Hello I have big problem with connecting ESP32 board. When it plug in my PC can not find this device. I installed everything, arduino software, esp, xtensa, drivers, 2 nd board ESP32... The device manager I cant see it at all. I tried 3 PC and cable is correct (not only for charging)
I have no idea what to do. The LED on ESP32 is working, but thats all.
post a link to where you bought the ESP32
What do the specs say about the USB-to-TTL-converter-chip?
Is it a CP2102 ? or a CP2104? is it a CH340?
alternatively post a high resolution-picture of your ESP32-board.
The resolution must be high enough to be able to read the type-number on the chips
CH340
CP2102
2102
This driver is installed
in the device manager did you look under Connections COM & LPT?
post a screenshot
Yes, I did. There is nothing. But if you want, I will make screen.
go to CP2102 USB to Serial Converter Hook-Up Guide - SparkFun Learn
scroll down to Installing Windows USB Drivers
I tryed to install it many times. Actually it was the first thing that I did. I do not see this.
"tried" means the installation failed?
What messages do you get if you start the CP2102-driver-installation?
post pictures of the installation process
to be able to post picture you have to reach trust-level 1 in the arduino-forum
To post images etc you need trust level 1, you can get there by:
- Entering at least 5 topics
- Reading at least 30 posts
- Spend a total of 10 minutes reading posts
Users at trust level 1 can…
- Use all core Discourse functions; all new user restrictions are removed
- Send PMs
- Upload images and attachments
This way of posting with just a few words. Will distract from finding the solution
what do you mean by writing I do not see this.
what is "this" you have to use specific and explicit words instead of generalised words.
I start to think all the problems you have are just there because you are in such a big hurry
Well. It means that I started install it many times and many times sucessful also. I do not see any warning about incorrect device or something similar you posted. I tried to install it and connect to 3 PCs. I tried to connect 2 boards.
did you look up the other devices section of the device-manager?
what is seriove zarizeni USB (COM5) ??
does this entry disappear if you DIS-connect the ESP32-board?
Do you know how to make screenshots directly ?
On win 11 there is not this section, or I can not to see it. Hidden devices are shown as you can see on pucture. On win 10 it looks same. No other device.
Seriove zarizeni is hidden device. It is shown when I connect mobile
can you please answer the above questions
if you open a command-prompt
windows-key-R
then type driverquery
is there an entry in the list
** silabser Silicon Labs CP210x US Kernel**
Seriove zarizeni is hidden device - reason why is grey. It is shown when I connect mobile.
Without any change when I plug in or out board. Is no arduino port. Normally (now) is hidden. (Plugged board)
You can do screenshots by pressing the PrtScr-key on your keyboard
I don't understand what you want to say with that
write your answer in your native language and then use google translate
your last picture is from a different screen
