Just bought a magnetic stripe reader, came with 11 pins(black,red,brown,orange,white,yellow,green,blue,purple,grey,white) respectively. It is written it uses TTL protocol, with my little understanding in electronics I connected reader's green,blue to GPIO1,GPIO3 of the esp32. I can not get a card reading from it.
The datasheet show Green - RCL and Blue - RDT. The datasheet has few pins colors compared to my device. I wanted to know if these colors mean anything and are they the reason am not getting readings.
xfpd
August 3, 2022, 12:04am
3
braysonJohn:
Is this the sequence on the wires connected to the pins? Normally, comm color scheme is BLK BRN RED ORG YEL GRN BLU PUR GRY WHT PNK TAN... so this is proprietary. Look for the Reader's datasheet.
The datasheet show Green - RCL and Blue - RDT. It has f
I have tested on ESP-32 it is working perfectly.
// Magnetic Card Reader with ESP32 Arduino
// Created on 2020-06-13 by Noah Coad
// Connect card reader cable to ESP32 pins:
// DATA (yellow) = 15, PRESENT (orange) = 14, STROBE (green) = 32
// I'm using Adafruit HUZZAH32 ESP32 Feather Board, but any ESP32 should work
// And the Magtek 21050071 card reader, which reads the 2nd card track only (encoded in 5 bits)
// Double check your card reader, which track(s) it reads, because track #1 is encoded differently
// Much thanks to nevdull's tutorial which this is based off of:
// https://www.instructables.com/id/Turn-your-Arduino-into-a-Magnetic-Card-Reader/
// variables
const int PIN_LED = 13;
// card data struct
struct CardReader {
const uint8_t PIN_CARD_DATA;
const uint8_t PIN_CARD_PRESENT;
const uint8_t PIN_CARD_STROBE;
bool bDataPresent;
char buff[40];
int64_t stamp;
uint8_t data, bitpos, idx;
// init card info
CardReader reader = {15, 14, 32, false, "", 0, 0, 0, 0};
// interrupt
void IRAM_ATTR isr() {
// reset our timer
reader.stamp = 0;
// a digital 1 is read as a low pin
if (digitalRead(reader.PIN_CARD_DATA) == LOW) { // low=1
bitSet(reader.data, reader.bitpos++);
reader.bDataPresent = true;
} else if (reader.bDataPresent) {
bitClear(reader.data, reader.bitpos++);
// if we've ready five bits already
// save off this byte worth of data
if (reader.bitpos == 5) {
reader.buff[reader.idx++] = reader.data;
reader.bitpos = 0;
// remember when last bit was
reader.stamp = millis();
// setup the pin modes
pinMode(reader.PIN_CARD_DATA, INPUT_PULLUP);
pinMode(reader.PIN_CARD_PRESENT, INPUT_PULLUP);
pinMode(reader.PIN_CARD_STROBE, INPUT_PULLUP);
pinMode(PIN_LED, OUTPUT);
digitalWrite(PIN_LED, LOW);
// attach interrupt
attachInterrupt(reader.PIN_CARD_STROBE, isr, FALLING);
// reset card data
initCardData();
// if data is ready
if (reader.stamp > 0 && ((millis() - reader.stamp) > 10)) {
printf("Card slide: ");
for (int x = 0; x < reader.idx - 1; x++) {
bitClear(reader.buff[x], 4);
printf("%1X", reader.buff[x]);
printf("\n");
// check validity
int pos = 0;
for (int x = 14; x < reader.idx; x++)
if (reader.buff[x] == 0x0D) { pos = x; break; }
bool valid = pos > 13 && pos < 21 && reader.buff[0] == 0x0B && reader.idx > pos + 4;
// show card info if valid
if (valid) {
for (int x = 1; x < pos + 5; x++) reader.buff[x] += 48;
printf(" valid, card # %.*s, exp %.*s/%.*s\n", pos - 1, &(reader.buff[1]),
2, &(reader.buff[pos + 3]), 2, &(reader.buff[pos + 1]));
else printf(" invalid\n");
initCardData();
digitalWrite(PIN_LED, HIGH);
void initCardData() {
reader.idx = 0;
reader.bDataPresent = false;
reader.bitpos = 0;
