Hi Everyone!
I have two ESP32S, 38 pin. Both of these are not printing their ip address. I am using Serial.println(WiFi.localIP()); to get ip address. I have programmed these with example code 'WifiScan' given in Arduino IDE. I have added 'Serial.println(WiFi.localIP());' to said code, I am getting Wifi networks list but not ip address.
Please help. Thanks
* This sketch demonstrates how to scan WiFi networks.
* The API is based on the Arduino WiFi Shield library, but has significant changes as newer WiFi functions are supported.
* E.g. the return value of `encryptionType()` different because more modern encryption is supported.
#include "WiFi.h"
// Set WiFi to station mode and disconnect from an AP if it was previously connected.
WiFi.mode(WIFI_STA);
WiFi.disconnect();
delay(100);
Serial.println("Setup done");
Serial.println("Scan start");
// WiFi.scanNetworks will return the number of networks found.
int n = WiFi.scanNetworks();
Serial.println("Scan done");
if (n == 0) {
Serial.println("no networks found");
Serial.print(n);
Serial.println(" networks found");
Serial.println("Nr | SSID | RSSI | CH | Encryption");
for (int i = 0; i < n; ++i) {
// Print SSID and RSSI for each network found
Serial.printf("%2d",i + 1);
Serial.print(" | ");
Serial.printf("%-32.32s", WiFi.SSID(i).c_str());
Serial.printf("%4d", WiFi.RSSI(i));
Serial.printf("%2d", WiFi.channel(i));
switch (WiFi.encryptionType(i))
case WIFI_AUTH_OPEN:
Serial.print("open");
case WIFI_AUTH_WEP:
Serial.print("WEP");
case WIFI_AUTH_WPA_PSK:
Serial.print("WPA");
case WIFI_AUTH_WPA2_PSK:
Serial.print("WPA2");
case WIFI_AUTH_WPA_WPA2_PSK:
Serial.print("WPA+WPA2");
case WIFI_AUTH_WPA2_ENTERPRISE:
Serial.print("WPA2-EAP");
case WIFI_AUTH_WPA3_PSK:
Serial.print("WPA3");
case WIFI_AUTH_WPA2_WPA3_PSK:
Serial.print("WPA2+WPA3");
case WIFI_AUTH_WAPI_PSK:
Serial.print("WAPI");
default:
Serial.print("unknown");
delay(10);
Serial.println("");
// Delete the scan result to free memory for code below.
WiFi.scanDelete();
// Wait a bit before scanning again.
delay(5000);
