This is the first time I've used the esp32 but I've been using the Arduino for a few years with the atmega328. So I am thinking my problem here is probably my fault but I've stripped it down to a skeleton bit of code taken from the examples folder and its still happening. The board is an esp32wroom32.
Whats happening is that as soon as BLEDevice::init is called the device seems to panic and reboot. The reason seems to vary each time although its all flying past so fast that I'm not totally sure if there is actually a single error. I've attached a minicom log of the output during which I have pressed the reboot button a few times with a gap of a few seconds between but its not clear when exactly I pressed it and when it rebooted on its own. If there is an option to stop it rebooting itself on error and just stop that might help isolate the user reboot error from the self rebooting error, but OTOH maybe it does not matter.
I've assumed that I had the wrong libraries installed because I started using my usual old 1.8 version of arduino and installed the latest esp library. So I installed the latest 2.x arduino and the board lib but its still happening. I've also tried several different boards in the board manager but none work. So its a completely fresh install of 2.x arduino, latest esp32 board from espressif, and default settings, example code. Since its still happening I'm wondering if the hardware is toast. I can run other example projects from the arduino menu without this problem.
Code I am running which came from ble->server example (same result happens with original code but I stripped it down bit by bit to the ble::init line which is the point at which it panics).
#include <BLEDevice.h>
#include <BLEUtils.h>
#include <BLEServer.h>
#define SERVICE_UUID "4fafc201-1fb5-459e-8fcc-c5c9c331914b"
#define CHARACTERISTIC_UUID "beb5483e-36e1-4688-b7f5-ea07361b26a8"
Serial.println("Point 1");
BLEDevice::init("ESP init");
Serial.println("Point 2");
delay(2000);
And output from minicom:
ets Jul 29 2019 12:21:46
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:4980
load:0x40078000,len:16612
load:0x40080400,len:3480
entry 0x400805b4
E (358) esp_core_äfŠ}±
Íé Core dump data check failed:
Calculated checksum='699d2fde'
Image checksum='020cf01d'Point 1
ASSERT_ERR((((uint32_t)twosc << 10) & ~((uint32_t)0x001FFC00)) == 0), in ld.c at line 2664
Guru Meditation Error: Core 0 panic'ed (IllegalInstruction). Exception was unhandled.
Memory dump at 0x4008f64c: 0000f01d 00004136 f01d0000
Core 0 register dump:
PC : 0x4008f653 PS : 0x00060c30 A0 : 0x80087a55 A1 : 0x3ffd02b0
A2 : 0x3ff9dc1d A3 : 0x00000000 A4 : 0x00000000 A5 : 0x3ff9e033
A6 : 0x00000a68 A7 : 0xfffffffb A8 : 0x8000814b A9 : 0x3ffd0220
A10 : 0x00000000 A11 : 0x3ffd0244 A12 : 0x3ffd01ef A13 : 0x00000034
A14 : 0x00000000 A15 : 0x3ffd01f5 SAR : 0x00000004 EXCCAUSE: 0x00000000
EXCVADDR: 0x00000000 LBEG : 0x400905fd LEND : 0x4009060d LCOUNT : 0xfffffffd
Backtrace: 0x4008f650:0x3ffd02b0 0x40087a52:0x3ffd02d0 0x4003c3f2:0x3ffd02f0 0x4016e98a:0x3ffd0330 0x40055199:0x3ffd0350 0x4017a2f2:0x3ffd0370 0x401654ab:0x3ffd03b0 0x401659e3:0x3ffd03d0 0x40093aad:0x3ffd0400
ELF file SHA256: bce087efb
abort() was called at PC 0x40155975 on core 0
Backtrace: 0x40092f04:0x3ffcff50 0x40092ec9:0x3ffcff70 0x40099211:0x3ffcff90 0x40155975:0x3ffd0010 0x401567a6:0x3ffd0040 0x40155692:0x3ffd0110 0x4018d48c:0x3ffd0130 0x400d6b33:0x3ffd0160 0x400db409:0x3ffd0180 0x40081cd5:0x3ffd01d0 0x40083b44:0x3ffd01f0 0x4008f650:0x3ffd02b0 0x40087a52:0x3ffd02d0 0x4003c3f2:0x3ffd02f0 0x4016e98a:0x3ffd0330 0x40055199:0x3ffd0350 0x4017a2f2:0x3ffd0370 0x401654ab:0x3ffd03b0 0x401659e3:0x3ffd03d0 0x40093aad:0x3ffd0400
Re-entered core dump! Exception happened during core dump!
Rebooting...
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
entry 0x400805b4
Calculated checksum='d10ef15d'
Image checksum='ffffffff'Point 1
rst:0x8 (TG1WDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
entry 0x400805b4
E (492) esp_core_äfŠ}±
ASSERT_ERR(0), in arch_main.c at line 1162
PC : 0x4008f653 PS : 0x00060830 A0 : 0x80087a55 A1 : 0x3ffd0390
A2 : 0x3f406389 A3 : 0x00000000 A4 : 0x00000000 A5 : 0x3f40e00a
A6 : 0x0000048a A7 : 0xfffffffb A8 : 0x8000814b A9 : 0x3ffd0300
A10 : 0x00000000 A11 : 0x3ffd0324 A12 : 0x3ffd02cf A13 : 0x00000032
A14 : 0x00000000 A15 : 0x3ffd02d5 SAR : 0x00000004 EXCCAUSE: 0x00000000
EXCVADDR: 0x00000000 LBEG : 0x40090141 LEND : 0x40090163 LCOUNT : 0xffffffff
Backtrace: 0x4008f650:0x3ffd0390 0x40087a52:0x3ffd03b0 0x40165ae6:0x3ffd03d0 0x40093aad:0x3ffd0400
<Z%íÿjpf ``ôr¢
ELF file SHA256: bce087efb<Z%íÿjpf ``ôr¢<Z%íÿjpf ``ôr¢ets Jul 29 2019 12:21:46
entry 0x400805b4
Calculated checksum='a1cd44b3'
Rebooting...
entry 0x400805b4
Point 1
ASSERT_PARAM(262144 0), in rwip.c at line 364
PC : 0x4008f653 PS : 0x00060c30 A0 : 0x80087c06 A1 : 0x3ffd0330
A2 : 0x00000000 A3 : 0x00040000 A4 : 0x00000000 A5 : 0x3f40f1bd
A6 : 0x0000016c A7 : 0xfffffffc A8 : 0x8000814b A9 : 0x3ffd02a0
A10 : 0x00000000 A11 : 0x3ffd02c3 A12 : 0x3ffd026f A13 : 0x00000034
A14 : 0x00000000 A15 : 0x3ffd0274 SAR : 0x00000004 EXCCAUSE: 0x00000000
EXCVADDR: 0x00000000 LBEG : 0x4000c46c LEND : 0x4000c477 LCOUNT : 0xffffffff
Backtrace: 0x4008f650:0x3ffd0330 0x40087c03:0x3ffd0350 0x4017a3b7:0x3ffd0370 0x401654ab:0x3ffd03b0 0x401659e3:0x3ffd03d0 0x40093aad:0x3ffd0400
Rebooting...
entry 0x400805b4
Point 1
Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled.
PC : 0x400e5393 PS : 0x00060a30 A0 : 0x8008f0b0 A1 : 0x3ffd02e0
A2 : 0x00000000 A3 : 0xfffe01ff A4 : 0x3ffd0768 A5 : 0x3ffc6d08
A6 : 0x00000000 A7 : 0x00000002 A8 : 0x00000001 A9 : 0x3ffd02e0
A10 : 0x00040004 A11 : 0x00060a24 A12 : 0x00060a20 A13 : 0x3fffd6c8
A14 : 0x00000000 A15 : 0x0000001a SAR : 0x00000011 EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000000 LBEG : 0x400900d8 LEND : 0x400900ee LCOUNT : 0x00000000
Backtrace: 0x400e5390:0x3ffd02e0 0x4008f0ad:0x3ffd0300 0x400882dd:0x3ffd0330 0x4001788d:0x3ffd0350 0x4017a2da:0x3ffd0370 0x401654ab:0x3ffd03b0 0x401659e3:0x3ffd03d0 0x40093aad:0x3ffd0400
Rebooting...
entry 0x400805b4
Point 1
A6 : 0x00040000 A7 : 0x00000002 A8 : 0x00000001 A9 : 0x3ffd02e0
A10 : 0x00040004 A11 : 0x00060a24 A12 : 0x00060a20 A13 : 0x3ffbd6c8
A14 : 0x00040000 A15 : 0x0000001a SAR : 0x00000011 EXCCAUSE: 0x0000001c
Rebooting...
entry 0x400805b4
Point 1
Backtrace: 0x4008f650:0x3ffd0330 0x400c7c03:0x3ffd0350 |<-CORRUPTED
<Z%íÿjpf ``ôr¢
ELF file SHA256: bce087efb<Z%íÿjpf ``ôr¢<Z%íÿjpf ``ôr¢Rebooting...
entry 0x400805b4
Point 1
Rebooting...
entry 0x400805b4
Point 1
Rebooting...
entry 0x400805b4
Point 1
assert failed: esp_efuse_utility_process esp_efuse_utility.c:84 (bits_counter <= req_size)
Backtrace: 0x40092f04:0x3ffd00f0 0x40092ec9:0x3ffd0110 0x40099301:0x3ffd0130 0x400d99a2:0x3ffd0270 0x400d983e:0x3ffd02b0 0x400dd171:0x3ffd02d0 0x400dd217:0x3ffd0310 0x400dd2cb:0x3ffd0330 0x400834ea:0x3ffd0360 0x40165371:0x3ffd0380 0x40165440:0x3ffd03b0 0x401659e3:0x3ffd03d0 0x40093aad:0x3ffd0400
Rebooting...
entry 0x400805b4
Point 1
<Z%íÿjpf ``ôr¢
entry 0x400805b4
Point 1
A10 : 0x00000004 A11 : 0x00060a24 A12 : 0x00060a20 A13 : 0x3ffbd6c8
Rebooting...
entry 0x400805b4
Point 1
Backtrace: 0x400e5390:0x3ffd02e0 0x400cf0ad:0x3ffd0300 |<-CORRUPTED
entry 0x400805b4
Calculated checksum='1e5f04b3'
Rebooting...
entry 0x400805b4
Point 1
Rebooting...
entry 0x400805b4
Point 1
PC : 0x40054c15 PS : 0x00060e30 A0 : 0x8017a300 A1 : 0x3ffd0340
A2 : 0x3ffee70c A3 : 0x9c510192 A4 : 0x00040004 A5 : 0x40013f14
A6 : 0x3ffb8360 A7 : 0x0000160c A8 : 0x80054c10 A9 : 0x3ffd02f0
A10 : 0x3ffb03f2 A11 : 0x00000000 A12 : 0xffffff00 A13 : 0x00040000
A14 : 0xffffff7f A15 : 0xffefffff SAR : 0x00000010 EXCCAUSE: 0x0000001c
EXCVADDR: 0x9c51019a LBEG : 0x40090141 LEND : 0x40090163 LCOUNT : 0xffffffff
Backtrace: 0x40054c12:0x3ffd0340 0x4017a2fd:0x3ffd0370 0x401654ab:0x3ffd03b0 0x401659e3:0x3ffd03d0 0x40093aad:0x3ffd0400
entry 0x400805b4
Calculated checksum='dc628aa4'
Image checksum='c2004136RøPoint 1
Rebooting...
entry 0x400805b4
Point 1
Rebooting...
entry 0x400805b4
Point 1
Rebooting...
entry 0x400805b4
Point 1
Rebooting...
entry 0x400805b4
Point 1
Rebooting...
entry 0x400805b4
Point 1
Rebooting...
entry 0x400805b4
Point 1
Any ideas here would be kindly appreciated.
