ESP32 CAM code not uploading to the board
can someone tell me what happen to my ESP32 CAM
Sketch uses 1058462 bytes (33%) of program storage space. Maximum is 3145728 bytes.
Global variables use 62288 bytes (19%) of dynamic memory, leaving 265392 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.8.1
Serial port COM3:
Connecting......................................
A fatal error occurred: Failed to connect to ESP32: Invalid head of packet (0x20): Possible serial noise or corruption.
For troubleshooting steps visit: Troubleshooting - ESP32 - — esptool latest documentation
Failed uploading: uploading error: exit status 2
Following the link in the error you posted, and using the error terms...
Invalid head of packet (0xXX): Possible serial noise or corruption.
This error is usually caused by one of the following reasons:
  • Using bad quality USB cable.
  • Sometimes breadboards can short the SPI flash pins on the board and cause this kind of problem. Try removing your development board from the breadboard.
  • The chip might be browning out during flashing. FTDI chips’ internal 3.3V regulator is not enough to power an ESP, see Insufficient Power.
Other things to try:
  • Try to sync and communicate at a much lower baud rate, e.g. esptool --baud 9600 ....
  • Try tracing the interactions running esptool --trace ... and see if anything is received back at all.
  • Try skipping chip autodetection by specifying the chip type, run esptool --chip ESP32 ....
If none of the above mentioned fixes help and your problem persists, please open a new issue.
