I am trying to generate sound (16bits@44.1kHz stereo) thru ESP32's I2S with external DAC (PCM5102) but the sound is dirty, for example, the sine wave that is fully-swung (-32768~+32767) is distorted.
In my investigation to I2S signals with logic analyzer, LSB of DOUT seems left-shifted by 1 BCLK.
Here is the captured image, in case of Lch should be 0x0001 and Rch should be 0x0002:
DOUT seems 1-bit left-shifted. Is it well-known issue on ESP32?
I am using Arduino 1.8.15, ESP32 board/platform is version 1.0.6.
Thanks,
CODE:
uint16_t wave[2] ;
static const i2s_port_t i2s_num = I2S_NUM_0 ;
static const i2s_pin_config_t pin_config = {
.bck_io_num = I2S_BCLK,
.ws_io_num = I2S_LRCK,
.data_out_num = I2S_DOUT,
.data_in_num = I2S_PIN_NO_CHANGE
static const i2s_config_t i2s_config = {
.mode = (i2s_mode_t) (I2S_MODE_MASTER | I2S_MODE_TX),
.sample_rate = 44100,
.bits_per_sample = I2S_BITS_PER_SAMPLE_16BIT,
.channel_format = I2S_CHANNEL_FMT_RIGHT_LEFT,
.communication_format = I2S_COMM_FORMAT_I2S_MSB,
.intr_alloc_flags = ESP_INTR_FLAG_LEVEL1,
.dma_buf_count = 4,
.dma_buf_len = 1024,
.use_apll = false,
.tx_desc_auto_clear = true
i2s_driver_install(i2s_num, &i2s_config, 0, NULL);
i2s_set_pin(i2s_num, &pin_config);
i2s_zero_dma_buffer(i2s_num);
wave[0] = 0x0001 ; // Lch
wave[1] = 0x0002 ; // Rch
size_t written ;
i2s_write(I2S_NUM_0, wave, sizeof(wave), &written, portMAX_DELAY) ;
