ESP32 cam camera-SD help
I'm struggling with making a simple sketch to take a photo on esp32cam and save to sd card. I have found a bunch of examples that that do what I want but basically they just take a photo and go to sleep. so every time you reset the unit it runs some code to take a photo, then goes into deep sleep. The thing is the photos suck, they are green and have no exposure control. I think that it is a known issue that the first photo is always green and the auto gain has not figured out the exposure yet. So because every photo is the first photo after waking up, they all suck.
I tried to move the setup stuff into the loop, and remove the sleep part, but it just straight up doesn't work. and I don't understand enough about coding to even get Chat GPT to help.....
I will put the working code below, and then the part i changed. Any help would be great. I thought it would be so simple, I just want to take a photo when i push a button.....
  ESP32 CAM Camera with MicroSD storage
  esp32cam-microsd.ino
  Take picture when button pressed
  Store image on MicroSD card
  DroneBot Workshop 2022
  https://dronebotworkshop.com
// Include Required Libraries
// Camera libraries
#include "esp_camera.h"
#include "soc/soc.h"
#include "soc/rtc_cntl_reg.h"
#include "driver/rtc_io.h"
// MicroSD Libraries
#include "FS.h"
#include "SD_MMC.h"
// EEPROM Library
#include "EEPROM.h"
// Use 1 byte of EEPROM space
#define EEPROM_SIZE 1
// Counter for picture number
unsigned int pictureCount = 0;
// Pin definitions for CAMERA_MODEL_AI_THINKER
#define PWDN_GPIO_NUM     32
#define RESET_GPIO_NUM    -1
#define XCLK_GPIO_NUM      0
#define SIOD_GPIO_NUM     26
#define SIOC_GPIO_NUM     27
#define Y9_GPIO_NUM       35
#define Y8_GPIO_NUM       34
#define Y7_GPIO_NUM       39
#define Y6_GPIO_NUM       36
#define Y5_GPIO_NUM       21
#define Y4_GPIO_NUM       19
#define Y3_GPIO_NUM       18
#define Y2_GPIO_NUM        5
#define VSYNC_GPIO_NUM    25
#define HREF_GPIO_NUM     23
#define PCLK_GPIO_NUM     22
void configESPCamera() {
  // Configure Camera parameters
  // Object to store the camera configuration parameters
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG; // Choices are YUV422, GRAYSCALE, RGB565, JPEG
  // Select lower framesize if the camera doesn't support PSRAM
  if (psramFound()) {
    config.frame_size = FRAMESIZE_UXGA; // FRAMESIZE_ + QVGA|CIF|VGA|SVGA|XGA|SXGA|UXGA
    config.jpeg_quality = 10; //10-63 lower number means higher quality
    config.fb_count = 2;
    config.jpeg_quality = 12;
    config.fb_count = 1;
  // Initialize the Camera
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    return;
  // Camera quality adjustments
  sensor_t * s = esp_camera_sensor_get();
  // BRIGHTNESS (-2 to 2)
  s->set_brightness(s, 0);
  // CONTRAST (-2 to 2)
  s->set_contrast(s, 1);
  // SATURATION (-2 to 2)
  s->set_saturation(s, 0);
  // SPECIAL EFFECTS (0 - No Effect, 1 - Negative, 2 - Grayscale, 3 - Red Tint, 4 - Green Tint, 5 - Blue Tint, 6 - Sepia)
  s->set_special_effect(s, 2);
  // WHITE BALANCE (0 = Disable , 1 = Enable)
  s->set_whitebal(s, 1);
  // AWB GAIN (0 = Disable , 1 = Enable)
  s->set_awb_gain(s, 1);
  // WB MODES (0 - Auto, 1 - Sunny, 2 - Cloudy, 3 - Office, 4 - Home)
  s->set_wb_mode(s, 0);
  // EXPOSURE CONTROLS (0 = Disable , 1 = Enable)
  s->set_exposure_ctrl(s, 1);
  // AEC2 (0 = Disable , 1 = Enable)
  s->set_aec2(s, 0);
  // AE LEVELS (-2 to 2)
  s->set_ae_level(s, 0);
  // AEC VALUES (0 to 1200)
  s->set_aec_value(s, 300);
  // GAIN CONTROLS (0 = Disable , 1 = Enable)
  s->set_gain_ctrl(s, 1);
  // AGC GAIN (0 to 30)
  s->set_agc_gain(s, 0);
  // GAIN CEILING (0 to 6)
  s->set_gainceiling(s, (gainceiling_t)0);
  // BPC (0 = Disable , 1 = Enable)
  s->set_bpc(s, 0);
  // WPC (0 = Disable , 1 = Enable)
  s->set_wpc(s, 1);
  // RAW GMA (0 = Disable , 1 = Enable)
  s->set_raw_gma(s, 1);
  // LENC (0 = Disable , 1 = Enable)
  s->set_lenc(s, 1);
  // HORIZ MIRROR (0 = Disable , 1 = Enable)
  s->set_hmirror(s, 0);
  // VERT FLIP (0 = Disable , 1 = Enable)
  s->set_vflip(s, 0);
  // DCW (0 = Disable , 1 = Enable)
  s->set_dcw(s, 1);
  // COLOR BAR PATTERN (0 = Disable , 1 = Enable)
  s->set_colorbar(s, 0);
void initMicroSDCard() {
  // Start the MicroSD card
  Serial.println("Mounting MicroSD Card");
  if (!SD_MMC.begin()) {
    Serial.println("MicroSD Card Mount Failed");
    return;
  uint8_t cardType = SD_MMC.cardType();
  if (cardType == CARD_NONE) {
    Serial.println("No MicroSD Card found");
    return;
void takeNewPhoto(String path) {
  // Take Picture with Camera
  // Setup frame buffer
  camera_fb_t  * fb = esp_camera_fb_get();
  if (!fb) {
    Serial.println("Camera capture failed");
    return;
  // Save picture to microSD card
  fs::FS &fs = SD_MMC;
  File file = fs.open(path.c_str(), FILE_WRITE);
  if (!file) {
    Serial.println("Failed to open file in write mode");
  else {
    file.write(fb->buf, fb->len); // payload (image), payload length
    Serial.printf("Saved file to path: %s\n", path.c_str());
  // Close the file
  file.close();
  // Return the frame buffer back to the driver for reuse
  esp_camera_fb_return(fb);
  // Disable brownout detector
  WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0);
  // Start Serial Monitor
  // Initialize the camera
  Serial.print("Initializing the camera module...");
  configESPCamera();
  Serial.println("Camera OK!");
  // Initialize the MicroSD
  Serial.print("Initializing the MicroSD card module... ");
  initMicroSDCard();
  // initialize EEPROM with predefined size
  EEPROM.begin(EEPROM_SIZE);
  pictureCount = EEPROM.read(0) + 1;
  // Path where new picture will be saved in SD Card
  String path = "/image" + String(pictureCount) + ".jpg";
  Serial.printf("Picture file name: %s\n", path.c_str());
  // Take and Save Photo
  takeNewPhoto(path);
  // Update EEPROM picture number counter
  EEPROM.write(0, pictureCount);
  EEPROM.commit();
  // Bind Wakeup to GPIO13 going LOW
  esp_sleep_enable_ext0_wakeup(GPIO_NUM_13, 0);
  Serial.println("Entering sleep mode");
  // Enter deep sleep mode
  esp_deep_sleep_start();
I changed the set up and loop:
  configESPCamera();
  initMicroSDCard();
 // Path where the new picture will be saved on the SD Card
  // Check if GPIO13 is low
  if (digitalRead(GPIO_NUM_13) == LOW) {
    takeNewPhoto(path);
    EEPROM.commit();
Take two or three photos, and write only the last one to the card. That is much easier that trying to rewrite the entire program.
Try something like:
 for (int i=0; i<3; i++) {
  if (!fb) {
    return;
 if (i<2)   {
   // Return first two frame buffers back to the driver for reuse
thanks, but this is way too delayed to be piratical, and does not address the exposure problem. I really need to keep the ESP on and just trigger the photo capture code with a button
Yes, it does. The camera takes some time to correctly adjust the exposure, and you are stuck with that.
Taking say 3 photos and only using the last one is, as mentioned, a common approach to the duff exposure problem.
OK, but can it be evaluating exposure all the time and only capture the photo (using the correct exposure) when I press the button?
Try it and see.
Yeah I don't know how to do that. I can't even past the code you suggested in the right place it would seam........
Compilation error: 'fb' was not declared in this scope
Post the code for your failed attempt, using code tags.
Thanks, Chat GTP got me there. But the the exposure problem persists. It won't take photos in any daylight, it just washes out to white.
Evidently, ChatGPT does not know how to solve the problem.
Few members of this forum are interested to fix the robots hallucinations.
Yeah it sucks, but it will just keep answering my questions without getting board and ghosting me so that is a plus.
Is the exposure problem even fixable? Can the ESP cam work in daylight conditions? I guess I've never tried because the only thing I can get to work is the web server example and I've never been able to try that outside.
Most people either use the approach outlined by posts #2 and #5, or get a better camera.
I moved your topic to a more appropriate forum category @svsavannah.
The Nano ESP32 category you chose is only used for discussions directly related to the Arduino Nano ESP32 board.
In the future, please take the time to pick the forum category that best suits the subject of your question. There is an "About the _____ category" topic at the top of each category that explains its purpose.
Thanks in advance for your cooperation.
