ESP32-CAM QR Scanner
Hello everyone, can anyone help me how to setup a qr scanner using ESP32-CAM OV2640?
I worked on the camera and it is now livestreaming in my local IP
Here is my Arduino Code
#include <WiFi.h>
#include <WebServer.h>
#include <esp32cam.h>
const char* WIFI_SSID = " ";
const char* WIFI_PASS = " ";
WebServer server(80);
void setupCamera() {
  using namespace esp32cam;
  Config cfg;
  cfg.setPins(pins::AiThinker);
  cfg.setResolution(Resolution::find(800, 600));
  cfg.setBufferCount(2);
  cfg.setJpeg(80);
  bool ok = Camera.begin(cfg);
  Serial.println(ok ? "CAMERA OK" : "CAMERA FAIL");
void streamMjpeg() {
  WiFiClient client = server.client();
  String header = "HTTP/1.1 200 OK\r\n"
                  "Content-Type: multipart/x-mixed-replace; boundary=frame\r\n"
                  "\r\n";
  client.print(header);
  while (client.connected()) {
    auto frame = esp32cam::capture();
    if (!frame) {
      Serial.println("Capture failed!");
    String frameHeader = "--frame\r\n"
                         "Content-Type: image/jpeg\r\n"
                         "Content-Length: " +
                         String(frame->size()) + "\r\n\r\n";
    client.print(frameHeader);
    frame->writeTo(client);
    client.print("\r\n");
    delay(100);
void handleRoot() {
  server.send(200, "text/html",
    "<h1>ESP32-CAM Live Stream</h1>"
    "<p><img src='/stream' width='640'></p>"
    "<p><a href='/stream'>Click here if video doesn't load.</a></p>");
  setupCamera();
  WiFi.persistent(false);
  WiFi.mode(WIFI_STA);
  WiFi.begin(WIFI_SSID, WIFI_PASS);
  unsigned long startAttemptTime = millis();
  while (WiFi.status() != WL_CONNECTED && millis() - startAttemptTime < 20000) {
    Serial.print(".");
  if (WiFi.status() == WL_CONNECTED) {
    Serial.println("\nWiFi Connected!");
    Serial.print("Stream URL: http://");
    Serial.print(WiFi.localIP());
    Serial.println("/stream");
    Serial.println("\nFailed to connect to WiFi!");
    return;
  server.on("/", handleRoot);
  server.on("/stream", streamMjpeg);
  server.begin();
  server.handleClient();
And now im working on how to scan qr codes and process it (I wanted to use mysql qr data and store it to xampp server locally) and i do try working on python OpenCV but i dont know how to use Python language
Can you also post the esp32cam.h file?
Here is the link of the esp32cam.h file that i used to build this
Thanks.
One of several examples on the web
Hi, I would also like to do the same thing with this card:
Did you succeed?
