ESP32-based boards: how to recompile camera driver?
Hello everyone!
I have couple of ideas on how to improve esp_camera code. That one, used by ESP32Cam examples.
I think, there is a room for improvements, namely - cam_ll_memcpy(). But to experiment with it I would like to recompile it. However it is a part of ESP-IDF, which comes precompiled. Is there a way to somehow compile & use my (modified) code instead of binary lib?
May be sources of esp_camera can be somehow be placed in a sketch directory, with manually created sdkconfig.h?
Expert opinion needed.
PS: may be I can just override esp_camera’s functions using -lWrap linker/compiler flags?
I use the ESP32 CAM code a lot. Where is this binary?
Github for camera code is here;
https://github.com/espressif/esp32-camera
Yes, the source code for the ESP-IDF component. Has its own build system.
Now I want to make some changes and use it. How it could be done without recompiling the whole ESP-IDF?
it is installed along with precompiled ESP-IDF libraries. Only Arduino Core is shipped in (and compiled from ) sources.
I used vscode, esp has an extension for their IDF and you can use Arduino as a component.
Then yes, you can recompile everything.
bit of a learning curve but possible..
good luck.. ~q
Post #3 has the answer.
