ESP-Now with ESP32C3
I am trying to setup 4 ESP32C3 using ESP-NOW and cannot seem to find the right combination to get them to work, I use the built in examples in Arduino IDE 2.3.2, under examples - ESP32 - ESPNow - ESPNow_MultiSlave_Master, for the master. And the examples - ESP32 - ESPNow -ESPNow_Basic_Slave for the 3 slaves, and I get them to talk, and send and receive packets to and from each other.
Found 6 devices
1: SlaveC3 [EC:DA:3B:AA:xx.xx] (-41)
6: SlaveC2 [EC:DA:3B:AA:xx.xx] (-91)
2 Slave(s) found, processing…
Processing: EC:DA:3B:AA:xx.xx Status: Already Paired
Sending: 7
Send Status: Success
Last Packet Sent to: ec:da:3b:aa:xx.xx
Last Packet Send Status: Delivery Success
But I am trying to get the master to work with a button that triggers the LEDs on the slaves. I realize this is probably very simple but I am new to this and don’t do well with coding. I have tried several examples that I have found online and on YouTube but still am struggling with this and would appreciate any help I could get.
TIA!
Without posting the codes that you have used as a base your whole question summarises to
can somebody write the complete code for me?
Which would be very demanding.
You should post the codes that you have used for testing the ESP-NOW-network
including your attempt with the button.
To write a everyday analogon:
You are asking for: can somebody write a manual on how to replace the brake on my bike.
Without showing YOUR bike
giving a sufficient answer would result in a whole book
"how to replace all types of brakes on all types of bikes"
So please post your complete sketches as code-sections
I did not save the code I was trying because it didn't work and I was frustrated, I can post the examples in the Arduino IDE if you like.
Ok I did find one I was playing with in the recycle bin.
   ESPNOW - Basic communication - Master
   Date: 26th September 2017
   Author: Arvind Ravulavaru <https://github.com/arvindr21>
   Purpose: ESPNow Communication between a Master ESP32 and a Slave ESP32
   Description: This sketch consists of the code for the Master module.
   Resources: (A bit outdated)
   a. https://espressif.com/sites/default/files/documentation/esp-now_user_guide_en.pdf
   b. http://www.esploradores.com/practica-6-conexion-esp-now/
   << This Device Master >>
   Flow: Master
   Step 1 : ESPNow Init on Master and set it in STA mode
   Step 2 : Start scanning for Slave ESP32 (we have added a prefix of `slave` to the SSID of slave for an easy setup)
   Step 3 : Once found, add Slave as peer
   Step 4 : Register for send callback
   Step 5 : Start Transmitting data from Master to Slave
   Flow: Slave
   Step 1 : ESPNow Init on Slave
   Step 2 : Update the SSID of Slave with a prefix of `slave`
   Step 3 : Set Slave in AP mode
   Step 4 : Register for receive callback and wait for data
   Step 5 : Once data arrives, print it in the serial monitor
   Note: Master and Slave have been defined to easily understand the setup.
         Based on the ESPNOW API, there is no concept of Master and Slave.
         Any devices can act as master or salve.
#include <esp_now.h>
#include <WiFi.h>
#include <esp_wifi.h> // only for esp_wifi_set_channel()
// variables for button&LED
const int buttonPin = D0;
int oldButtonState = LOW;
const int ledPin = 4;
// Global copy of slave
esp_now_peer_info_t slave;
#define CHANNEL 1
#define PRINTSCANRESULTS 0
#define DELETEBEFOREPAIR 0
// Init ESP Now with fallback
void InitESPNow() {
  WiFi.disconnect();
  if (esp_now_init() == ESP_OK) {
    Serial.println("ESPNow Init Success");
  else {
    Serial.println("ESPNow Init Failed");
    // Retry InitESPNow, add a counte and then restart?
    // InitESPNow();
    // or Simply Restart
    ESP.restart();
// Scan for slaves in AP mode
void ScanForSlave() {
  int16_t scanResults = WiFi.scanNetworks(false, false, false, 300, CHANNEL); // Scan only on one channel
  // reset on each scan
  bool slaveFound = 0;
  memset(&slave, 0, sizeof(slave));
  Serial.println("");
  if (scanResults == 0) {
    Serial.println("No WiFi devices in AP Mode found");
    Serial.print("Found "); Serial.print(scanResults); Serial.println(" devices ");
    for (int i = 0; i < scanResults; ++i) {
      // Print SSID and RSSI for each device found
      String SSID = WiFi.SSID(i);
      int32_t RSSI = WiFi.RSSI(i);
      String BSSIDstr = WiFi.BSSIDstr(i);
      if (PRINTSCANRESULTS) {
        Serial.print(i + 1);
        Serial.print(": ");
        Serial.print(SSID);
        Serial.print(" (");
        Serial.print(RSSI);
        Serial.print(")");
        Serial.println("");
      delay(10);
      // Check if the current device starts with `Slave`
      if (SSID.indexOf("Slave") == 0) {
        // SSID of interest
        Serial.println("Found a Slave.");
        Serial.print(i + 1); Serial.print(": "); Serial.print(SSID); Serial.print(" ["); Serial.print(BSSIDstr); Serial.print("]"); Serial.print(" ("); Serial.print(RSSI); Serial.print(")"); Serial.println("");
        // Get BSSID => Mac Address of the Slave
        int mac[6];
        if ( 6 == sscanf(BSSIDstr.c_str(), "%x:%x:%x:%x:%x:%x",  &mac[0], &mac[1], &mac[2], &mac[3], &mac[4], &mac[5] ) ) {
          for (int ii = 0; ii < 6; ++ii ) {
            slave.peer_addr[ii] = (uint8_t) mac[ii];
        slave.channel = CHANNEL; // pick a channel
        slave.encrypt = 0; // no encryption
        slaveFound = 1;
        // we are planning to have only one slave in this example;
        // Hence, break after we find one, to be a bit efficient
  if (slaveFound) {
    Serial.println("Slave Found, processing..");
    Serial.println("Slave Not Found, trying again.");
  // clean up ram
  WiFi.scanDelete();
// Check if the slave is already paired with the master.
// If not, pair the slave with master
bool manageSlave() {
  if (slave.channel == CHANNEL) {
    if (DELETEBEFOREPAIR) {
      deletePeer();
    Serial.print("Slave Status: ");
    // check if the peer exists
    bool exists = esp_now_is_peer_exist(slave.peer_addr);
    if ( exists) {
      // Slave already paired.
      Serial.println("Already Paired");
      return true;
      // Slave not paired, attempt pair
      esp_err_t addStatus = esp_now_add_peer(&slave);
      if (addStatus == ESP_OK) {
        // Pair success
        Serial.println("Pair success");
        return true;
      } else if (addStatus == ESP_ERR_ESPNOW_NOT_INIT) {
        // How did we get so far!!
        Serial.println("ESPNOW Not Init");
        return false;
      } else if (addStatus == ESP_ERR_ESPNOW_ARG) {
        Serial.println("Invalid Argument");
        return false;
      } else if (addStatus == ESP_ERR_ESPNOW_FULL) {
        Serial.println("Peer list full");
        return false;
      } else if (addStatus == ESP_ERR_ESPNOW_NO_MEM) {
        Serial.println("Out of memory");
        return false;
      } else if (addStatus == ESP_ERR_ESPNOW_EXIST) {
        Serial.println("Peer Exists");
        return true;
        Serial.println("Not sure what happened");
        return false;
    // No slave found to process
    Serial.println("No Slave found to process");
    return false;
void deletePeer() {
  esp_err_t delStatus = esp_now_del_peer(slave.peer_addr);
  Serial.print("Slave Delete Status: ");
  if (delStatus == ESP_OK) {
    // Delete success
    Serial.println("Success");
  } else if (delStatus == ESP_ERR_ESPNOW_NOT_INIT) {
  } else if (delStatus == ESP_ERR_ESPNOW_ARG) {
  } else if (delStatus == ESP_ERR_ESPNOW_NOT_FOUND) {
    Serial.println("Peer not found.");
uint8_t data = 0;
// send data
void sendData() {
  data++;
  const uint8_t *peer_addr = slave.peer_addr;
  Serial.print("Sending: "); Serial.println(data);
  esp_err_t result = esp_now_send(peer_addr, &data, sizeof(data));
  Serial.print("Send Status: ");
  if (result == ESP_OK) {
  } else if (result == ESP_ERR_ESPNOW_NOT_INIT) {
    Serial.println("ESPNOW not Init.");
  } else if (result == ESP_ERR_ESPNOW_ARG) {
  } else if (result == ESP_ERR_ESPNOW_INTERNAL) {
    Serial.println("Internal Error");
  } else if (result == ESP_ERR_ESPNOW_NO_MEM) {
    Serial.println("ESP_ERR_ESPNOW_NO_MEM");
  } else if (result == ESP_ERR_ESPNOW_NOT_FOUND) {
// callback when data is sent from Master to Slave
void OnDataSent(const uint8_t *mac_addr, esp_now_send_status_t status) {
  char macStr[18];
  snprintf(macStr, sizeof(macStr), "%02x:%02x:%02x:%02x:%02x:%02x",
           mac_addr[0], mac_addr[1], mac_addr[2], mac_addr[3], mac_addr[4], mac_addr[5]);
  Serial.print("Last Packet Sent to: "); Serial.println(macStr);
  Serial.print("Last Packet Send Status: "); Serial.println(status == ESP_NOW_SEND_SUCCESS ? "Delivery Success" : "Delivery Fail");
  //Set device in STA mode to begin with
  WiFi.mode(WIFI_STA);
  esp_wifi_set_channel(CHANNEL, WIFI_SECOND_CHAN_NONE);
  Serial.println("ESPNow/Basic/Master Example");
  // This is the mac address of the Master in Station Mode
  Serial.print("STA MAC: "); Serial.println(WiFi.macAddress());
  Serial.print("STA CHANNEL "); Serial.println(WiFi.channel());
  // Init ESPNow with a fallback logic
  InitESPNow();
  // Once ESPNow is successfully Init, we will register for Send CB to
  // get the status of Trasnmitted packet
  esp_now_register_send_cb(OnDataSent);
  // configure the button pin as input
  pinMode(buttonPin, INPUT);
    // initialize the LED pin as an output:
    pinMode(ledPin, OUTPUT);
  // In the loop we scan for slave
  ScanForSlave();
  // If Slave is found, it would be populate in `slave` variable
  // We will check if `slave` is defined and then we proceed further
  if (slave.channel == CHANNEL) { // check if slave channel is defined
    // `slave` is defined
    // Add slave as peer if it has not been added already
    bool isPaired = manageSlave();
    if (isPaired) {
      // pair success or already paired
      // Send data to device
      sendData();
      // slave pair failed
      Serial.println("Slave pair failed!");
  else {
  // wait for 3seconds to run the logic again
  delay(3000);
And
  ESP-NOW Multi Unit Demo
  esp-now-multi.ino
  Broadcasts control messages to all devices in network
  Load script on multiple devices
  DroneBot Workshop 2022
  https://dronebotworkshop.com
// Include Libraries
#include <WiFi.h>
// Define LED and pushbutton state booleans
bool buttonDown = false;
bool ledOn = false;
// Define LED and pushbutton pins
#define STATUS_LED D0
#define STATUS_BUTTON D5
void formatMacAddress(const uint8_t *macAddr, char *buffer, int maxLength)
// Formats MAC Address
  snprintf(buffer, maxLength, "%02x:%02x:%02x:%02x:%02x:%02x", macAddr[0], macAddr[1], macAddr[2], macAddr[3], macAddr[4], macAddr[5]);
void receiveCallback(const uint8_t *macAddr, const uint8_t *data, int dataLen)
// Called when data is received
  // Only allow a maximum of 250 characters in the message + a null terminating byte
  char buffer[ESP_NOW_MAX_DATA_LEN + 1];
  int msgLen = min(ESP_NOW_MAX_DATA_LEN, dataLen);
  strncpy(buffer, (const char *)data, msgLen);
  // Make sure we are null terminated
  buffer[msgLen] = 0;
  // Format the MAC address
  char macStr[18];
  formatMacAddress(macAddr, macStr, 18);
  // Send Debug log message to the serial port
  Serial.printf("Received message from: %s - %s\n", macStr, buffer);
  // Check switch status
  if (strcmp("on", buffer) == 0)
    ledOn = true;
    ledOn = false;
  digitalWrite(STATUS_LED, ledOn);
void sentCallback(const uint8_t *macAddr, esp_now_send_status_t status)
// Called when data is sent
  char macStr[18];
void broadcast(const String &message)
// Emulates a broadcast
  // Broadcast a message to every device in range
  uint8_t broadcastAddress[] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
  esp_now_peer_info_t peerInfo = {};
  memcpy(&peerInfo.peer_addr, broadcastAddress, 6);
  if (!esp_now_is_peer_exist(broadcastAddress))
    esp_now_add_peer(&peerInfo);
  // Send message
  esp_err_t result = esp_now_send(broadcastAddress, (const uint8_t *)message.c_str(), message.length());
  // Print results to serial monitor
    Serial.println("Broadcast message success");
    Serial.println("ESP-NOW not Init.");
    Serial.println("Unknown error");
  // Set up Serial Monitor
  // Set ESP32 in STA mode to begin with
  Serial.println("ESP-NOW Broadcast Demo");
  // Print MAC address
  Serial.print("MAC Address: ");
  // Disconnect from WiFi
  WiFi.disconnect();
  // Initialize ESP-NOW
    Serial.println("ESP-NOW Init Success");
    esp_now_register_recv_cb(receiveCallback);
    esp_now_register_send_cb(sentCallback);
    Serial.println("ESP-NOW Init Failed");
    delay(3000);
    ESP.restart();
  // Pushbutton uses built-in pullup resistor
  pinMode(STATUS_BUTTON, INPUT_PULLUP);
  // LED Output
  pinMode(STATUS_LED, OUTPUT);
  if (digitalRead(STATUS_BUTTON))
    // Detect the transition from low to high
    if (!buttonDown)
      buttonDown = true;
      // Toggle the LED state
      ledOn = !ledOn;
      // Send a message to all devices
      if (ledOn)
        broadcast("on");
        broadcast("off");
    // Delay to avoid bouncing
    // Reset the button state
    buttonDown = false;
You should make a fundamental decision:
Ask yourself:
"Do I you want to invest some hours of learning?"
"Do I want to give pretty detailed description of my project?"
or
"some hours of learning, writing a detailed description of my project is too much work for me I abandon this project"
It boils down to this fundamental decision.
This forum can be of great help with answering a lot of questions but you have to show some own effort.
This initial effort is to give a pretty detailed description of what you want to do.
I am pretty sure that pressing a button on the master makes the slaves light up an led is switched on is not all.
The minimum is to add: once the button is pressed and the leds on the slaves are switched on the system can stay in this mode with leds on forever
or
until I switch them all off again.
or
describing what shall happen instead?
  • should another press on the button switch the led off again?
  • should the led switch off after a certain time?
  • something else?
Your turn to make the decision.
Is really very simple, I would like the sensor on the garage door (master) to trigger (eventually 4) slaves in the home in different rooms that the garage door is open for as long as it is open. Then turn off when it closes.
So simply post your best attempt how you at least tried to modify the code
for whenever an pinut-pin has "signal" door opened send a certain value to all ESP-NOW-slaves
whenever an pinut-pin has "signal" door closed send a different value to all ESP-NOW-slaves
or ask
code-specific questions
how can I ...... what ever your question is
So far you post rather less informations.
I'm pretty sure that you agree and will follow the way how to solve your problem mimimum 200 minutes faster.
This requires to invest 20 minutes of your precious time to read how to speedup solving your problems.
Directly after registering you got presented informations how to speed up solving your problem.
You should really read it.
I did in post #3, this is what I modified and tried to make work, I'm not sure what you want, Should I post what original code that is in arduion IDE too? As I explained I do not know coding and am trying to learn something. My how to question is how can I modify this broken code to make it work? What is it that I am doing wrong?
You should always be precise with your information. The post above is the first one that does explicitly say that it is the modificated code.
remark: I am posting the complete sketch NEW in THIS posting with clearly writing which sketch this is what
The sketch called master
   Flow: Master
   Flow: Slave
#include <WiFi.h>
#define CHANNEL 1
void InitESPNow() {
  WiFi.disconnect();
  else {
    // InitESPNow();
    ESP.restart();
  Serial.println("");
        Serial.print(": ");
        Serial.print(SSID);
        Serial.print(" (");
        Serial.print(RSSI);
        Serial.print(")");
        Serial.println("");
      delay(10);
        // SSID of interest
        int mac[6];
        slaveFound = 1;
  if (slaveFound) {
  // clean up ram
  WiFi.scanDelete();
      deletePeer();
    if ( exists) {
      return true;
        // Pair success
        return true;
        return false;
        return false;
        return false;
        return false;
        return true;
        return false;
    return false;
void deletePeer() {
    // Delete success
uint8_t data = 0;
// send data
void sendData() {
  data++;
  char macStr[18];
  InitESPNow();
  ScanForSlave();
    if (isPaired) {
      sendData();
  else {
  delay(3000);
This is the sketch called multiunit-demo
which has some modifications to read in a button etc.
  esp-now-multi.ino
#include <WiFi.h>
bool ledOn = false;
  buffer[msgLen] = 0;
  char macStr[18];
    ledOn = true;
    ledOn = false;
  char macStr[18];
  // Send message
  WiFi.disconnect();
    delay(3000);
    ESP.restart();
  // LED Output
    if (!buttonDown)
      buttonDown = true;
      ledOn = !ledOn;
      if (ledOn)
        broadcast("on");
        broadcast("off");
    buttonDown = false;
If you used the "master-code" how should a code that does not read in the button be able to send any kind of message to any other board containing the switch-state?
You should very carefully analyse which code runs on which board
easiest way to do this is to add some unique number to each board
and to make the master blink its onboard led at a different frequency than the others
goodbye
