ESP32 CAM and DHT problem Sensor_t
Hello I try to make this sketch work but there is a conflict with sensor_t and I can't seem to find a solution.
Sketch:
#define BLYNK_TEMPLATE_ID           "TMPL5me-22yZE"
#define BLYNK_TEMPLATE_NAME         "Plantevander 2"
#define BLYNK_AUTH_TOKEN "lXuIlcR_gSDyWSdg4KO8FRF9huqjVlWv"
#define BLYNK_PRINT Serial
#include "OV2640.h"
#include <WiFi.h>
#include <WebServer.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <Adafruit_Sensor.h>
#include <DHT.h>
#include <DHT_U.h>
#define DHTPIN 12
#define DHTTYPE    DHT11     // DHT 11
DHT_Unified dht(DHTPIN, DHTTYPE);
#define PWDN_GPIO_NUM     32
#define RESET_GPIO_NUM    -1
#define XCLK_GPIO_NUM      0
#define SIOD_GPIO_NUM     26
#define SIOC_GPIO_NUM     27
#define Y9_GPIO_NUM       35
#define Y8_GPIO_NUM       34
#define Y7_GPIO_NUM       39
#define Y6_GPIO_NUM       36
#define Y5_GPIO_NUM       21
#define Y4_GPIO_NUM       19
#define Y3_GPIO_NUM       18
#define Y2_GPIO_NUM        5
#define VSYNC_GPIO_NUM    25
#define HREF_GPIO_NUM     23
#define PCLK_GPIO_NUM     22
char auth[] = BLYNK_AUTH_TOKEN;
const char* ssid = "****";
const char* password = "****";
float dry = 1700; // value for dry sensor
float wet = 1600; // value for wet sensor
float DryAlarm = 0;
float WetValue = 0;
float DryValue = 0;
float AutoCal = 0;
// This function creates the timer object. It's part of Blynk library
BlynkTimer timer;
OV2640 cam;
WebServer server(80);
const char HEADER[] = "HTTP/1.1 200 OK\r\n" \
                      "Access-Control-Allow-Origin: *\r\n" \
                      "Content-Type: multipart/x-mixed-replace; boundary=123456789000000000000987654321\r\n";
const char BOUNDARY[] = "\r\n--123456789000000000000987654321\r\n";
const char CTNTTYPE[] = "Content-Type: image/jpeg\r\nContent-Length: ";
const int hdrLen = strlen(HEADER);
const int bdrLen = strlen(BOUNDARY);
const int cntLen = strlen(CTNTTYPE);
void handle_jpg_stream(void)
  char buf[32];
  int s;
  WiFiClient client = server.client();
  client.write(HEADER, hdrLen);
  client.write(BOUNDARY, bdrLen);
  while (true)
    if (!client.connected()) break;
    cam.run();
    s = cam.getSize();
    client.write(CTNTTYPE, cntLen);
    sprintf( buf, "%d\r\n\r\n", s );
    client.write(buf, strlen(buf));
    client.write((char *)cam.getfb(), s);
const char JHEADER[] = "HTTP/1.1 200 OK\r\n" \
                       "Content-disposition: inline; filename=capture.jpg\r\n" \
                       "Content-type: image/jpeg\r\n\r\n";
const int jhdLen = strlen(JHEADER);
void handle_jpg(void)
  cam.run();
  if (!client.connected()) return;
  client.write(JHEADER, jhdLen);
  client.write((char *)cam.getfb(), cam.getSize());
void handleNotFound()
  String message = "Server is running!\n\n";
  message += "URI: ";
  message += server.uri();
  message += "\nMethod: ";
  message += (server.method() == HTTP_GET) ? "GET" : "POST";
  message += "\nArguments: ";
  message += server.args();
  message += "\n";
  server.send(200, "text / plain", message);
//What to do when successfully connected to Blynk
BLYNK_CONNECTED() {
  //Makes sure that V1 is in sync in case of lost connection.
  Blynk.syncVirtual(V0);
  Blynk.syncVirtual(V6);
  Blynk.syncVirtual(V7);
  Blynk.syncVirtual(V8);
//  Blynk.syncVirtual(V9);
  //Message that shows up in Serial Monitor.
  BLYNK_LOG("Connected to Blynk 🙌");
  //A LED lights up when connected to server.
  //digitalWrite(13, HIGH);
//What to do when not connected to Blynk
BLYNK_DISCONNECTED() {
  BLYNK_LOG("Blynk disconnected");
BLYNK_WRITE(V9)
  // Set incoming value from pin V0 to a variable
  DryAlarm = param.asInt();
BLYNK_WRITE(V8)
  AutoCal = param.asInt();
BLYNK_WRITE(V7)
  DryValue = param.asInt();
BLYNK_WRITE(V6)
  WetValue = param.asInt();
const int R1 = 9750;//we read the voltage acrosst this resistor ()
const int R2 = 35860;
float VB1;
int mV;
const int VinPin = 36; // Potentiometer connected to GPIO4
//This is for preventing dataoverflow so it only sends the updated value with certain intervals.
//The update interval is defined by timer.setInterval in the void setup section.
void myTimerEvent() {
  uint32_t voltage_mV = analogReadMilliVolts(VinPin); // Read the voltage in millivolts
  mV = voltage_mV;
  VB1 = (((float) voltage_mV) / 1000.0)  * (1 + (float)R2/(float)R1);
  Serial.print("VB1 Voltage: ");
  Serial.print(VB1); // Convert millivolts to volts
  Serial.println("V ");
 Blynk.virtualWrite(V4, VB1);
int sensorVal = analogRead(35);
int percentageHumididy = map(sensorVal, wet, dry, 100, 0);
    if ((AutoCal) == 1){
    Serial.println("AutoCal ON");
   if (percentageHumididy > 100)
     wet = sensorVal;
     Blynk.virtualWrite(V6, wet);
     Serial.print("Wet = ");
     Serial.print(wet);
   if (percentageHumididy < 0)
     dry = sensorVal;
     Blynk.virtualWrite(V7, dry);
     Serial.print(" | Dry = ");
     Serial.print(dry);
   else{
     dry = DryValue;
     wet = WetValue;
Blynk.virtualWrite(V3, percentageHumididy);
Blynk.virtualWrite(V5, sensorVal);
Serial.print(F("Ground Humidity: "));
    Serial.print(percentageHumididy);
    Serial.println(F("%"));
if(percentageHumididy < DryAlarm){
Blynk.logEvent("Dry");
Serial.println("tørt");
  // Get temperature event and print its value.
  sensors_event_t event;
  dht.temperature().getEvent(&event);
  if (isnan(event.temperature)) {
    Serial.println(F("Error reading temperature!"));
  else {
    Serial.print(F("Temperature: "));
    Serial.print(event.temperature);
    Serial.println(F("°C"));
    Blynk.virtualWrite(V1, event.temperature);
  // Get humidity event and print its value.
  dht.humidity().getEvent(&event);
  if (isnan(event.relative_humidity)) {
    Serial.println(F("Error reading humidity!"));
  else {
    Serial.print(F("Humidity: "));
    Serial.print(event.relative_humidity);
    Blynk.virtualWrite(V2, event.relative_humidity);
  // You can send any value at any time.
  // Please don't send more that 10 values per second.
  //send among of seconds that has past to virtual pin V0
  Blynk.virtualWrite(V0, millis() / 1000);
  // This function describes what will happen with each timer tick
  // e.g. writing sensor value to datastream V2
  //while (!Serial);            //wait for serial connection.
dht.begin();
  sensor_t sensor;
  dht.temperature().getSensor(&sensor);
  dht.humidity().getSensor(&sensor);
  // Setup a function to be called every second
  timer.setInterval(2000L, myTimerEvent);
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  // Frame parameters
  //  config.frame_size = FRAMESIZE_UXGA;
  config.frame_size = FRAMESIZE_QVGA;
  config.jpeg_quality = 12;
  config.fb_count = 2;
#if defined(CAMERA_MODEL_ESP_EYE)
  pinMode(13, INPUT_PULLUP);
  pinMode(14, INPUT_PULLUP);
#endif
  cam.init(config);
  IPAddress ip;
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED)
    Serial.print(F("."));
  ip = WiFi.localIP();
  Serial.println(F("WiFi connected"));
  Serial.println("");
    // Configure Blynk
  Blynk.config(auth);
  Serial.println("Connecting to Blynk");
  while (Blynk.connect() == false) {
    Serial.print(".");
  Serial.println("\nConnected to Blynk");
  Serial.println(ip);
  Serial.print("Stream Link: http://");
  Serial.print(ip);
  Serial.println("/mjpeg/1");
  server.on("/mjpeg/1", HTTP_GET, handle_jpg_stream);
  server.on("/jpg", HTTP_GET, handle_jpg);
  server.onNotFound(handleNotFound);
  server.begin();
  timer.run();
  server.handleClient();
   Blynk.run();
Error message:
In file included from C:\Users\Asus ROG\Downloads\live-video-streaming-esp32-cam-blynk-iot\live-streaming\live-streaming.ino:14:
c:\Users\Asus ROG\Documents\Arduino\libraries\Adafruit_Unified_Sensor/Adafruit_Sensor.h:194:3: error: conflicting declaration 'typedef struct sensor_t sensor_t'
 } sensor_t;
In file included from C:\Users\Asus ROG\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp32-camera/driver/include/esp_camera.h:71,
                 from C:\Users\Asus ROG\Downloads\live-video-streaming-esp32-cam-blynk-iot\live-streaming\OV2640.h:9,
                 from C:\Users\Asus ROG\Downloads\live-video-streaming-esp32-cam-blynk-iot\live-streaming\live-streaming.ino:9:
C:\Users\Asus ROG\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.17/tools/sdk/esp32/include/esp32-camera/driver/include/sensor.h:253:3: note: previous declaration as 'typedef struct _sensor sensor_t'
 } sensor_t;
exit status 1
Compilation error: exit status 1
It would be nice to use the DHT sensor without Adafruit, also what does adafruit do?
Thank you in advance.
