Hi Everyone. I am thinking on buy this ESP32 C3 SUPER MINI Dev board and I would like to know if you have had the chance of working with it. Also:
-Does it really have WiFi and Bluetooth capabilities?
-Aproximate coverage range for WiFi and Bluetooth
-Is it possible to use ADC Channels along with WiFI ?
@junior_27 I have just bought a couple from Seeed Studio
The site has a lot of interesting development kits based around their tiny mcu boards with sensors, cameras, displays etc. for a very reasonable price.
From what I see the Seeed Studio boards work reasonably well. They differ from the larger development boards in the fact that they come with an external antenna whereas the regular boards the antenna is built in. Without the antenna the wifi signal seems very weak, I have not done much with the wifi yet but I am interested to see how the external antenna works out.
The ESP32-C3 SuperMini has a built-in aerial that looks like a (red) smd resistor, which seems to perform the same as the printed aerial traces on bigger boards.
Software USB (no USB<>Serial chip) needs a bit of getting used to, but works ok.
I think it's a great little board if you want the lower current draw of a single-core ESP32.
Only have used WiFi so far, so can't comment on BT (LE only) or A/D. But I don't see why it would be different to other ESP32 boards.
Leo..
I moved your topic to a more appropriate forum category @junior_27.
The Nano ESP32 category you chose is only used for discussions directly related to the Arduino Nano ESP32 board.
In the future, please take the time to pick the forum category that best suits the subject of your question. There is an "About the _____ category" topic at the top of each category that explains its purpose.
I just bought a few of these to play with and wondered what they used for an antennae. Mine are like the first picture and if anything seem to be more sensitive than the other various sorts of ESP that I have. At least, they are seeing more of the wifi access points around the neighbourhood than the others do.
Google "2.4MHz ceramic chip aerial" (images).
They look like SMD capacitors, and come in various lengths. It's the black square top/right of the board in post#1. Good to hear that your board is performing better. I have seen little or no difference.
Leo..
