Happy New Year to all. I was playing with a Lolin32 Pro (which obviously has an ESP-32) and I was trying one of the examples for using the WPS button.
Example Code To Get ESP32 To Connect To A Router Using WPS
This example code provides both Push Button method and Pin
based WPS entry to get your ESP connected to your WiFi router.
Hardware Requirements
ESP32 and a Router having atleast one WPS functionality
This code is under Public Domain License.
Author:
Pranav Cherukupalli <cherukupallip@gmail.com>
#include "WiFi.h"
#include "esp_wps.h"
Change the definition of the WPS mode
from WPS_TYPE_PBC to WPS_TYPE_PIN in
the case that you are using pin type
WPS
#define ESP_WPS_MODE WPS_TYPE_PBC
#define ESP_MANUFACTURER "ESPRESSIF"
#define ESP_MODEL_NUMBER "ESP32"
#define ESP_MODEL_NAME "ESPRESSIF IOT"
#define ESP_DEVICE_NAME "ESP STATION"
static esp_wps_config_t config;
void wpsInitConfig(){
config.crypto_funcs = &g_wifi_default_wps_crypto_funcs;
config.wps_type = ESP_WPS_MODE;
strcpy(config.factory_info.manufacturer, ESP_MANUFACTURER);
strcpy(config.factory_info.model_number, ESP_MODEL_NUMBER);
strcpy(config.factory_info.model_name, ESP_MODEL_NAME);
strcpy(config.factory_info.device_name, ESP_DEVICE_NAME);
String wpspin2string(uint8_t a[]){
char wps_pin[9];
for(int i=0;i<8;i++){
wps_pin[i] = a[i];
wps_pin[8] = '\0';
return (String)wps_pin;
void WiFiEvent(WiFiEvent_t event, system_event_info_t info){
switch(event){
case SYSTEM_EVENT_STA_START:
Serial.println("Station Mode Started");
case SYSTEM_EVENT_STA_GOT_IP:
Serial.println("Connected to :" + String(WiFi.SSID()));
Serial.print("Got IP: ");
case SYSTEM_EVENT_STA_DISCONNECTED:
Serial.println("Disconnected from station, attempting reconnection");
WiFi.reconnect();
case SYSTEM_EVENT_STA_WPS_ER_SUCCESS:
Serial.println("WPS Successfull, stopping WPS and connecting to: " + String(WiFi.SSID()));
esp_wifi_wps_disable();
delay(10);
WiFi.begin();
case SYSTEM_EVENT_STA_WPS_ER_FAILED:
Serial.println("WPS Failed, retrying");
esp_wifi_wps_enable(&config);
esp_wifi_wps_start(0);
case SYSTEM_EVENT_STA_WPS_ER_TIMEOUT:
Serial.println("WPS Timedout, retrying");
case SYSTEM_EVENT_STA_WPS_ER_PIN:
Serial.println("WPS_PIN = " + wpspin2string(info.sta_er_pin.pin_code));
default:
void setup(){
delay(10);
WiFi.onEvent(WiFiEvent);
WiFi.mode(WIFI_MODE_STA);
Serial.println("Starting WPS");
wpsInitConfig();
void loop(){
//nothing to do here
I would like to know if it is possible to take the SSID and PASSWORD received via WPS and save it in the SD.
I ask this because if the connection is done with the WPS when the board is reset the credentials remain stored but, if the electricity obviously everything is lost and I do not like it very much.
I would like to do something like this: I read the credentials from SD, I try to connect, if I match OK otherwise I force a connection with the WPS.
Suggestions?
