave
//digitalWrite(greenLED, HIGH);
dataAcommand = 67;
dataAindex = 1;
dataStopOn = false;
dataAstatus = 1;
dataPar[3] = 0;
dataTime = dataPar[3];
dataA1 = dataStep;
dataA3 = dataTime;
loopMode = 1;
if (markRx == 68) // D - outgoing analog data from slave for plotter example dataCRLF
dataAcommand = 68;
dataAindex = 1;
dataAstatus = 1;
dataStopOn = false;
if (serialPrintOn)
Serial.print("D data for plotter start = ");
Serial.println(dataAindex);
dataTime = 0;
dataPar[3] = 0;
dataA1 = dataStep;
dataA3 = dataTime;
loopMode = 1;
if ( markRx == 69 ) // E - Exx - xx is data step in ms
String pomString = Serial.readString();
//pomString.trim();
dataStep = pomString.toInt();
if (serialPrintOn)
Serial.print("Data step = ");
Serial.println(dataStep);
markRx = 80; // answeres as R = parameters print out
if (markRx == 70) // F - Serial Print On
menuOn = true;
Serial.println("F - Serial Print is On !");
PrintMenuEsp();
dataAcommand = 70;
dataAstatus = 0;
loopMode = 1;
if (markRx == 71) // G - set yellow Led On
if (serialPrintOn)
Serial.println("Yellow Led is light on !");
dataAcommand = 71;
dataAstatus = 0;
loopMode = 1;
if (markRx == 72) // H - set Red Led On
if (serialPrintOn)
Serial.println("Red Led is light On !");
dataAcommand = 72;
dataAstatus = 0;
loopMode = 1;
if ( markRx == 73) // I - info
if (serialPrintOn)
Serial.print("*I,");
Serial.print(masterName);
Serial.print(",");
Serial.print(slaveName);
Serial.println(",#,");
Serial.print(slaveNumber);
dataAcommand = 73;
dataAstatus = 0;
loopMode = 0;
if (markRx == 74) // J - set green Led On
if (serialPrintOn)
Serial.println("Green led is light on !");
dataAcommand = 74;
dataAstatus = 0;
loopMode = 1;
if ( markRx == 75 ) // Kx - choose of slave station : 1 = A, 2 = B"
slaveNumber = pomString.toInt();
if (serialPrintOn)
Serial.print("slaveNumber = ");
if (espnowOK)
// Set ESP-NOW Role
// Register peer
if (slaveNumber==1)
dataAcommand = 75;
loopMode = 1;
if (slaveNumber==2)
dataAcommand = 75;
loopMode = 1;
if (serialPrintOn)
loopMode = 0;
if ( markRx == 76 ) // L - number of data saved to or readed from slave memory
dataPocetOsc = pomString.toInt();
dataPocetOsc = dataPocetOsc + 1;
if (dataPocetOsc > dataPocetOscMax)
if (serialPrintOn)
Serial.print("dataPocetOsc max = ");
Serial.print(dataPocetOscMax-1);
Serial.println(" !");
dataPocetOsc = dataPocetOscMax;
if (serialPrintOn)
Serial.print("Data pocet Osc = ");
Serial.println(dataPocetOsc-1);
markRx = 80; // R = parameters print out
if ( markRx == 77 ) // M - confirm command M and record data to slave memory
dataAcommand = 77;
dataPar[3] = 0;
Serial.print("*M,");
Serial.print(dataPar[1]);
Serial.print(",");
Serial.print(dataPar[2]);
Serial.print(",");
Serial.print(dataPar[3]);
Serial.print(",");
Serial.print(dataPar[4]);
dataAstatus = 0;
loopMode = 1;
if ( markRx == 78 ) // N - start reading of data from slave memory
dataAcommand = 78;
dataAstatus = 1;
loopMode = 1;
if ( markRx == 79 ) // O - data offset
dataOscOffset = pomString.toInt();
if (dataOscOffset > 250) // byte
if (serialPrintOn)
Serial.print("data offset max = ");
Serial.print(250);
dataOscOffset = 250;
if (serialPrintOn)
Serial.print("Data offset = ");
Serial.println(dataOscOffset);
markRx = 80;
if (markRx == 80) // P = parametry
dataAcommand = 80; // - save parameters to slave
dataAstatus = 0;
dataAindex = 0;
dataA1 = dataPar[1]; //data Step
dataA2 = dataPar[2]; //data number
dataA3 = dataPar[5]; //dataPocetOscMax
dataA4 = dataPar[4]; //data offset
if (serialPrintOn)
Serial.print("P Parameters: Step = ");
Serial.print(", Nr Osc Buffer = ");
Serial.print(", Nr Osc Buffer Max = ");
Serial.print(", Offset = ");
Serial.print("*P,");
Serial.print(",");
Serial.print(",");
Serial.print(",");
Serial.print(dataA4);
Serial.print(",");
Serial.println("#,");
loopMode = 1;
if (markRx == 81) // Q = print data off
if (serialPrintOn)
Serial.println("Serial print is off !");
dataAcommand = 81;
dataAstatus = 0;
dataStep = dataPar[1]; //data Step
dataPocetOsc = dataPar[2]+1; //data pocet
dataTime = dataPar[3]; //data time
dataOscOffset = dataPar[4]; //data offset
dataA1 = dataStep; //data Step
dataA2 = dataPocetOsc-1; //data pocet
dataA3 = dataPocetOscMax-1;
dataA4 = dataOscOffset; //data offset
Serial.print("*Q,");
Serial.print(dataStep);
Serial.print(",");
Serial.print(dataPocetOsc-1);
Serial.print(",");
Serial.print(",");
Serial.print(dataOscOffset);
loopMode = 1;
if (markRx == 82) // R = read parameters
dataAstatus = 0;
dataAindex = 0;
dataA2 = dataPar[2]; //data Number
dataA3 = dataPar[3]; //data time
if (serialPrintOn)
Serial.print("R Parameters: Step = ");
Serial.print(", Nr of data = ");
Serial.print(", dataTime = ");
Serial.print("*R,"); // confirm R command and repeated last measured time
Serial.print(",");
Serial.print(",");
Serial.print(",");
Serial.print(",");
loopMode = 1;
if (markRx == 83) // S = stop of data transfer
dataStopOn = true;
dataAcommand = 83;
dataAstatus = 0;
loopMode = 1;
if ( markRx == 84 ) // Txxx - espWaitTime
espWaitTime = pomString.toInt();
if (serialPrintOn)
Serial.print("espWaitTime = ");
Serial.println(espWaitTime);
dataAcommand = 84;
dataAstatus = 0;
loopMode = 1;
Serial.flush();
markRx = 0;
} // end of Serial Available
if (loopMode == 0)
if (loopMode == 1) //loop will send data etc.
//dataSendOK = true;
if (serialPrintOn)
Serial.print("loopMode = ");
Serial.print(loopMode);
Serial.print(", dataAcommand = ");
Serial.println(dataAcommand);
if (dataAcommand == 65) // A - slave data test send
dataAstatus = 0;
dataAindex = 1;
dataTime = 0;
dataPar[3] = 0;
dataA1 = 0;
dataA2 = dataPar[2]; //data pocet
loopMode = 2;
if ((dataAcommand == 66) || (dataAcommand == 67) || (dataAcommand == 68))
// these commands send data in cycle
dataTime = 0;
dataPar[3] = 0;
dataA1 = dataPar[1]; //data step
if (dataAcommand == 66) // B - master ask slave data to send in cycle
if (dataSendOK)
dataAstatus = 1;
if (serialPrintOn)
Serial.print("B asked data in loopmode = 1 dataAindex = ");
loopMode = 2;
if (serialPrintOn)
Serial.println("w,");
if (dataAcommand == 67) // C - master ask slave to send data in cycle
if (dataSendOK)
dataAstatus = 1;
if (serialPrintOn)
Serial.print("C asked data in loopmode = 1 dataAindex = ");
loopMode = 2;
if (serialPrintOn)
Serial.print("w,");
if (dataAcommand == 68) // D - master ask slave to send data for plotter in cycle
if (dataSendOK)
dataAstatus = 1;
if (serialPrintOn)
Serial.print("D master asked data in loopmode = 1 dataAindex = ");
loopMode = 2;
if (serialPrintOn)
if (dataAcommand == 70) // F - slave data print on
dataAstatus = 0;
dataAindex = 0;
dataA1 = dataPar[1]; // slave print on
loopMode = 2;
if (dataAcommand == 71) // G = Yellow led is On
dataAstatus = 0;
dataAindex = 0;
dataA1 = dataPar[1]; // Yellow led is On
loopMode = 2;
if (dataAcommand == 72) // H = Red led is On
dataAstatus = 0;
dataAindex = 0;
dataA1 = dataPar[1]; // Red led is On
loopMode = 2;
if (dataAcommand == 73) // I - station name
dataAstatus = 0;
//dataAindex = 0;
dataA1 = dataPar[1]; // this A slave station
dataA3 = slaveNumber; // slave number
loopMode = 2;
if (dataAcommand == 74) // J / Green led is On
dataAstatus = 0;
dataAindex = 0;
dataA1 = dataPar[1]; // Green led is On
loopMode = 2;
dataAstatus = 0;
dataAindex = 0;
dataA1 = dataPar[1]; // dataStep
dataA2 = dataPar[2]; //data Nr
dataA3 = slaveNumber; //number of slave station
loopMode = 2;
if (dataAcommand == 77) // M - command foe measuring and saving data to slave memory
dataAstatus = 0;
dataAindex = 0;
dataPar[3] = dataA1 * dataA2; //expected data time
dataA3 = dataPar[3]; //data time start
//espParOn = true;
//espOscOn = false;
loopMode = 2;
if (dataAcommand == 78) // N command for reading and sending slave data from its memory
dataAstatus = 1;
dataAindex = 0;
dataPar[3] = dataA1 * dataA2; //zero to data time
loopMode = 2;
if (dataAcommand == 80) // P - set parameters to slave
dataAstatus = 0;
dataAindex = 0;
loopMode = 2;
if (dataAcommand == 81) // Q - serialPrintOn
dataAstatus = 0;
dataAindex = serialPrintOn;
dataA1 = 0; //data Step
loopMode = 2;
if (dataAcommand == 83) // S - data transfer stop
dataAstatus = 0;
dataA1 = dataStep;
dataA2 = dataAindex; // Nr of all data sended
dataTime = millis() - timeStart; // time of all data were transfered
dataA3 = dataTime;
loopMode = 2;
if (dataAcommand == 84) // T - espWaitTime
dataAstatus = 0;
dataAindex = 0;
dataA3 = espWaitTime; //wait time when sendDataOK are false
loopMode = 2;
if (dataAcommand == 85) // read data from slave memory of dataAindex
dataAstatus = 1;
dataA1 = dataStep;
dataA2 = dataAindex; //asked from slave data from memory according of dataAindex
dataA3 = 0;
loopMode = 2;
if (dataAcommand == 0) // greenLED off
loopMode = 0;
espWaitTimeStepDown = espWaitTime;
} // end of loopMode 1
if (loopMode == 2) // data are on send ready
if (serialPrintOn)
Serial.print(" dataSendOK = ");
Serial.println(dataSendOK);
Serial.print("dataAcommand = ");
Serial.print(" dataAstatus = ");
Serial.print(" dataAindex = ");
if (dataSendOK)
if (serialPrintOn)
Serial.print("dataAcommand: ");
Serial.print(", dataAStatus: ");
Serial.print(", index: ");
Serial.print(", waittime: ");
Serial.println(espWaitTimeStepDown);
digitalWrite(redLED,LOW);
loopMode = 3;
digitalWrite(redLED,HIGH);
Serial.print("w,");
} // end of loopMode 2
if (loopMode == 3)
if (serialPrintOn)
Serial.println(loopMode);
Serial.print("dataSendOK = ");
if (serialPrintOn)
PrintEspSendMessage();
LoadSendMessage();
// Send message via ESP-NOW
if (slaveNumber==1)
esp_now_send(slaveMacAddressA, (uint8_t *) &espSendMessage, sizeof(espSendMessage));
if (slaveNumber==2)
esp_now_send(slaveMacAddressB, (uint8_t *) &espSendMessage, sizeof(espSendMessage));
loopMode = 4;
//delay(espWaitTime);
delay(1);
//digitalWrite(greenLED, LOW);
} // end of loopMode 3
if (loopMode == 4)
if (dataSendOK)
digitalWrite(yellowLED,LOW);
if (serialPrintOn)
Serial.print("dataSendOK !");
if (dataAstatus == 0)
loopMode = 0; //
loopMode = 1;
if (serialPrintOn)
//Serial.println();
delay(espWaitTime);
} // end of loopMode 4
if (loopMode == 7)
if (serialPrintOn)
Serial.print("*A,");
dataOsc = dataA3;
Serial.print(dataOsc); // analogData
Serial.print(",");
Serial.print(dataA1); // LoPlus
Serial.print(",");
Serial.print(dataA2); // LoMinus
loopMode = 0;
digitalWrite(yellowLED,HIGH);
if (serialPrintOn)
Serial.print("B received of dataAindex = ");
Serial.print(",");
Serial.print(",");
Serial.println(",");
dataOsc = dataA3;
Serial.print("*B,");
dataAstatus = 1;
loopMode = 1;
if (dataStopOn)
loopMode = 0;
if (serialPrintOn)
Serial.print("B loopMode 7 => dataAindex asked = ");
if (dataAcommand == 67) // C data *,data,#,
if (serialPrintOn)
Serial.print("C received dataAindex = ");
dataOsc = dataA3;
Serial.print("*,");
dataAstatus = 1;
loopMode = 1;
if (dataStopOn)
loopMode = 0;
if (serialPrintOn)
Serial.print("C loopMode 7 => dataAindex asked = ");
if (dataAcommand == 68) // D - dataCRLF
if (serialPrintOn)
Serial.print("D received dataAindex = ");
dataOsc = dataA3;
Serial.println(dataOsc); // data direct on serial plotter
dataAstatus = 1;
loopMode = 1;
if (dataStopOn)
loopMode = 0;
if (serialPrintOn)
Serial.print("D loopMode 7 => dataAindex asked = ");
dataSendOK = true;
Serial.print("*K,");
Serial.print(dataA3); //confirmed slave number
loopMode= 0;
//dataOscArray[I] = dataOsc + dataOscOffset;
if (dataAindex > 0)
dataOsc = dataOscArray[dataAindex];
Serial.print(",");
if (serialPrintOn)
Serial.print(", dataAindex = ");
if (dataAindex < dataPocetOsc)
dataAstatus = 1;
loopMode = 1;
loopMode = 0;
dataTime = dataStep * (dataPocetOsc-1);
if (serialPrintOn)
Serial.print("Meased:,");
Serial.print(",");
Serial.print(",");
Serial.print(dataTime);
Serial.print(",");
loopMode = 0;
dataPocetOsc = dataPar[2];
dataAindex = 0;
dataA1 = dataStep;
dataPar[3] = dataStep * (dataPocetOsc-1);
Serial.print("*N,");
Serial.print(",");
Serial.print(",");
Serial.print(",");
Serial.print(",");
dataAcommand = 85;
dataAstatus = 1;
loopMode = 1;
if (serialPrintOn)
Serial.print("P received parameters:");
Serial.print(",");
Serial.print(",");
Serial.print(",");
loopMode = 0;
dataPar[2] = dataAindex;
dataPar[3] = dataTime; //data all time
if (serialPrintOn)
Serial.print("Stop => received all dataTime = ");
Serial.println(dataTime);
Serial.print("*S,");
Serial.print(",");
Serial.print(",");
Serial.print(",");
Serial.print(",");
dataStopOn = true;
dataA1 = 0;
loopMode = 0;
if (serialPrintOn)
Serial.print("loopMode 7 ");
} //end of loopMode = 7
