Esp32 devkit v1, boot loop error while using wifi.h
Configuring access point...
ets Jul 29 2019 12:21:46
rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:4688
load:0x40078000,len:15516
load:0x40080400,len:4
load:0x40080404,len:3196
entry 0x400805a4
entry 0x400805a4
the board is looping in boot like these when i use wifi.h.
But It is working perfectly without wifi.h.
Chip is ESP32-D0WD-V3 (revision v3.1)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: 3c:8a:1f:a4:b3:68
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
I uploaded wifi program that is simple only to get macaddress.
But it didn't uploaded.gave me fail error.
After this,i got this problem.
Board Info
Crystal is 40MHz
Uploading stub...
Running stub...
Stub running...
entry 0x400805a4
entry 0x400805a4
please everyone
Your two topics on the same subject have been merged. please do not cross-post, it wastes people's time.
Sorry for my mistakes.
I have no experience with ESP32 based boards so can't help further. It might be a good idea however to post your sketch; please do not forget to use code tags.
That is my code.It is from eaxmples
#include <WiFi.h>
const char *ssid = "your-ssid";
const char *password = "your-password";
int btnGPIO = 0;
int btnState = false;
  delay(10);
  // Set GPIO0 Boot button as input
  pinMode(btnGPIO, INPUT);
  // We start by connecting to a WiFi network
  // To debug, please enable Core Debug Level to Verbose
  Serial.print("[WiFi] Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  // Auto reconnect is set true as default
  // To set auto connect off, use the following function
  //    WiFi.setAutoReconnect(false);
  // Will try for about 10 seconds (20x 500ms)
  int tryDelay = 500;
  int numberOfTries = 20;
  // Wait for the WiFi event
  while (true) {
    switch (WiFi.status()) {
      case WL_NO_SSID_AVAIL: Serial.println("[WiFi] SSID not found"); break;
      case WL_CONNECT_FAILED:
        Serial.print("[WiFi] Failed - WiFi not connected! Reason: ");
        return;
      case WL_CONNECTION_LOST: Serial.println("[WiFi] Connection was lost"); break;
      case WL_SCAN_COMPLETED:  Serial.println("[WiFi] Scan is completed"); break;
      case WL_DISCONNECTED:    Serial.println("[WiFi] WiFi is disconnected"); break;
      case WL_CONNECTED:
        Serial.println("[WiFi] WiFi is connected!");
        Serial.print("[WiFi] IP address: ");
        return;
      default:
        Serial.print("[WiFi] WiFi Status: ");
        Serial.println(WiFi.status());
    delay(tryDelay);
    if (numberOfTries <= 0) {
      Serial.print("[WiFi] Failed to connect to WiFi!");
      // Use disconnect function to force stop trying to connect
      WiFi.disconnect();
      return;
      numberOfTries--;
  // Read the button state
  btnState = digitalRead(btnGPIO);
  if (btnState == LOW) {
    // Disconnect from WiFi
    Serial.println("[WiFi] Disconnecting from WiFi!");
    // This function will disconnect and turn off the WiFi (NVS WiFi data is kept)
    if (WiFi.disconnect(true, false)) {
      Serial.println("[WiFi] Disconnected from WiFi!");
Have you got anything connected to any of the ESP32 pins, if so which pin ?
Did it get as far as printing any of your debug messages to the console ?
Try setting the Core Debug level to verbose
               app0 : addr: 0x00010000, size:  1280.0 KB, type:  APP, subtype: OTA_0
               app1 : addr: 0x00150000, size:  1280.0 KB, type:  APP, subtype: OTA_1
             spiffs : addr: 0x00290000, size:  1408.0 KB, type: DATA, subtype: SPIFFS
           coredump : addr: 0x003F0000, size:    64.0 KB, type: DATA, subtype: COREDUMP
Software Info:
  Compile Date/Time : Feb 25 2025 21:22:36
  Compile Host OS   : windows
  ESP-IDF Version   : v5.3.2-584-g489d7a2b3a-dirty
  Arduino Version   : 3.1.3
Board Info:
  Arduino Board     : ESP32_DEV
  Arduino Variant   : esp32
  Arduino FQBN      : esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=verbose,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=all,JTAGAdapter=default,ZigbeeMode=default
============ Before Setup End ============
[   698][V][esp32-hal-uart.c:421] uartBegin(): UART0 baud(115200) Mode(800001c) rxPin(3) txPin(1)
[   707][V][esp32-hal-uart.c:510] uartBegin(): UART0 not installed. Starting installation
[   718][V][esp32-hal-uart.c:575] uartBegin(): UART0 initialization done.
[   742][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type GPIO (1) successfully set to 0x401634c8
[   753][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 0 successfully set to type GPIO (1) with bus 0x1
I got this,sir
Do you have an external resistor on that pin ?
no sir.
Even i just only try to connect wifi,I got the error (boot loop)
#include <WiFi.h>
const char* ssid = "examplewifi";       // Replace with your Wi-Fi SSID
const char* password = "234234234"; // Replace with your Wi-Fi password
  WiFi.disconnect(true);  // Reset Wi-Fi settings
  Serial.println("Connecting to Wi-Fi...");
  unsigned long startAttemptTime = millis();
  while (WiFi.status() != WL_CONNECTED && millis() - startAttemptTime < 10000) {
    Serial.print(".");
  if (WiFi.status() == WL_CONNECTED) {
    Serial.println("\nWi-Fi Connected!");
    Serial.print("IP Address: ");
    Serial.println("\nFailed to connect to Wi-Fi. Restarting...");
  // Your main code here
That is very simple code to connect wifi.
Still looping. :frowning:
the response is
Flash Info:
  Chip Size         :  4194304 B (4 MB)
  Block Size        :    65536 B (  64.0 KB)
  Sector Size       :     4096 B (   4.0 KB)
  Page Size         :      256 B (   0.2 KB)
  Bus Speed         : 80 MHz
  Bus Mode          : QIO
Partitions Info:
                nvs : addr: 0x00009000, size:    20.0 KB, type: DATA, subtype: NVS
            otadata : addr: 0x0000E000, size:     8.0 KB, type: DATA, subtype: OTA
Software Info:
Board Info:
[   733][W][STA.cpp:541] disconnect(): STA already disconnected.
But Without using wifi,It is working perfectly.
There could be an inconsistency here. Have you made any changes to the flash mode settings ?
Yep,I tried flash Mode both of DIO ad QIO.
It changed nothing.still happening
LOG INFO
Software Info:
  Compile Date/Time : Feb 25 2025 21:47:02
Board Info:
  Arduino FQBN      : esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=debug,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=all,JTAGAdapter=default,ZigbeeMode=default
Setup Started...
[  2513][W][STA.cpp:541] disconnect(): STA already disconnected.
Wi-Fi settings reset.
load:0x3fff0030,len:4916
load:0x40078000,len:16492
Sketch code
#include <WiFi.h>
const char* ssid = "your_SSID";       // Replace with your Wi-Fi SSID
const char* password = "your_PASSWORD"; // Replace with your Wi-Fi password
  Serial.println("Setup Started...");
  Serial.println("Wi-Fi settings reset.");
  Serial.println("Wi-Fi.begin() called. Waiting for connection...");
    Serial.print("."); // Print dots while trying to connect
    delay(2000);
    ESP.restart(); // Restart ESP32 to prevent infinite loop
  Serial.println("Looping...");
It is working on this line and then after reaching WiFi.begin(),board is resetting.
Show a link to the exact board you have. It may be that ESP32 Dev Module is not an appropriate choice of board.
It is Board Link
BOard info
ESP-wroom-32 (esp32 devkit v1)
LinK
Try selecting this board since yours appears to have DOIT printed on it:
