ESP : Using GPIO2 to light external LED
Hello everyone,
I can't believe I'm saying this but I can't get an LED on GPIO2 to light on my ESP32. I measured 3.3v on my pin when pulled high. The wiring is simple resistor (I tried 220ohm and 330ohm), green LED, then to ground.
Any ideas? I don't have any other pins available so please do not tell me to use a different pin. Onboard LED is working.
Thanks
If you are using the following 30-pin ESP32 Dev Module (Fig-1), then FPIO2 is connected with the onboard Blue LED. Without connecting anything with the GPIO2-pin, upload the following sketch and check that the onboard Blue LED is blinking.
Figure-1:
#define BLED 2//onboard BlueLED
  pinMode(BLED, OUTPUT);
  digitalWrite(BLED, HIGH);
  digitalWrite(BLED, LOW);
It is.
Here is my current code
I tried switching to GPIO4 which should be 100% clean to use and it still didn't work. I also switched to a white LED.
Pic @ Imgur: The magic of the Internet
const byte LED_GPIO = 4;
  pinMode(LED_GPIO, OUTPUT);
  digitalWrite(LED_GPIO, HIGH);
That means that the onboard Blue LED is not blinking for your ESP32 Dev Board! In my case, it is blinking.
I have uploaded your sketch of post #3 for GPIO4; the LED has correctly turned ON.
Your code (and mine when changed to pin 2 causes the onboard LED to blink.
Why isn't my LED working?
HAHAHA...it was polarity!
