Esp32 devkitv1 servo MG90s issues
I'm working with my esp32 Devkitv1 board and an MG90S servo. I have the servo connected to pin VIN (Red Wire), GND (Brown Wire), and GPIO pin 18 (Orange Wire). The code is simple, I based it off the example code esp32 sweep code. I can see from my voltmeter that it has 5V to the device but no response. Any thoughts as to what's wrong here?
I reviewed the spec sheet, and it should use 5v.
Micro Servo Motor MG90S - Tower Pro (components101.com)
#include <ESP32Servo.h>
Servo myservo;  // create servo object to control a servo
int pos = 0;    // variable to store the servo position
#if defined(ARDUINO_ESP32S2_DEV)
int servoPin = 17;
#else
int servoPin = 18;
#endif
	// Allow allocation of all timers
	ESP32PWM::allocateTimer(0);
	ESP32PWM::allocateTimer(1);
	ESP32PWM::allocateTimer(2);
	ESP32PWM::allocateTimer(3);
	myservo.setPeriodHertz(50);    // standard 50 hz servo
  myservo.attach(servoPin, 0, 3000); // attaches the servo on pin 18 to the servo object
  Serial.write("0\n");
  myservo.write(0);
  myservo.detach();
  myservo.attach(servoPin, 180, 3000); // attaches the servo on pin 18 to the servo object
  Serial.write("180\n");
  myservo.write(180);
  myservo.detach();
Here's some examples from a different library:
hmm, not sure why those are not working. Servo_Sweep.ino - Wokwi Arduino and ESP32 Simulator
c:\repo\Arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp: In member function 'uint8_t Pwm::tone(uint8_t, uint32_t, uint16_t, uint16_t)':
c:\repo\arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp:91:65: error: 'ledcChangeFrequency' was not declared in this scope
         ledcChangeFrequency(ch, frequency, config[ch].resolution);
c:\repo\arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp: In member function 'void Pwm::ledc_attach_with_invert(uint8_t, uint8_t, bool)':
c:\repo\arduino\libraries\ESP32_ESP32S2_AnalogWrite\src\pwmWrite.cpp:319:3: error: 'ledc_channel_config_t' has no non-static data member named 'flags'
exit status 1
Compilation error: exit status 1
Are you using the latest releases?
Arduino only lists 4.2.3 for ESP32-ESP32S2-AnalogWrite. I'm also using Arduino IDE 2.0.3 with ESP32 stable. https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_index.json
Thanks for the info.
I was using using Arduino IDE 1.8.19. After installing 2.0.3, I selected the ESP32 Dev Module and updated all libraries. Then I closed and re-opened 2.0.3, then selected File-->Examples-->ESP32 ESP32S2 AnalogWrite-->Dual_Servo_Sweep_Speed.ino , then ran Verify.
If 4.2.4 is shown as installed, then 4.2.3 will be highest option on the version drop down selector.
Thanks for assisting. I tried an experiment, I think the ESP32 pwm signal is not strong enough for the servo. I connected the same servo to an uno board and ran the servo example sweep program and the servo works. I checked the pwm voltage and the uno sends .6 and the esp32 is sending .4 volts. I suspect this is the issue.
Well, if you're using a multi-meter to measure the DC voltage of a servo pwm pulse, then it would be normal to measure 0.6V on a 5V Uno and 0.4V on a 3.3V ESP32.
A scope would be the ideal instrument to use, but I don't think this is the problem. When using the ESP32, make sure to power the servo with 5V, preferably using a separate supply.
Post a schematic, post an image of the project.
Why utilize all 4 timers?
What is this supposed to be doing
  myservo.write(0);
  myservo.detach();
  myservo.write(180);
  myservo.detach();
Why not just attached the servo in setup and leave it attached?
The ESP PWM signal is strong enough.
