ESP32 Cameras or Alternative Camera
Hi, I have 3x ESP32 Cameras that I would like to connect without wifi or bluetooth because I am worried about latency in the stream, is it possible to wire them to the arduino and if not what is a good alternative camera that will allow me to connect atleast 3x cameras to an arduino board?
Thanks
You want to connect 3 ESP32 CAMs to a Uno, why?
Stream latency worry. Why? The ESP32 cam takes 5 images a second. FTPing those images takes little time.
Describe your plan a bit better.
Ok so I have a motorcycle that I would like to monitor remotely, I need 3x cameras on the bike that will live stream to a control room.
I will be using a SIM7600CE-T connected to arduino for internet connectivety
And I am completely new to this
is how I use the esp32cam to ftp images to a server.
#include "sdkconfig.h" // used for log printing
#include "esp_system.h"
#include "freertos/FreeRTOS.h" //freeRTOS items to be used
#include "freertos/task.h"
#include "certs.h"
#include "esp_camera.h"
#include "soc/soc.h"           // Disable brownout problems
#include "soc/rtc_cntl_reg.h"  // Disable brownout problems
#include "driver/rtc_io.h"
#include <WiFi.h>
#include <WiFiClient.h>
#include "ESP32_FTPClient.h"
WiFiClient wifiClient; // do the WiFi instantiation thing
ESP32_FTPClient ftp (ftp_server, ftp_user, ftp_pass, 5000, 2);
void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
  switch (event) {
    case SYSTEM_EVENT_STA_CONNECTED:
      log_i("Connected to WiFi access point");
    case SYSTEM_EVENT_STA_DISCONNECTED:
      log_i("Disconnected from WiFi access point");
    case SYSTEM_EVENT_AP_STADISCONNECTED:
      log_i("WiFi client disconnected");
    default: break;
} // void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
  WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0); //disable brownout detector
  if ( configInitCamera() )
    xTaskCreatePinnedToCore( capturePhoto_sendFTP, "capturePhoto_sendFTP", 20000, NULL, 3, NULL, 1 );
    log_i( "camera failed to initilize. Quitting programed operations." );
} // void setup()
void capturePhoto_sendFTP( void *pvParameters )
  TickType_t xLastWakeTime    = xTaskGetTickCount();
  const TickType_t xFrequency = 100; //delay for mS
  for (;;)
    log_i( "tick");
    if ( WiFi.status() == WL_CONNECTED )
      camera_fb_t * fb = NULL; // pointer
      fb = esp_camera_fb_get();
      if (!fb)
        log_i( "Camera capture failed" );
        ftp.OpenConnection(); // try open FTP
        if ( ftp.isConnected() )
          //try send file ftp
          ftp.ChangeWorkDir( ftp_path );
          // Delete existing file, create the new file, and send the image to the file
          ftp.DeleteFile( ftp_file_name );
          ftp.InitFile( ftp_file_type ); //"Type I"
          ftp.NewFile( ftp_file_name );
          ftp.WriteData( (unsigned char *)fb->buf, fb->len );
          ftp.CloseFile();
          ftp.CloseConnection();
        esp_camera_fb_return(fb); //return the frame buffer back to the driver for reuse
      log_i( "In capturePhoto_sendFTP found WiFi not connected ");
      connectToWiFi();
    vTaskDelayUntil( &xLastWakeTime, xFrequency );
  vTaskDelete( NULL );
} //void capturePhoto_sendFTP( void *pvParameters )
void configureCameraSettings()
  sensor_t * s = esp_camera_sensor_get(); //see certs.h for more info
  s->set_brightness(s, -1);     // -2 to 2 **************************
  s->set_contrast(s, 0);       // -2 to 2
  s->set_saturation(s, 0);     // -2 to 2
  s->set_special_effect(s, 0); // 0 to 6 (0 - No Effect, 1 - Negative, 2 - Grayscale, 3 - Red Tint, 4 - Green Tint, 5 - Blue Tint, 6 - Sepia)
  s->set_whitebal(s, 1);       // 0 = disable , 1 = enable
  s->set_awb_gain(s, 1);       // 0 = disable , 1 = enable
  s->set_wb_mode(s, 0);        // 0 to 4 - if awb_gain enabled (0 - Auto, 1 - Sunny, 2 - Cloudy, 3 - Office, 4 - Home)
  s->set_exposure_ctrl(s, 1);  // 0 = disable , 1 = enable
  s->set_aec2(s, 0);           // 0 = disable , 1 = enable
  s->set_ae_level(s, 0);       // -2 to 2
  s->set_aec_value(s, 300);    // 0 to 1200
  s->set_gain_ctrl(s, 1);      // 0 = disable , 1 = enable
  s->set_agc_gain(s, 0);       // 0 to 30
  s->set_gainceiling(s, (gainceiling_t)0);  // 0 to 6
  s->set_bpc(s, 0);            // 0 = disable , 1 = enable
  s->set_wpc(s, 1);            // 0 = disable , 1 = enable
  s->set_raw_gma(s, 1);        // 0 = disable , 1 = enable
  s->set_lenc(s, 1);           // 0 = disable , 1 = enable
  s->set_hmirror(s, 0);        // 0 = disable , 1 = enable
  s->set_vflip(s, 0);          // 0 = disable , 1 = enable
  s->set_dcw(s, 1);            // 0 = disable , 1 = enable
  s->set_colorbar(s, 0);       // 0 = disable , 1 = enable
} //void configureCameraSettings()
bool configInitCamera()
  camera_config_t config = {}; // Stores the camera configuration parameters
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer   = LEDC_TIMER_0;
  config.pin_d0       = GPIO_NUM_5; //Y2
  config.pin_d1       = GPIO_NUM_18; //Y3
  config.pin_d2       = GPIO_NUM_19; //Y4
  config.pin_d3       = GPIO_NUM_21; //Y5
  config.pin_d4       = GPIO_NUM_36; //Y6
  config.pin_d5       = GPIO_NUM_39; //Y7
  config.pin_d6       = GPIO_NUM_34; //Y8
  config.pin_d7       = GPIO_NUM_35; // Y9
  config.pin_xclk     = GPIO_NUM_0; //XCLK
  config.pin_pclk     = GPIO_NUM_22; //PCLK
  config.pin_vsync    = GPIO_NUM_25; //VSSYNC
  config.pin_href     = GPIO_NUM_23; // HREF
  config.pin_sscb_sda = GPIO_NUM_26; //SIOD
  config.pin_sscb_scl = GPIO_NUM_27; //SIOC
  config.pin_pwdn     = GPIO_NUM_32; //PWDN
  config.pin_reset    = -1; //RESET
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG; //assuming default is has PSRAM
  config.frame_size = FRAMESIZE_UXGA; // FRAMESIZE_ + QVGA|CIF|VGA|SVGA|XGA|SXGA|UXGA
  config.jpeg_quality = 10; //0-63 lower number means higher quality
  config.fb_count = 2;
  // Initialize the Camera
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    log_i("Camera init failed with error 0x%x", err);
    return false;
    configureCameraSettings();
    return true;
} //void configInitCamera()
void connectToWiFi()
  int TryCount = 0;
  while ( WiFi.status() != WL_CONNECTED )
    TryCount++;
    WiFi.disconnect();
    WiFi.begin( SSID, PASSWORD );
    vTaskDelay( 4000 );
    if ( TryCount == 10 )
      ESP.restart();
  WiFi.onEvent( WiFiEvent );
void loop() {}
Ok thanks, will try this method
For Arduino, you can consider Pixi cam:
https://pixycam.com/
Can I use a pocket wifi router and connect all 3 ESP32 camers to that to send data to server?
Ok thanks, would I be able to connect 3 cameras to 1 arduino? I need something that will be realiable and will be able to send clear video or picture to remote server so I can capture anything that might occur like a accident
What happened when you tried to use a pocket wifi router and connect all 3 ESP32 cameras to that to send data?
Which Arduino will you be connecting the 3 ESP32 CAMS to?
I have not tried yet. I am trying to gather information from experienced people so I don't go and buy hardware that is not required
Which arduino would you recommend?
What's the purpose of sending the images to a centralized location?
Incase of theft or accident, footage could be lost if stored locally
Consider sending the images to a server of some sort. I have a few ESP32CAM's that send their images to a RPi acting as a FTP server. From there image processing is done and the images are sent to their final destinations.
A BeagleBone can also be used as a FTP server and image processor costing less than a RPi but is a bit more complicated to use or you can use an existing PC.
Ok thanks, will give that a try
Might help you get started.
#include "certs.h"
#include <WiFi.h>
  switch (event) {
    default: break;
} // void setup()
  for (;;)
    log_i( "tick");
      if (!fb)
          //try send file ftp
          ftp.CloseFile();
      connectToWiFi();
    return false;
    return true;
  int TryCount = 0;
    TryCount++;
    WiFi.disconnect();
    vTaskDelay( 4000 );
      ESP.restart();
void loop() {}
